Old 12-24-2009, 08:43 AM   #8896
Trader Rating: 16 (100%+)
Originally Posted by obi wun View Post
i need help...i have my tekin rs in my wgt and it is pretty quick the first 6 to 8 laps...i have a ea duo 2, tekin, 82.90 rollout, and an intellect 40 c battery.. the track is 70 x 35...when i begin a run the car is a bullet...9.1, 9.2, after 6 to 8 laps...all i can get is 9.5, 9.6, 9.7...what could be the problem...someone anyone let me know...is it gearing, setup, or what...the motor does not get hot..there is not timing in the motor...the esc setup is as follows
turbo boost...max
timing boost...3
throttle profile...4
drag brake ...0
push....50
delay.... .5
Try checking the motor bearings, diff bearings etc, diffs, and other areas that might cause drag. It's just an idea but if it isn't getting hot it sounds like your fighting a drag issue when the bearings get hot after being under load.
My experience with Motor dynos etc, I would get way more acceleration out of a car working on the bearings rather than the small tweaks on the motor.
Just a thought that may have been overlooked.
www.TheRcShack.com
www.TeamXray.com
Spdjunky is offline   Reply With Quote
Old 12-24-2009, 08:46 AM   #8897
turbo boost...max
timing boost...3
drag brake ...0
push....50
delay.... .5
Battery might be coming off peak power and dropping fast also. Check to see if cells are balanced good. Check voltage just after 6 laps and recheck voltage a few laps later.
www.TheRcShack.com
www.TeamXray.com
Old 12-24-2009, 08:49 AM   #8898
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rosko View Post
when using this speedo what changes were made on the speedo or timing setting using a 17.5 ballistic and trinity duo
I usually run the Ballistic 17.5, but tested a Duo1 with the same speedo settings. The Duo1 was upwards of 2/10s faster with the same settings and FDR, and could also carry another tooth on the pinion for a solid 2/10s gain.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 12-24-2009, 11:29 AM   #8899
1M
1M's Avatar
Trader Rating: 35 (100%+)
Will the new software be in our mail boxes in the morning?
Bob
1M is offline   Reply With Quote
Old 12-24-2009, 11:34 AM   #8900
Bob
I don't think so.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-24-2009, 11:42 AM   #8901
Regional Moderator
CarbonJoe's Avatar
Us "regular" drivers want our "Vegas 2.0" from Santa, or at least Randy. Team drivers have had it for about a week already.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-24-2009, 11:49 AM   #8902
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
that would be cool if they had as a christmas gift,but since i'm on the east coast that means it christmas before everyone else
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-24-2009, 11:50 AM   #8903
I have just bought my rs pro and installed the V200 software sent to me by Randy but I have not been able to run my new speedy yet. And there is talk of new software !!!!
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 12-24-2009, 12:49 PM   #8904
STLNLST's Avatar
Trader Rating: 21 (100%+)
The one good thing is.......Randy can send you the upgrade just like he did the 200 software. Go run the 200 and get a feel for it so that when the upgrade is out for everyone you can feel any differences
STLNLST is offline   Reply With Quote
Old 12-24-2009, 12:55 PM   #8905
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default upgrade
so what will the new upgrade give us
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 12-24-2009, 12:59 PM   #8906
STLNLST's Avatar
Less time to post........
Old 12-24-2009, 01:19 PM   #8907
Just a bit info please.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 12-24-2009, 01:20 PM   #8908
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
hoping some thing soon novak race is coming up for me and could use a little extra ponnies under the body for this race. the v200 version is very very good but we can always use a little more!!! correct??? thanks tekin. jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 12-24-2009, 02:15 PM   #8909
Default RS Setting query PUSH
Its been mentioned to me about using push .
I race 1/12th pan car(Speedmerchant) i Primarily race 10.5 . Lipo 1S In the Uk push setting seems to be always off.
It has been explained to me as setting 90 is like having 10 clicks forward on throttle. It helps roll round corners faster . Does it mean when on the start line you have to excert brake before you roll off.
Does any one else use push and if so what setting and too what effect does it have on your run.
TIA
tellan is offline   Reply With Quote
Old 12-24-2009, 02:59 PM   #8910
Trader Rating: 5 (86%+)
Default losing power update
i went to a lower rollout 72..tried a new battery, new motor, receiver pack...and still have the same problems..the car is crazy fast in the beginning and falls way off within 5 or 6 laps is am running aduo 2 motor timing on zero
timing boost 3
turbo boost max
throttle profile 4
no drag brake...
could my capacitor be bad
the only thing left to replace is the speed control and capacitor...someone give me some insight..
obi wun is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
