Old 01-01-2010, 08:14 PM   #9586
theisgroup's Avatar
Originally Posted by 2056dennis View Post
is this the setup you were talking about yang .
yes sir. that seams to work for the guys that I have been working with. both off and on road. we did move the delay down to .3 for some, but some are running .5 all on the same track. I think it just depends on the racer and when he gets on throttle. the guys that are on throttle as soon as they hit apex are running a little longer delay, but the one that don't get back on throttle until they complete the turn are running shorter delay. I am looking for turbo to start kicking in 1/3 down the track and it should pull to 2/3-3/4 of the length of the longest straight.
my theory is to use timing boost for infield speed and turbo for straight line speed. i want the timing to pull all the way through the longest corner. just because you hit the end rpm does not mean the motor is not still pulling. i really think that what this narrow band rpm is doing is it ramps the timing pretty fast and it keeps the rpm low. since timing reduces torque, it is almost like a CVT transmition. it keep the motor at the idea RPM through the corner. and then once the motor spools up after the corner it want to catch up to the timing. this basically give you a real strong infield
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-01-2010, 08:15 PM   #9587
pakk's Avatar
Trader Rating: 79 (100%+)
I dropped .5sec off my fast lap and all I did was use the setting that randy posted.
I ran the posted settings in a 12th scale 1s 17.5 ballistic with 89mm run out(most people run around 100) and the timing set to how ever many degerees the second to the lowest line is. I think it is suppose to be about 10*.
Insane software here.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 01-01-2010, 08:23 PM   #9588
Trader Rating: 5 (86%+)
Default ESC setups
does anyone have an idea of where the wgt 13.5 and 1/12 13.5 should be at...my track is pretty small ...70 x 30...i know no one can set it up for me. i know we all drive differently...i just need someone to give me an idea..i want it to be as fast as possible...running duo 2 in wgt and orion in 1/12...please give me some input..thanks in advance
obi wun is offline   Reply With Quote
Old 01-01-2010, 08:25 PM   #9589
gsxr0311's Avatar
Trader Rating: 19 (100%+)
which posted posted settings are you talking about ?
gsxr0311 is offline   Reply With Quote
Old 01-01-2010, 08:30 PM   #9590
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
damn...10+ pages in 24 hours Gota love Tekin. with some of the good feedback i can't wait to hit the track tomorrow.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-01-2010, 08:39 PM   #9591
oeoeo327's Avatar
Trader Rating: 74 (100%+)
+1 - Tomorrow can't get here fast enough!!!
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-01-2010, 09:23 PM   #9592
Trader Rating: 198 (100%+)
Originally Posted by Danny-b23 View Post
If anyone was looking for small track settings, I can't help you at this point. I was running a Novak SS 17.5, and the motor just wants to bite back at whatever timing I throw at it. I did break the track record with our new configuration, but the car still didn't seem quite as fast as it could of been.
Here's what I ended the day off at:
35 Drag Brake
75 Brake Strength
Profile 3
40 Timing Boost
Max Turbo
0.1 Boost Delay
Start RPM ~4800
End RPM ~14000
6.9 FDR
I do not think you need any turbo for that size track at all. My home track is only 65 feet long and turbo is just no play. It just adds unwanted heat to the motor. Your end rpm seems a little high also. I would not think your turbo would even kick in with that high of an end rpm.
Randy posted a 13.5 setup a few pages back. I would start by looking at it and go from there. He was on a larger track with a very low turbo setting. With the amount of power this new software makes you will not be using the full range of all the settings even though you can set them up.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 01-01-2010, 09:42 PM   #9593
Trader Rating: 38 (100%+)
Ive seen FDRs for 17.5 from 5.2 to 6.9 with the new software. Seems like a big difference. Which is correct?
or8ital is offline   Reply With Quote
Old 01-01-2010, 09:54 PM   #9594
Twin 1 Kevin's Avatar
Is anyone having issues with 1 cell lipo with 13.5 motor. A couple of us had our cars cutting out for a second or two with this software. I'm also using a novak booster and spektrum receiver with module. When it happens the transponder light goes out...everything dies and the booster goes out. The red light starts to flash (on the booster) a couple of times then everything powers back up again. Even happened when I bench test it. If I role the throttle on, after a couple time everything just quits. It will power back up but only after a second or two. When it happens on the track your helpless until it decides to power back up again. Some had issues other didn't. I'm thinking it could be a bad booster.
any thoughts???
Duo 2 motor
Twin 1 Kevin is offline   Reply With Quote
Old 01-01-2010, 10:02 PM   #9595
Scottmisfits's Avatar
With 13.5 I was running a 7.02 and a 7.4 FDR. I used Randy's TC 13.5 sheet as a base and tried to fine tune a bit. I turned turbo down and timing down a bit and ran slightly lower gearing than he had on his sheet but I liked it. It was blistering fast down the straight.
Scottmisfits is offline   Reply With Quote
Old 01-01-2010, 10:03 PM   #9596
RobS's Avatar
any thoughts???
Duo 2 motor
Try running the old 200 version and see if it does it. If so, its the booster.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 01-01-2010, 10:06 PM   #9597
first qualifer v203...did it
second qualifer v200...fine
main v203 with adjustments....did it again
Anything else???
Old 01-01-2010, 10:10 PM   #9598
RobS's Avatar
Anything else???
I'll let you know after tomorrow when I run it all for the first time! See ya at the track...
Rob Say
Old 01-01-2010, 10:12 PM   #9599
theisgroup's Avatar
Anything else???
yes, I have heard a couple people having that problem in 1 cell. a rx pack fix both issues I have heard about. also it maybe your setup. I would think that if your setup require a lot of torque or too much timing too soon, then you are asking the motor to do something it can't so it draw soo many amps that your booster is shutting down
yang lai
Old 01-01-2010, 10:17 PM   #9600
not racing tomorrow...I'll be out at the track to pick up some stuff. I'm racing a lot in the States and I need to get this issue figured out.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
