Old 12-30-2009, 12:28 PM   #9166
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally Posted by ottoman View Post
OK... finally thinking of going Tekin for the upcoming Novak... is the pro a advantage over the std RS for 13.5 touring car?
I believe all the programing options are the same... correct?
Very good decision to go TeamTekin.
The Pro and RS are both strong performers, the Pro has extra goodies(fets) to handle faster winds. Either is great for 13.5.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 12-30-2009, 12:57 PM   #9167
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I tried an RS and then an RS Pro back to back last night with a 13.5 in 4wd sedan on carpet. I was doing it to see if there was any difference in brakes. As I was testing I noticed no difference in power or in brakes; push or drag. Both were set up on hotwire with the exact same settings. Just an FYI.
Old 12-30-2009, 12:59 PM   #9168
-showtime-'s Avatar
Originally Posted by schreff View Post
IThe LRP motors, however... do NOT turn the timing up a lot with this software. You WILL blow them up. I've seen one last as little as 3 laps with the new stuff where as a DUO with the same speedo settings worked fine.
I see Goat's trying out the new software
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 12-30-2009, 01:17 PM   #9169
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
wasn't me this time......
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 12-30-2009, 01:59 PM   #9170
Skiddins's Avatar
I will say this guys... please beware of your timing settings once you get 2.03.
DUO1, DUO2, Nemesis, Novak, and Speed Passion seem to be able to handle a good amount of timing without melting them down.
Just an FYI...
Was that the latest version of the LRP's, the X12's? and was this with or without added timing on the motors?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-30-2009, 02:27 PM   #9171
joeymdz's Avatar
Send a message via MSN to joeymdz
I disagree and I’ll keep it short:
on my wgt/13.5 1s I ran back to back with exact profiles w/ battery and I was .3-.5 slower with the rs vs. the pro. (I even ran the rs a couple more times to make sure it wasn’t me but the times told the truth plus my motor temps were +11-15 higher. *this was on a 100x60 indoor high bite carpet track
I was a big believer that the difference wouldn’t not be noticeable with the 13.5 1s class and had argued my point.. but I take it all back!!!
joey
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 12-30-2009, 02:32 PM   #9172
schreff's Avatar
Send a message via AIM to schreff
Skiddins
This was with an X12... the latest and greatest. The timing was at the Neutral point on the motor. Even with 1.99 or 2.00... the LRPs HATE the Timing Advance. They get hot immediately when you throw timing at them. Heck, with 1.99, I had a 13.5 get up to 180* after 2 laps... but they were some mighty fast laps.
2.03 is a new ball game, but a VERY good one.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 12-30-2009, 02:45 PM   #9173
What is "turbo Ramp"?
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 12-30-2009, 02:54 PM   #9174
Skitee's Avatar
It sounds more like timing ramp than turbo ramp from what I've read so far, so on some tracks with the right timing setup you may not even need turbo.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 12-30-2009, 03:10 PM   #9175
Thistle's Avatar
Send a message via MSN to Thistle
I tried a dedicated receiver pack, and the ESC responded perfectly, so I now have 2 AAA's wired in. (6.1 volts)
I will be trying it on the track tonight, and I'll let you all know how it goes.
Xray | Ofna | KO Propo | Tekin | Clockwork Racing Engines
Thistle is offline   Reply With Quote
Old 12-30-2009, 03:13 PM   #9176
The X12 can on the SPX only used till mode 6. It will els be to hot.
With the Tekin you just set the Boost lower and you fly with it.
tread it like a MOD motor. Than is this motor fast.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-30-2009, 03:20 PM   #9177
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
did you see a drop in the # of led's flashing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-30-2009, 03:23 PM   #9178
hi
i read some where the rs could not be used for 4wd off-road is this true? i only will be running 9.5 turns.
martin
MartinBasse is offline   Reply With Quote
Old 12-30-2009, 03:23 PM   #9179
Why not stick with the receiver pack? Should be smaller and lighter than 2 AAA batteries.
Old 12-30-2009, 03:29 PM   #9180
Originally Posted by MartinBasse View Post
hi
i read some where to rs could not be used for 4wd off-road is this true? i only will be running 9.5 turns.
martin
Why not?
It can handle up to a 5T so a 9,5 must be possible.
Maybe smart to ad a cap and a fan.
It will be harder to find a good setup with the V203 with the RPM settings or can you keep it for 1 motor on the same settings on all the track and you only change the Boost and the Turbo?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
