Old 12-31-2009, 03:20 PM   #9316
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by razzor View Post
where about ?
I am still seeing Hotwire 3.25 listed on the tekin site.
If you go to the main page there is a graphic for Vegas 2.0. Click on it and it will take you there.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-31-2009, 03:23 PM   #9317
Originally Posted by SlowerOne View Post
Can someone (Randy?) give me a short explanation of what I should be doing with this new software? Feel like a bit of a fool, as everyone else seems to know, but I don't!
I'm running a Redline 10.5 on 1S LiPo in 12th. Currently set on zero motor timing, a high-ish ratio, 20 boost and 10 turbo on 0.7 sec. What settings do I need to sort out with this version, and how should I use the rpm range?
All help welcome! Thanks in advance.
PS - can we sort out a name for it?!!! Since it is Vegas2 on the link, and 4.0 on the file, could we use Vegas 2 as a suitable moniker? Vegas2, that sounds good...
Here's what it looks like so far from what I can see playing around with the settings.
The low RPM is where the boost timing starts to kick in. It ramps up to the max boost setting at the max rpm setting. It looks like there is a ton more boost timing available so it's pretty easy to over time things. You'll have to gear down a ton with the higher settings. Check your temps often when you're trying new settings.
Turbo looks like it works exactly the same as before except they've added the turbo ramp setting. Turbo ramp controls how fast the turbo hits once you hit full throttle. 1 ramps the turbo in slower and 3 is faster.
In the end, it's the same story. Start low on the timing and work your way up. We'll know more as people start to fingure out the best starting settings for each class.
Fred_B is offline   Reply With Quote
Old 12-31-2009, 03:24 PM   #9318
Originally Posted by fatbear View Post
Now what we need is for someone to come up with a program or excel spreadsheet that we can use to help us with setting up the new software.
Things like enter your track lenght and straight length and it gives you a starting point for rpm etc.
That sounds like a good idea,I have just loaded the new v203 and have been looking at it on my laptop. I have no idea at all what settings I should use or how to understand it. Im really confused I never got the chance to run v200 as I have just bought my rs pro but this new v203 has just blown my mind !!
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 12-31-2009, 03:24 PM   #9319
caltek1's Avatar
Trader Rating: 36 (100%+)
A big Kudos to KennyL for sharing and a thanks a heap to Team Tekin for the New Year present.
I was all set for testing until the rain god thought otherwise for today. I have used the settings slightly milder to what KennyL posted today.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 12-31-2009, 03:25 PM   #9320
Originally Posted by dodgeguy View Post
I am and the settings once I hit apply then current are not the same.
If you don't get the "settings saved" pop-up it's not saved. I've seen it take a couple of try's to get the buttons to work.
Old 12-31-2009, 03:27 PM   #9321
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default new version
so where can i get the new version and thanks for info
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 12-31-2009, 03:30 PM   #9322
LOW ET's Avatar
Trader Rating: 97 (100%+)
http://www.teamtekin.com/
middle of page, towards the top, click where it says smarter, smaller, faster.
LOW ET is offline   Reply With Quote
Old 12-31-2009, 03:30 PM   #9323
I had to restart Hotwire after I loaded it for the Advanced button to work. But everything works now.
Old 12-31-2009, 03:32 PM   #9324
Trader Rating: 21 (100%+)
Tekin site.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 12-31-2009, 03:34 PM   #9325
Agreed.
I assume ramp setting 3 is better for smaller/tighter tracks?
The one thing I'd like Tekin to chime in on is a suggested End RPM range for motors/track sizes.
Old 12-31-2009, 03:46 PM   #9326
2056dennis's Avatar
Default new version
Originally Posted by lidebt2 View Post
Tekin site.
so the new version is called v4
Old 12-31-2009, 03:46 PM   #9327
This is what I hate about Tekin.. They have great hardware andf they just release the software to make it world class. Now everybodies stumbling around trying to figure it out.
WHAT HAPPENED TO YOUR TEAM DRIVERS.
Isn't the point of giving it to them early is to let them test it and work out some profiles for the guys who pay full price for the product.
All we need are some starting points.
17.5 touring
13,5 touring
WGT
17.5 12
13.5 12
and some oval settings.
Come on guys, put the final piece in place and make this thing really rock. We shouldn't have to cruise through 20 pages on this forum and try to put something together.
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 12-31-2009, 03:47 PM   #9328
Originally Posted by PitNamedGordie View Post
Agreed.
That's what I would assume but I haven't had time to play with it on the track yet.
I'm going to start out by tuning in the boost and RPM range before I mess with the turbo at all. I only want the turbo to kick in on the straight anyway. Plus with the bigger timing setting for boost I might not need turbo at all.
Old 12-31-2009, 03:47 PM   #9329
Originally Posted by Kenny L View Post
You need to set end rpm range first
Start here
profile 5
boost 50
turbo 10
delay .1 adjust if more or less is needed on straight
ramp 3
end rpm 7000-6000 (7000 for longer tracks and 6000 for shorter)
start 2400-2500ish
make sure to temp 2 minutes in no matter what
Kenny,
It may help many of us gauge things off of our old setup from v200 if we had a comparison with how the boost/RPM relationship functioned in the old software? Can you give us general idea as to what RPM that came ON and at what RPM or TIME DELAY it used as the end point?
What type of layout scenarios would require the Boost StartUp to be below 2400? Any? What result would come from 1000RPM? Generate to much heat?
Thanks for your help!
Aaron
Dude, Go RRReally FFFast - When something gets in your way - Turrrnn
VRacing is offline   Reply With Quote
Old 12-31-2009, 03:49 PM   #9330
LOW ET's Avatar
nope, it's 203. the 4 is for hotwire version 4
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
