Old 11-25-2009, 09:25 AM   #8311
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
Originally Posted by g12314 View Post
I've been running anywhere from 7.0 - 7.6 FDR in 13.5 on tracks smaller than 100'. 30 degrees total timing, max turbo, 0.5 delay. Motor without heatsink/fan comes off at 145 after 6 minutes. With the light gearing, the infield rip is great, and the turbo pulls me down the straight. Your mileage may vary, but I felt with all the timing advance (turbo) I was overgeared and kept dropping teeth till I stopped accelerating at the end of the straight.
Jeremy,
Did you ever try dropping like 5 teeth and run like we talked about in Green Bay? Just curious on the results. See you in a couple weeks for the Hurricane race.
Jimmy
yup gave it a whirl and could not get out of a corner very good. i had alot of wheel spin. put lines on the tires and did some taping. all you can see off a corner is lots of whel spin. i did drop a tooth or two from what i have been running and very little spin. car has been 3-5 tenths faster than the rest of the guys. some due to tekin and some from the 09 corally..
you going to come up fri. for some practice?? if you need a place to crash you can crash on the couch. jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 11-25-2009, 06:12 PM   #8312
LOW ET's Avatar
Trader Rating: 97 (100%+)
ok, i got my rs today. downloaded v200 from the link that was posted here. i bring the hotwire up and it says current version 200. but where is all this turbo stuff and delay and what not?
LOW ET is offline   Reply With Quote
Old 11-25-2009, 06:14 PM   #8313
You have to check the "sensored only" box for it to show up.
AreCee is offline   Reply With Quote
Old 11-25-2009, 06:18 PM   #8314
LOW ET's Avatar
gotcha, thanks.
Old 11-25-2009, 09:11 PM   #8315
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by Randy_Pike View Post
This is coming! There will be user saveable profiles that can be stored into the RS. These will be able to be cycled via the onboard buttons/interface on the speedo, no puter required.
what's this i picked up in that lrp vs tekin thread?
randy: part of the new software coming soon?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 11-25-2009, 09:15 PM   #8316
mjc168's Avatar
Trader Rating: 25 (100%+)
Originally Posted by alangking_306 View Post
to mr randy how much tekin hotwire n a cost send to malaysia thanks
pls contact hobbyhaven....they are selling hotwire in Malaysia....
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Old 11-25-2009, 10:33 PM   #8317
jkirkwood's Avatar
Originally Posted by theisgroup View Post
have you tried extending the turbo delay out to like .7+ and then gearing a little higher? at .2 with an 80mm roll out on a track that size, i am thinking that you are trying to ramp timing before the motor has a chance to spin up and that may be generating the heat in the motor.
I have been playing with trying to allow the motor to hit almost full rpm before I ramp timing up with the turbo. this has cooled the motor quite a bit and then it allows me to gear a little higher.
just something to try
I tried that one day with a .6 delay. Either I just didn't get the rollout nailed down or the settings I was experimenting with just wasn't making enough power as my average lap times just wasn't as good. I'll play with it some more before i totally write off that idea.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 11-25-2009, 10:59 PM   #8318
vazzo's Avatar
Trader Rating: 100 (100%+)
Whats the latest and greatest 10.5 setup for medium/technical track, long back straight?
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 11-26-2009, 03:54 AM   #8319
Wicksy1's Avatar
Hey guys could i get V200 thanks [email protected]
Thanks Matt
That'll do donkey, That'll do.
Wicksy1 is offline   Reply With Quote
Old 11-26-2009, 06:18 AM   #8320
theisgroup's Avatar
you may have to gear up quite a bit. on the large track layout that we currently run on I have gone up 5 teeth with timing change only
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 11-26-2009, 05:31 PM   #8321
energyracing's Avatar
Default V200
Hi Randy,
Can you send me v200 at [email protected]
Thank you
George B.
[email protected]
Sponsored by Serpent / SRX2 MM, RM, SC / Serpent SRX4
MoFo paints
energyracing is offline   Reply With Quote
Old 11-26-2009, 06:37 PM   #8322
I'm good found it.
Thanks.
George B.
[email protected]
MoFo paints
Old 11-26-2009, 07:02 PM   #8323
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Thanks Matt
http://redirectingat.com/?id=42X1295...Hotwire200.zip
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-26-2009, 08:06 PM   #8324
RCRjuanabbe's Avatar
Originally Posted by 20 SMOKE View Post
thanks for the link..
RCRjuanabbe is offline   Reply With Quote
Old 11-27-2009, 06:42 AM   #8325
Default Not sure if Turbo is working
Hi. Have just slapped a 11.5T to my RS Pro. Geared at about 6.2 FDR (touring). I have tried to test the turbo function with 0 timing boost and max turbo at 0.5sec. With the car on stands there does not seem to be a noticeable 'step up' in speed that some people were describing in this thread that is akin to a nitro 2-speed. Am I missing something?
This is the first time I have tried the sensored mode as I used to run dual mode with a 5T previously.
Some pointers will be helpful. Thanks.
radwerx is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
