Old 01-02-2010, 02:43 AM   #9616
blade072's Avatar
Trader Rating: 98 (100%+)
happy to say i received the hotwire v4 software and updated to the vegas 2 update....time to have some fun.....thanks tekin keep up the good work..
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-02-2010, 03:59 AM   #9617
Default RPM Ranges
Hi everyone. Just got the software installed and reflashed.
I have been looking at Randy's 13.5 TC base setting and it seems he is running an rpm range of ~4000 to ~12000?
So why is it that some of you guys are discovering that having a narrow rpm range like 4000~6000 is better for lowering lap times?
Has this got something to do with the gearing we are running?
Anyway I am running a 11.5 fixed endbell. If anyone would care to give me some base setups for a med sized track that wld be good.
Thanks and happy new year to all.
radwerx is offline   Reply With Quote
Old 01-02-2010, 04:44 AM   #9618
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
what did you end up doing to get it working
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-02-2010, 04:51 AM   #9619
hi...
i tried v203 today and was impressed with the difference...
i run an xray t2 009 TC with 2S... 10.5 redline and rs pro.
my v200 setup was:
12 boost
max turbo
0.7 delay
with temperature around 60^C
my v203 setup is
40 boost (4000-12000rpm ramp)
max turbo
0.5 delay
with temperature around 55^C
overall the car is faster...pulls harder and tops out higher...
the track is biggish.. 55Metres straight...
fdr is 5.29 on rubber asphalt.
would you change anything?
g
gortan is offline   Reply With Quote
Old 01-02-2010, 05:00 AM   #9620
aussierevo's Avatar
Trader Rating: 14 (100%+)
Has anyone got a good setups for the RS and a 21.5T in a Tamiya F104pro.
I've got my software ready to go, but looking for a guide as to what timing and fdr/rollout you might run the esc with for a pan car.
any information is appreciated.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 01-02-2010, 05:08 AM   #9621
Senna Racing's Avatar
Was wondering if anyone could help
I have windows xp and have been trying to down load the emal
that Randy has sent me. With version 2.0
I previously had v200
But when I run the zip file it gives me ver.1.0
I have tried uninstalling the older version
and have gone to the tekin site to download all
the other software they recommend you have but I still
don't see any new features
Any ideas
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 01-02-2010, 05:15 AM   #9622
I think, some people are mixing the end/start rpm and boost as entwined functions, I don't think they are.
the start/end rpm, dictates when and how long an RPM range the added timing comes in. Boost comes in at a set throttle point and defined delay. So even if your end rpm is set high, once you hit full throttle, the timer counts the delay, then adds your boost.
I am thinking of using the end/start rpm as a way of altering the power curve of the motor, making it more linear with a wider rpm spread, and punchy by narrowing the rpm spread.
DA_cookie_monst is offline   Reply With Quote
Old 01-02-2010, 05:21 AM   #9623
razzor's Avatar
Thats how i am looking at it as well.
It makes sense hence why a few guys have found that Randy's base setup and Yang's setup both work well. Just needs to be tried back to back to notice how it differs.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-02-2010, 05:37 AM   #9624
rcterp's Avatar
Trader Rating: 35 (100%+)
I could be wrong but it depends what "boost" you're talking about. Timing boost is entwined with the RPMs. When you hit your low RPM the ESC starts to add timing boost; as RPMs increase so does the timing and maxes out at your max RPM.
Turbo boost is the one you're referencing that comes in at full throttle.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 01-02-2010, 07:00 AM   #9625
[QUOTE=radwerx;6794570]Hi everyone. Just got the software installed and reflashed.
Yang lai has been explaining this in detail. maybe he can help again.
windsor is offline   Reply With Quote
Old 01-02-2010, 07:25 AM   #9626
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
I had problems finding the correct link, until I reloaded the window. Once that was done, it took me to a registration page, and then the download link was emailed to me.
Any ideas
The Original SC10 4X4 Clutch Basket
Steve McGeorge
Mac The Knife is offline   Reply With Quote
Old 01-02-2010, 08:23 AM   #9627
I don't have a problem with that
I have been emailed the link and downloaded the zip file
But when I run it I just get what seems to be the older version
I'm running xp, is there a hidden file that I need to remove
like with vista?
Old 01-02-2010, 08:26 AM   #9628
LOW ET's Avatar
Trader Rating: 97 (100%+)
when you see the contents of the zip file, there's like four or five things in it, like setup, hotwire, etc... click on the hotwire icon in the zip file. that's what i had to do and i'm running windows xp.
LOW ET is offline   Reply With Quote
Old 01-02-2010, 08:27 AM   #9629
I used the link on the site and it worked fine.
I did have to register twice though, once for each computer.
AreCee is offline   Reply With Quote
Old 01-02-2010, 08:41 AM   #9630
Trader Rating: 198 (100%+)
I will agree. I believe the boost starts at the starting rpm and ends at the end rpm. So you can get a smooth increase in timing or an abrupt engagement.
When I was at a 3500 rpm start the car really kicked forward as I was really getting a boost. When I lowered the start rpm to 1500 the jump was not near noticeable.
This was in TC
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
