Old 12-21-2009, 10:06 AM   #8836
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Can't seem to update my RS Pro....
Downloaded this file:
Originally Posted by 20 SMOKE View Post
Then I uninstalled the hotwire software i downloaded from the Tekin website before installing the version in the zip file downloaded.
After installing it, hooked up the ESC and hotwire to the PC... after the software loads a pop-up comes out saying "Some of the user values are outside the expected range! Your ESC may not be compatible with this version of the Hotwire."
When i click on "View Versions", the list only goes up to "198"... no "200".
Anything I'm doing wrong?
Thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-21-2009, 10:15 AM   #8837
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by oeoeo327 View Post
I was at a race recently, and noticed that I had a problem with the car running backwards after hitting a board. Eventually, the car would proceed in the proper direction after a few seconds, but not before travelling backwards for a second. The sensor cable was replaced twice, but the problem persists. Reverse has been disabled, since the car isn't used for anything but racing. Has anyone observed the same behavior (and more importantly, figured out what causes this to happen)?
Joe was having some weird stuff with his setup and i found the sensor pins on the bell were loose..it looked good with the leds until i wigled the sensor cable.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 12-21-2009, 10:16 AM   #8838
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
that is still the 198,double check that you un install the old first before you do the 200
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-21-2009, 10:48 AM   #8839
Thanks!
You forgot to remove the hidden files.Here is a you tube video of randy explaining how to uninstall the files.
http://www.youtube.com/watch?v=tTp3tUL9u8Y
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-21-2009, 11:16 AM   #8840
oeoeo327's Avatar
Trader Rating: 74 (100%+)
I have a feeling it's a problem with the endbell, as the motor I'm using has caused a few problems in the past. I tried the "wiggle test", and everything seemed to check out OK. I'll know for sure after the next race, since I have another 13.5 to test with.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 12-21-2009, 11:23 AM   #8841
I have finally bought an RS Pro and the hotwire, both will arrive tomorrow. In the mean time is there any thing I can download and install ready for there arrival.
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 12-21-2009, 12:06 PM   #8842
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by tellan View Post
Just obtained a 10.5 and 17.5 duo 2 motors. Looking for rollout and Settings for V200 .
Running 1/12th in doors carpet track. Large.
Much appreciated in advance
17.5
tp-3
0 motor timing
25 esc timing
max turbo
.8 delay
sensored
1 cell box checked
93 mm rollout
Old 12-21-2009, 12:08 PM   #8843
Yes this
http://redirectingat.com/?id=42X1295...Hotwire200.zip
after that plug in the hotwire and your ready to update your speedo.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 12-21-2009, 12:12 PM   #8844
nitrobeast's Avatar
Sounds good. If u need help you know where to find me
Rui Goncalves
Old 12-21-2009, 02:41 PM   #8845
vazzo's Avatar
Trader Rating: 100 (100%+)
Anyone running the rs pro with the duo 17.5 red endbell motor? What settings have you found work well?
Cheers
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 12-21-2009, 04:53 PM   #8846
20 SMOKE's Avatar
Cheers
around 10 on the motor 15-20 on the boost geared med/small track 5.0-5.2 fdr
Jamie W
Old 12-21-2009, 05:05 PM   #8847
oeoeo327's Avatar
+1 if you're running a first generation Duo, but will get you in the ballpark for Duo 1/Duo 2 motors. Might gear to gear a few teeth shorter on the Duo 2 for best performance.
Old 12-21-2009, 05:46 PM   #8848
Danny-b23's Avatar
With upgrading from 200 to "Vegas" 200, is there still hidden files that need to be removed?
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 12-21-2009, 06:22 PM   #8849
20 SMOKE's Avatar
its a vista thing
Jamie W
Old 12-21-2009, 06:25 PM   #8850
VooDooPH's Avatar
This is great! Thanks for this... now v200 is up and running. Can't wait to try the car out on the track.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
