Old 12-09-2009, 09:15 PM   #8506
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
vegas
http://redirectingat.com/?id=42X1295...Hotwire200.zip
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-09-2009, 09:17 PM   #8507
RC-ProSpeed's Avatar
Randy.. could you provide any info regarding if Tekin is working on a software upgrade for the RS so we can level the racing field against the AE Black Diamond?
See my signature... got Turbo, now I need NOS
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 12-09-2009, 09:25 PM   #8508
radio_car_racer's Avatar
Rollout MMPR
ballpark figure for Tekin 17.5BL and 2s lipo in mm please?
radio_car_racer is offline   Reply With Quote
Old 12-10-2009, 07:04 AM   #8509
Senna Racing's Avatar
Originally Posted by mikky32 View Post
I gear my 10,5T even higher than 6.0. I have now my LRP on 7,6FDR wile the SPX drivers with the same motor are around the 6,7 or even heavier LOL
ha mikky
long time since i have asked for your assistance but i have just started running 10.5 as of last sunday
i was using rs and redline 10.5 with a 79 27 which is 6.01fdr motor was hot and speedy shut down in second final
your thoughts
thanks in advance
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 12-10-2009, 07:22 AM   #8510
Originally Posted by radio_car_racer View Post
Rollout MMPR
dont know if this helps but i have been running my 416 at 42.26mm with some good results at club level
Old 12-10-2009, 08:00 AM   #8511
Originally Posted by niznai View Post
This doesn't sound like what I saw yesterday. Are you sure you are talking about the SP 3? I mean this one:
http://demonpowerproducts.co.uk/prod...oducts_id=4880
Have you tried that?
Perhaps you didn't have the gearing right. My friend's car was really fast. Remember, he was runing against people who run stock all the time, and his car was faster by a clear margin.
From personal experience I can tell you about the Hacker I have which is really slow, but has so much torque you need to gear it really heavily and it will pull like a mad dog.
I have the old Speedpassion 10,5 motor but the new one loves also to be geared heavy.
I get enough power out of it but I don't like the motor.
I love the Tekin much more. I started with the Speedpassion and later I got the LRP X11. Than I bought a 10,5 Tekin and after driving the Tekin, I was sold. This motor is great. Good top speed and good acceleration.
The GM is the only motor that I didn't get fast. I don't have it but some drivers tried several setups and I tried to help but noting worked.
If you have some tips for me how I get that motor also fast than I will be very happy and the drivers with the motor also.
Originally Posted by Senna Racing View Post
ha mikky
your thoughts
thanks in advance
How big is the track?
I use on a big track this setup.
Boost 15
Motor timing 8 to 10
Turbo delay 0,7
Throttle 5
Turbo Max
gearing 6,3FDR
Lipo cut off 2
brake 75%
Drag brake 0
I tried to gear heavier but the motor went faster when I gear't it lighter.
Motor temp was 165F
You can also set the motor timing lower. You get some more power in the infield.
Keep the motor around the 160 to 170F and it runs great.
Never got that the speedo stopped. I got 1 time that my car stopped but that was because the wires were not good. They were not connecting very well because the motor became to hot.
I have read your pm but wanted to reply later and I forgot. sorry for that.
I'm not always at home as I'm reading this forum. I watch it every were where I have internet
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 12-10-2009, 11:39 AM   #8512
Skiddins's Avatar
Randy has mentioned before that the updates etc are constantly being looked at/worked on, so the answer would be a yes even without the 'threat' of the Black Diamond.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-10-2009, 12:52 PM   #8513
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by InspGadgt View Post
Having a problem with my 2nd RS today. The first 2 to 4 laps the car feels great and you can definitely see the turbo kick in. But after that the seems like it is stuck in first gear, like turbo isn't kicking in. I've already tried rebinding my radio gear, reprogramming the RS, and finally did a factory reset. None of those seemed to fix it. The motor (LRP 13.5) was running just under 150 degrees and the ESC felt warm for the first time that I've ever noticed. Any ideas?
My other RS is running great still. I'll probably swap the 2 since my other RS is in my 1/12th where I don't use turbo right now anyway.
This has been reported 100 times on this thead. Have you done the EPA trick yet? Calibrate with your throttle at 90%, then set back to 100% after its done.
Originally Posted by Randy_Pike View Post
If you're running 199 software this was fixed with 200.
It certainly was NOT fixed with 200. TONS of people were/are still having the indentical issue with 200 that 199 saw, and it has been gone over dozens of times in this thread since 200 was released. Once I did the 90-100 epa trick, no issues since.
I'm running V200 Vegas...same one you set up for me at IIC on my WGT car. Still using my Futaba 3PJS with Spektrum module and reciever. At first I was thinking it was the battery going flat. But then I noticed it was happening after only a few laps so I didn't think that was it.
Try my trick, and try raising your delay to 1.0, then try .9, then try .8, then try .7. Once you get down there, you will likely see less and less snap from the turbo as you will be over-timing your motor too early.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-10-2009, 01:00 PM   #8514
Haven't had a chance to try anything yet but will this weekend.
Old 12-10-2009, 06:00 PM   #8515
RCknight's Avatar
Default Man great deal on Tower Hobbies right now.
Tekin RS for 174.00, zero shipping and $15 off with add. 016DG. Early Christmas present for me. lol
RCknight is offline   Reply With Quote
Old 12-10-2009, 07:32 PM   #8516
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
016GL=$25 discount with free shipping
Old 12-10-2009, 10:09 PM   #8517
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yes software is being worked on right now. Testing is happening in undisclosed locations....
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-10-2009, 10:23 PM   #8518
That's great to hear Randy,I know you will put your best foot forward
grouchy is offline   Reply With Quote
Old 12-10-2009, 10:25 PM   #8519
Company Representative
SweepRacingUSA's Avatar
Power to the people!
SweepRacingUSA is offline   Reply With Quote
Old 12-10-2009, 11:08 PM   #8520
sprint5h's Avatar
man I hope so.
Thw word from the Open Wheel Champs tonite is that the Mamba Max Pro is untouchable, and that is in 2s 13.5 class. The lap times aren't very far from the open mod times....
Please hurry on the software updates.
I'd hate to think I could have bought 2 of the mambas for what I paid for my tekin.....
sprint5h is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
