Old 11-23-2009, 07:45 PM   #8281
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally Posted by B18C Turbo View Post
thanks for all the help, got it working
thanks to randy's youtube video!
works great! curious though...there
is a 199 firmware on the tracks computer
and it allows users to drop turbo delay to 0 (none).
Anybody know where i could get that one?
from the track
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-23-2009, 07:47 PM   #8282
beach's Avatar
Originally Posted by 20 SMOKE View Post
from the track
Good luck with that...I have tried with several Team guys....NO LUCK....if you do stumble on it...please look me up.
Beach
beach is offline   Reply With Quote
Old 11-23-2009, 07:48 PM   #8283
jag88's Avatar
That's the version that they call the '199 team' at my track. It's impressive.
jag88 is offline   Reply With Quote
Old 11-23-2009, 07:55 PM   #8284
20 SMOKE's Avatar
if they dont look and your fast on a pc get a flash driver and try and down load it,i've never had it only whats comes from randy through emails
Jamie W
Old 11-23-2009, 08:13 PM   #8285
theisgroup's Avatar
Originally Posted by jag88 View Post
It might not have been released but alot of people have it and from what I've seen it's THE version to have !
there are several 199 version and basically v200 is the "fixed" version. as I understand it. the way the thottle works, the way turbo, and timing boost, and the way push works is the same with v199 and v200 vegas. the biggest difference is that v200 does not have GPFs
I have been playing with 199 and vegas200 for several months. they work the same. with the exception that the 199 does go down to 0 delay. but i am running 1.2sec of delay so, really no difference between the 2
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 11-23-2009, 08:14 PM   #8286
LOW ET's Avatar
Trader Rating: 97 (100%+)
what is GPFs?
LOW ET is offline   Reply With Quote
Old 11-23-2009, 08:32 PM   #8287
Micro-E's Avatar
GPF = General Protection Fault. Old Windows 3.1 / WIn 95 error message when an application would 'crash' and wreck your WIndows session.
- Erik
Micro-E is offline   Reply With Quote
Old 11-23-2009, 11:47 PM   #8288
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The 199 with 0 delay still isn't a true 0 delay, as much as you guys think or wish it was. Vegas 200 has proven to be faster. If you truly wanted more timing right now all the time you could just add motor timing,more boost.
If you guys are still looking for more performance and/or think you're missing something post your setups, track demensions, motor temps, gearing,etc and I will do my best to help...
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-24-2009, 06:17 AM   #8289
Senna Racing's Avatar
ya was there to watch on sunday you had great speed down the straight
dont agree with your jump start as it was not picked up while the race was going on but with a complent later
you seemed to be pushing young matty for time to time
ah well
were are you racing week to week
Originally Posted by B4james View Post
I was running 17.5 and was geared at 5.2FDR, 10 degrees on the motor, 15 in the speedy and max turbo boost with .2 Delay.
The car was awesome down the straight, once you get the RS set up to the sweet spot it is weapon. I had a ball in the finals as normally when you qualify in 7th you sort of stay around that mark but to get 4th was awesome and just wished I had the speed during qualifying
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 11-24-2009, 06:47 AM   #8290
I drove with a Turbo delay from 0,2 but I changed back to 0,3 and the car was a bit faster. You don't see or feel it but you see it in the lap times.
I was using first 5 Boost and 0,2 Turbo delay with the motor timing on 12 (LRP motor)
I changed to 8 Boost to get a bit more top speed and after a couple of laps I changed also the Turbo delay from 0,2 to 0,3 and from that moment the car went faster. with the turbo delay on 0,4 there was no difference. The feeling with the turbo delay on 0.3 was better.
I drove against an other Tekin driver and we tested several Turbo delay's.
When the Boost got higher the Turbo delay went better as it was also higher.
W used 1 car with 1 setup and changed the other one.
At a moment with a lower boost and a lower turbo delay the car accelerated better. This also happened when you geared the car very light and set more Boost and a higher Turbo delay. The setup with the lower Boost field a bit better.
When I would use a Tekin motor I would choose for a lighter gearing lower motor timing and a bit more boost.
But this is because the Tekin runs better than the LRP wile it makes rpm's.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 11-24-2009, 07:09 AM   #8291
20 SMOKE's Avatar
when you lowered and raised boost what is the end bell timing,was it the same during the runs
Jamie W
Old 11-24-2009, 07:30 AM   #8292
Yes
The LRP is standard on 12 and we may not change the timing. You can only set it higher on a LRP X11 and I don't want more motor timing. I want to lower it but it's not possible.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 11-24-2009, 07:32 AM   #8293
LOW ET's Avatar
this is intended for RANDY PIKE but anyone can chime in.
can you give me a setup to put on my tekin rs esc for carpet 13.5t rubber touring car (v200 software). i'm using thunder power 5000 40c lipo, lrp x12 13.5t motor, same car and setup larry fairtrace ran at the classic.
track is 90'X40'
Old 11-24-2009, 07:49 AM   #8294
track is 90'X40'
Nice layout. Almost the same size are were I drive on my races.
I use a 10,5 lipo and i'm geared 7,3FDR.
I have seen a driver with the X12 10,5T but even with a lighter gearing than me his motor went way to hot so I would say gear very light and check your motor temp allot.
Can you set the motor on 0?
If so set it on 0 and the boost 20
Turbo max
Turbo delay 0,3 to 0,4
Gearing i don't now but I now it's just like the Tekin redline motor. very light.
If you keep your motor standard timed set your boost between the 5 and 8.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 11-24-2009, 08:09 AM   #8295
Randy,
I run on a small/tight track, 24x50 with 6' lanes. The straight is 50' with a 20' sweeper entry coming from a very slow chicane (approximately 60' of full throttle before you let off).
I am running a version of 200 I downloaded off of this site. The minimum Turbo Delay is 0.5. So far, finding the 0.2 version has been like an Easter Egg Hunt for me.
My best lap times have been with the following setup: Car-BMI DB12RR Lipo w/ Fantom 5000mah 40c, Rollout 70.5mm, Gear 41/84, RS [email protected], RS Esc Boost 25d, Turbo 20d, Delay .5sec(my current minimum without the correct software). This produces 138d temperature.
Slight changes in motor timing/ Boost setting bring the temperature up to the 150d mark and get a little boggy.
This track layout is like setting up for the tightest infield spot you've seen for the whole lap, then adding one short blast of speed.
Your insight would be appreciated.
VRacing is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
