Old 12-31-2009, 10:15 PM   #9451
Originally Posted by VA_Racer View Post
Yes and I downloaded from the link in the email. I did update the esc and now I can't get anything out of it. well I do get 3 flashing lights on the speedo now.
Check that you have that the right motor is selected after I installed the new software, I did not notice it had changed to a brushed motor.
-=light=-
Gorden
light is offline   Reply With Quote
Old 12-31-2009, 10:20 PM   #9452
Trader Rating: 59 (100%+)
Send a message via AIM to todb
thanks for the new software. it worked great on the dl/install. saves the price of a new esc on each update. now i need another rs.
todb is offline   Reply With Quote
Old 12-31-2009, 10:28 PM   #9453
Trader Rating: 21 (100%+)
Originally Posted by light View Post
Check that you have the right motor selected after I installed I did not notice it had changed to a brushed motor.
-=light=-
I finally got it to work. Had to go to another pc. Thanks for the help guys.
VA_Racer is offline   Reply With Quote
Old 12-31-2009, 10:31 PM   #9454
theisgroup's Avatar
there are alot of ways to setup the speedo now with all the new setting. the last couple of weeks of testing, I have gone a different direction then most. what I have been doing is using timing boost to help the car get out of the corner faster. so I work on a combination of timing and gearing. i add 5 degrees each time until I find that the acceleration out of the corner feels soft. then I start to add more gear and see where I am. once I find a good combination of timing and gear, then I work on turbo. I use turbo mainly on the straight. it really is to raise your top speed. If there are several places on your track that you hit top speed, then you are just going to have to come up with a compromise or pick the longest straight. as far as start and end rpm i try to keep them between 1500 and 2500rpm difference. this is really because i find that any more does not get the car out of the corners any better then vegas 200. I start high in the rpm range of the motor and then work my way down 500rpm each time.
so for our "large" track, for 17.5 1/12th I ended up with the same roll out as my vegas 200 setup. I left the rpm range the default in the v203 and had 10 end bell timing and 45 software timing and 6 turbo at .4sec, ramp 2. this basically dropped my laptime .5sec a lap.
we now have a new layout. most of the guys were at the track all day and ran vegas 200 to get a good setup. then we loaded v203. in 13.5 tc. most found that they liked 10 motor timing, 50 software timing, turbo 8, .4sec delay, ramp 3 and rpm 2100-4900. motors were coming offf at 101-110 and most drop laptimes by .5 - .8 sec
i did try the larger span of start and end rpm, and really it felt softer then a narrow rpm range. i also find that anything less then .4 really does not do anything for turbo. it just ramps to early.
just fyi 17.5 is 2200Kv and 13.5 is 3300Kv
i am sure that the other setup yield just as good results
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 12-31-2009, 10:37 PM   #9455
theisgroup's Avatar
i think with 198 installed and either win7 or vista, you need to delete the hidden file.
when you install, if you run the batch file, it will do an uninstall before it does an install of the new version. also remember with win7 and vista, you need to run as an admin, so right click and select run as admin
a quirk i found. when you plug in your speedo and it need to be updated, you click the box to update your software. once you completed the install of v203 the software opens back up, but you can not click on the advance button. that is the only time I have found this to happen. if you close the software and open it back you are ok. or if you unplug you speedo and open it back, then you are good to go as well
yang lai
Old 12-31-2009, 10:50 PM   #9456
Team Tekin
TY@TEAMTEKIN's Avatar
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 12-31-2009, 10:55 PM   #9457
oze
How large is your large track?
oze is offline   Reply With Quote
Old 12-31-2009, 11:04 PM   #9458
Trader Rating: 68 (100%+)
Send a message via AIM to joey
about 105x60 ft..
=Joe Wright=
joey is offline   Reply With Quote
Old 12-31-2009, 11:08 PM   #9459
theisgroup's Avatar
the new layout is much more inline with the "average" size track. you can take a look at it http://www.mikeshobbyshop.com/tcmed.htm
i believe it is more like 90 x 50 now
yang lai
Old 12-31-2009, 11:09 PM   #9460
theisgroup's Avatar
Originally Posted by Randy_Pike View Post
Yes, the entire Tekin crew is here together celebrating! Happy Holidays everyone!
randy,
you should introduce us to Team Tekin.
yang lai
Old 12-31-2009, 11:25 PM   #9461
bukil's Avatar
Trader Rating: 39 (100%+)
This is money right here . I came up with the same conclusion after some testing earlier. Smaller discrepancy between the start rpm and end rpm yield faster laptimes.
I have about 10 -15 motor timing on my motor. Car was stupid fast. I had to increase my drag brake from 5 to ~20 to get the car to stop faster.
A few people at my track thought I was driving a mod car . Further testing will continue tomorrow .
bukil is offline   Reply With Quote
Old 12-31-2009, 11:48 PM   #9462
Trader Rating: 5 (86%+)
Default Duo 2
how much timing is in each notch of a duo 2..i am thinking of going up to 10 degrees on the motor...anyone have a suggestion...the track is 70 x 30...the temps on the car are 101....does anyone have anything for wgt...i am in left field with this thing...help please...same track size as above...
obi wun is offline   Reply With Quote
Old 01-01-2010, 12:04 AM   #9463
cyanyde's Avatar
Finally, something I've always wanted. Can't wait to try it against my Mamba Max Pro with CHEAT mode.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 01-01-2010, 12:21 AM   #9464
MaxSp97's Avatar
OBI
Each notch = 10 degree.
Check this one out, it's from Randy.
http://www.rctech.net/forum/6789190-post9381.html
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 01-01-2010, 12:38 AM   #9465
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Pat McCracken View Post
what if you have the novak ballistic 17.5 it come with 30 deg of timing in it
so u can't set the endbell at 0. can you still set the boost at 50 or 55
On the Novak Ballistic motors, you can get down to just 5' of timing on the endbell by turning it to the very edge of the label. They don't suggest turning it all the way down to zero.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
