Old 09-01-2008, 09:33 PM   #901
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Stealth_RT View Post
Maybe this has been asked already (heck, maybe I asked this alread, and forgot I did), but how low can the LVC be set on the RS/RS Pro. Need a speedo to run 1/12th with a 13.5 and SMC's new 1S lipo. With or without a receiver pack, too.
It can be set to canned values for 1S, 2S, and 3S lipos or as low as you want it to go in 0.1V increments I believe (with Hotwire). I'll fire it up right now to check.
EDIT: The increments aren't exactly 0.1V, but they're small. However, the lowest it'll go is 3.0V, which is perfect for 1S lipo anyway, but I would think it would be easy for them to let you crank it lower if there were a good reason. I don't know what that reason would be though.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 09-02-2008, 05:51 AM   #902
The only reason to go below 3v is with Lithium Ion cells. There are new cells out that are about sub C sized and about 4000 mAh at single cell voltage. Might be a good alternative for the t-plate guys but LiPo has more capacity at the moment.
Fred_B is offline   Reply With Quote
Old 09-02-2008, 06:45 AM   #903
Hi all,
I've just started to run RS Pro insted of my LRP speedo and need some help to figure out my setup.
Running 5 cell MOD 4,5T (LRP with factory timing) on a large track.
Used to run LRP ESC throtle profile 4 with 6,2 FDR. This gave me enogh power end runtime.
Started with RS Pro throtle profile 5 and FDR of 6,2 and no top speed (10km/h less on a back straight) When changed FDR to 5,9 I haven't noticed any increase in top speed, only in heat (cells, motor and ESC).
i have Hotwire so any profile can be adjusted.
Thanks a lot.
Z
_____________________________________________
Tamiya TRF 417, Fantom Racing
rcpoint is offline   Reply With Quote
Old 09-02-2008, 09:05 AM   #904
Originally Posted by rcpoint View Post
Hi all,
Thanks a lot.
Z
What is your timing setting in the Hotwire? That's what will make the big difference here. The throttle profile doesn't affect your top speed, just the manner in which you accelerate to it. Also, what is your current limit set to?
Pete Waydo
Old 09-02-2008, 09:25 AM   #905
Hi all,
Thanks a lot.
Z
Are your running in hybrid mode? Please provide more info
monstercol is offline   Reply With Quote
Old 09-02-2008, 10:10 AM   #906
Timing in Hotwire is set to 0 and limit is set to 28 (still did't play with Hotwire). I'm running hybrid (i think, because sensored only is unchecked)
Thanks for all your help guys.
Old 09-02-2008, 10:41 AM   #907
You'll need to start adding timng to get that straightaway speed back. Try gearing back to the 6.2 ratio and add timing to get your straightaway speed back.
For mod gearing in sedan, I usually start with the lowest timing setting to get the gearing close. Then add timing to get the straightaway speed that I need (without overheating).
Just like any other system, you have to play with both the timing and gearing to get the balance that you need for each track.
In your case, you might end up increasing the current limiter if it's not launching off the corners well. Or just turn it off if there's plenty of bite.
Old 09-02-2008, 03:37 PM   #908
TRF415boy's Avatar
TRy 80% timing. You might need a fan on the speedo as well.
TRF415boy is offline   Reply With Quote
Old 09-02-2008, 04:30 PM   #909
m3ndo5a's Avatar
Is there a launch mode for starting. I know other ESC's you would hold the brake throttle for like 3 sec and its activated. I could not seem to get off the line quick enough on both my RS and RS Pro......I tried setting the throttle position as high as it can go and turn the current limiter off. It just rolled off to a quick accelerate afterward with a 13.5 RL and the 21.5 RL launch much better with the RS ESC.
m3ndo5a is offline   Reply With Quote
Old 09-02-2008, 05:09 PM   #910
Buckyaga's Avatar
does it seem to cog when you take off?
I had the problem with the R1, but as soon as I went sensored, it felt like a brushed motor on the launch, just with more power.
if you are running a RS, make sure the sensor plug is all the way in. If its not, it will fail back to sensorless and cog off the start.
Factory RC
4WheelMod 4 LIFE
Buckyaga is offline   Reply With Quote
Old 09-02-2008, 05:26 PM   #911
m3ndo5a's Avatar
It seem like the sensor wires that came with the Red line motors are too big for the harness on the RS/RS Pro (they do not go all the wat down into the slots, so I used the LRP sensor wires which goes all the way down....(I wondered). Normally I would get a squill from the Diff on a launch or just pulling the trigger at low speeds with the other ESC's but not with these, so I am hoping that wiring might be the case.....It would be great if these RS/RS pro ESC's lit another color like amber when the mode are different...that could be an easy way to determine the wiring are doing its part.
But than again could it be the motors do not have the same punch as a SP or Novak because they feel Super Linear like an Orion. I guess I will kick the timing back (from stock setting) and just gear it alittle more.
Old 09-02-2008, 05:49 PM   #912
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The sensor harness can be pushed into the slot both ways. Make sure you have the alignment tabs positioned properly.
If you have a hotwire try running higher timing for more top end. If you want more timing overall from Dual mode, run sensored only with the maximum motor timing. However this only sees much of a benefit with 13.5 motors and higher winds like the 17.5,etc.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-02-2008, 05:51 PM   #913
Buckyaga's Avatar
I would suggest trying the sensor wire that came with the motor to be sure, but it does sound like its motor cog from sensorless launches.
as for punch, I can pull wheelies on the street with slicks on my B44 with a Redline 7.5, I don't think the motors lack bottom end
Factory RC
4WheelMod 4 LIFE
Old 09-02-2008, 09:09 PM   #914
bkspeedo's Avatar
Does anyone on this thread know if there where RS ESC's used by drivers in the A mains at IIC this year?
Also any comments on comparison of the RS to Speedpassion, LRP, Novak in feel, top end speed, corning speed, etc.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-02-2008, 09:42 PM   #915
Team Tekin
Randy_Pike's Avatar
Donny Lia, Jeff Cuffs, Mark Smyka all made the A mains in different classes.
Donny took the 1/12 scale 17.5 win with an RS. Mark Smyka won the GT class with his as well.
As always Jeff made the podium and was in his A's as well.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
