Tekin RS ESC sensored
#8821
Hi Everyone,
I have been reading this thread for a while, I use a speedpasion GT2 at the moment but I want to up grade. The RS pro is on my radar for 13.5 and 10.5 touring car racing. I have been racing for around 6 years now but I like most people I race with are really put off the likes of the RS esc and GM etc because they are so complicated to setup and programme. I would really like to buy on RS but iam holding back because of this. Now to the point, if some one was to publish either on here or on the Tekin website a step by step guide from opening the box to installing the hotwire software and programming including all the confusing stuff about about windows xp/vista etc then I would buy one straight away.
I know all the info is prob already in this thread some where but a step by step guide for muppets like me would be a big help. Just a thought
It's really not as difficult as it first appears.
#8822
Uninstall whatever you downloaded from the website and download the version posted 3 posts before yours.
Probably what's going on is that your RS has a newer version software than your hotwire software has.
Once you get V200 downloaded, update the firmware on your RS to 200 and you'll have all the current adjustments.
#8823
It's hart to wait when you now that the new update will be fast.
#8826
#8827
Possible problem with sensor port on ESC???
I was at a race recently, and noticed that I had a problem with the car running backwards after hitting a board. Eventually, the car would proceed in the proper direction after a few seconds, but not before travelling backwards for a second. The sensor cable was replaced twice, but the problem persists. Reverse has been disabled, since the car isn't used for anything but racing. Has anyone observed the same behavior (and more importantly, figured out what causes this to happen)?
#8828
Seriously. You have no other electrical glitches with the motor? Sounds like you may have a motor sensor issue. Have you tried a different motor in the car with the same result?
#8829
I was thinking the same thing (motor sensor/endbell), since this motor has been giving me issues on an intermittent basis. I haven't tried another motor yet (too busy with snow removal after the storm that hit the Northeastern US last night, LOL), but I'll try another motor and see if the issue is resolved.
#8830
You're right - I walked right into that one... Maybe I've been hitting hard enough to unlock the hidden "retreat to my pit table" mode.
#8831
Checked the 3 LEDs for proper sensor operation, and everything checked out fine with the 3 different cables that were used for troubleshooting. I'm hoping the issue isn't with the ESC, but I'll check the system using another motor and see if the problem clears up.
#8832
#8833
One thing I did notice while checking the sensors using the method mentioned by reenmachine a few posts back - one of the sensor lights is a little dimmer than the other two. Maybe it's my eyes or my imagination, but I'm wondering if one of the sensors isn't being read properly...
#8835
Tekin RS in 1/12th with DUO 2 motors
Just obtained a 10.5 and 17.5 duo 2 motors. Looking for rollout and Settings for V200 .
Running 1/12th in doors carpet track. Large.
Much appreciated in advance
