Old 01-01-2010, 07:57 AM   #9481
rayhoe1's Avatar
ok did i miss the link for 1-1-10?
rayhoe1 is offline   Reply With Quote
Old 01-01-2010, 08:02 AM   #9482
trerc's Avatar
Trader Rating: 89 (100%+)
Tekin passed it out early, it's on their site.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-01-2010, 08:09 AM   #9483
as you don't see the V4 Vegas 2.0 klik refresh on the site.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-01-2010, 08:24 AM   #9484
cheehtae's Avatar
Trader Rating: 15 (100%+)
need help, can't seem to download it. Everytime I would click on the link on my e-,ail it would take me to tekin and software is not there , it would just say to register to get the updated version. I did uninstall the older version.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 01-01-2010, 08:26 AM   #9485
rayhoe1's Avatar
ok got the new one but just wont load in speedo gos to 200?be nice guys just need alittle help
Old 01-01-2010, 08:26 AM   #9486
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by mike ivy View Post
Anyone have any 1/12th 13.5 1s 3.7v lipo setups you can pm me I race ona 100x40 track carpet. any help would be appreciated
Originally Posted by oeoeo327 View Post
Kenny Lambert's setup is probably pretty close,but plan to adjust the rollout a bit - see page 626 for the setups Randy has posted...
I see lots of smoke in both your futures... I'll be trying in my WGT this weekend for the first time.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 01-01-2010, 08:31 AM   #9487
Originally Posted by jeppesen View Post
Hi guys.
I've just ordered a RS pro combo set with a 17.5 red-line and the hotwire cable, and i am very excited so see the performance, im using a GM 120 at the moment
I'm new with tekin, så any help with gearing and set-up for the speedo would be perfekt, im running 1/10 touring rubber on a medium size track.
Thanks.
Hi jeppesen
has morfars begun importing Tekin?
basse
MartinBasse is offline   Reply With Quote
Old 01-01-2010, 08:31 AM   #9488
bkspeedo's Avatar
Originally Posted by obi wun View Post
how much timing is in each notch of a duo 2..i am thinking of going up to 10 degrees on the motor...anyone have a suggestion...the track is 70 x 30...the temps on the car are 101....does anyone have anything for wgt...i am in left field with this thing...help please...same track size as above...
Each white tick mark is 5deg on a Duo2
Each hole is 10deg on a Duo1
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 01-01-2010, 08:32 AM   #9489
uninstall your current version,then install v 203
grouchy is offline   Reply With Quote
Old 01-01-2010, 08:41 AM   #9490
delete also the hidden files.
http://www.youtube.com/watch?v=tTp3tUL9u8Y
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 01-01-2010, 08:53 AM   #9491
Tim Stamper's Avatar
Duo2 is listed as a +40/-40 motor. Would make the marks 10 degrees.
Not that it matters, but didnt want to confuse.
Tim
This space for rent
Tim Stamper is offline   Reply With Quote
Old 01-01-2010, 09:19 AM   #9492
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
from the looks of everything I've read on gearing it seems like if you run both 13.5/17.5 starting with the 13.5 gearing on 17.5 and 10.5 gearing on a 13.5.that seems to be the pattern of gearing down 4-8 teeth
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-01-2010, 09:29 AM   #9493
bkspeedo's Avatar
Measure the C-C distance between the 1 and 3 holes on a duo1 and then measure the distance between the center mark and outer mark of a Duo2. I think you'll find there the same which is 20deg this equals 5deg per mark.
If the duo2 documentation may say +/- 40deg, I think they made a mistake, I'm sure they meant 40deg total.
The Novak ballistic is similar to the Duo2 in timing adjustment and markings. There documentation claims +\- 20deg.
Brent Klingforth
5280 Raceway
Old 01-01-2010, 09:34 AM   #9494
B4james's Avatar
Simple to fix, just copy the whole link and paste it in a new window and hit enter, it will then begin to download. Dont forget to remove any < or > off of the link when you cut or paste it.
What your email client is doing is leaving off the last part of the link, when you click on it it will do what you are experiencing.
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 01-01-2010, 09:43 AM   #9495
MaxSp97's Avatar
Here is the Duo2 documentation from Epic.
The DUO 2 ROAR spec motors have been updated
for increased performance. They still feature the ability
to work with older sensorless speed controls and
the newest sensored speed controls.
Neo 2 magnets., Heavy duty ball bearings. 3 screw
adjustable infinite timing. + 40 / -40
Meets ROAR/IFMAR specs
Team EPIC is the first brushless motor manufacturer to offer a dyno tested brushless motor. What this means for the dealer and racer is that every Duo2 motor that leaves our factory has been tested and meets performance specs. This also gives the racer data from motor to motor to better judge gearing as we all know by now that brushless motors need as much care as brushed motors to keep them from melting down.
All Duo 2 motors are tested with the maximum timing setting which insures that the specs from motor to motor are comparable. Doing the testing this way takes any adjustable timing differences out of the equation.
The results for each motor are right on the box, (rpm, watts, efficiency & torque).
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
