Tekin RS ESC sensored
#9466
how much timing is in each notch of a duo 2..i am thinking of going up to 10 degrees on the motor...anyone have a suggestion...the track is 70 x 30...the temps on the car are 101....does anyone have anything for wgt...i am in left field with this thing...help please...same track size as above...
#9467
1/12 roll out 10.5 Rs-Pro Vegas software
#9468
We've been running 12th scale 10.5 single cell LiPo on a 30m x 12m track with a 67mm rollout using Vegas. That's with 0 on the motor, 10-20 on timing boost depending on the driver, max turbo boost at 0.5 seconds. Boost definitely kicks in!
Maybe its your transmitter setup, but I'm sure you'll have already read all the posts on that.
Nice shells by the way.
Trev
Trev
#9469
OBI
Each notch = 10 degree.
Check this one out, it's from Randy.
http://www.rctech.net/forum/6789190-post9381.html
I would be interested as well what timing the duo2 comes with. In the document that someone wrote privatly to explain the RS and hotwire he stated that maximum timing possible on the motor would be 10 degrees and that most of the adjustments would be less then zero. I don't care about the maximimum timing the motor can get but just want to know what timing the motor has as a factory setting so i know how to adjust the rs and also what setting would be considerd zero.
#9471
hello all
first all a happy new year
tis tread is on fire
i wil thank team TEKIN for the great speedo and software.
was planing to buy a ae speedo .
buth with the 203 update i wil buy a second tekin . now a rs pro
thanks again to randy and team tekin.
one question is do i stil need to adapt the endpoint after setup to say 110%
greeting marcel pinkster
from assen the netherlands
#9473
Happy New year for all Tekin´s Users ¡¡¡ , now i feel the power this weekend go for testing new software, thanks Team tekin for your work.
Greetings, Luis C.
Greetings, Luis C.
#9474
Hi guys.
I've just ordered a RS pro combo set with a 17.5 red-line and the hotwire cable, and i am very excited so see the performance, im using a GM 120 at the moment
I'm new with tekin, så any help with gearing and set-up for the speedo would be perfekt, im running 1/10 touring rubber on a medium size track.
Thanks.
Thanks.
#9475
Hi guys.
Thanks.
Thanks.
#9476
#9478
i take it if i run 6.5 on duel mode i dont have to worry about the new features ?.
can somebody confirm this please.
#9480
thanks smoke !
