Old 12-04-2009, 10:42 PM   #8446
Pit_dad's Avatar
Originally Posted by 20 SMOKE View Post
what system do you have
I have the Home XP edition from about 2003.
Bob James - Remembered forever | Bud Light |
Pit_dad is offline   Reply With Quote
Old 12-05-2009, 07:04 AM   #8447
alangking_306's Avatar
hai guys,just have hot wire n thanks to smoke for v200, i am using cyclone tc,internal ratio 2.16, like to what ratio goin to use if used sp11.5t version 3,n how to setting bost,turbo, thanks guys
4pk,PT 2549804,V one R4,,RB matrix,nova 353,3st (RRRR,mega, evo2 history)
JBRCC -Black Crow Racing Team-
alangking_306 is offline   Reply With Quote
Old 12-05-2009, 05:29 PM   #8448
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
should work,its not 64 bit
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-05-2009, 06:11 PM   #8449
vazzo's Avatar
Trader Rating: 100 (100%+)
Is it still recommended to use dual mode for mod motors? Does anyone run mod motors in sensored mode?
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 12-05-2009, 06:25 PM   #8450
20 SMOKE's Avatar
yeap dual mode
Jamie W
Old 12-05-2009, 10:58 PM   #8451
CypressMidWest's Avatar
Hey, Shoulda done this earlier but....
Just want to thank Jeff Cuffs for his help at the US Indoor Champs, he's a class act and the Tekin faithful are lucky to have someone as helpful and knowledgable as a resource.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-06-2009, 03:20 AM   #8452
TrevCoult's Avatar
HotWire requires that MDAC28, .NET2.0 and Windows Installer are all installed on the computer.
My guess is that one of the first two is missing. Both are on the original HotWire Install CD.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 12-06-2009, 10:05 AM   #8453
RacinJ's Avatar
Trev
These files are also available for download at the Tekin website.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is online now   Reply With Quote
Old 12-06-2009, 11:49 AM   #8454
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
just thought i would share my 17.5 rubber tc hotwire set-up.
motor :
tekin: 15 degrees
novak ballistic:37 degrees ( neutral setting on motor is 30 degrees)
timing boost: 15
turbo boost: 10
delay: .02
fdr: 5.2
this set-up works very well for me and thought i would share it.
motor temp: 141 degrees after 6 min.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 12-06-2009, 12:50 PM   #8455
Micro-E's Avatar
Jeff,
What size track do you run that setup on?
- Erik
Micro-E is offline   Reply With Quote
Old 12-06-2009, 04:50 PM   #8456
I wanted to know the best setting for the Novak Ballistic motors. They come with 30 degrees so should I turn the timing down on the motor or the speedo? If the motor comes with 30 already I was thinking I don't want to go higher than that just wanted to know which is better, on the motor or the speedo. Also how does it all correspond with turbo? I have v200 firm ware. Please excuse if this has been asked before.
Isaac is offline   Reply With Quote
Old 12-06-2009, 05:22 PM   #8457
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
To answer which timing is better it all depends. I came to the conclusion the Ballistic makes more heat past +2 (40 degrees). But makes more power if you do it in the speedo. On the 17.5 I tried different combos of gearing from 4.1 to 6.0 and timing over the last 2 weeks.
On the track you race at... (96 ft Strait)
V200-Vegas
30 Timing Boost
20 Turbo Boost
.2 Delay
32.5 Timing on the Ballistic (N +.5) (if you come off cool after 6 go up .5 more till you get the temp you want)
5.59 FDR
If the track is less technical and you don't need as much punch
15 Timing Boost
20 Trubo Boos
.2 Delay
30 Timing on Ballistic (neutral)
4.90 FDR
ChristopherKee is offline   Reply With Quote
Old 12-06-2009, 05:34 PM   #8458
michael mercer's Avatar
Which ballistic wind and what type of car(scale) are we talking about?
Thank You
michael mercer is offline   Reply With Quote
Old 12-06-2009, 06:39 PM   #8459
17.5 touring, 10th scale
Old 12-06-2009, 08:34 PM   #8460
Having a problem with my 2nd RS today. The first 2 to 4 laps the car feels great and you can definitely see the turbo kick in. But after that the seems like it is stuck in first gear, like turbo isn't kicking in. I've already tried rebinding my radio gear, reprogramming the RS, and finally did a factory reset. None of those seemed to fix it. The motor (LRP 13.5) was running just under 150 degrees and the ESC felt warm for the first time that I've ever noticed. Any ideas?
My other RS is running great still. I'll probably swap the 2 since my other RS is in my 1/12th where I don't use turbo right now anyway.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
