Old 11-09-2009, 11:13 PM   #8086
B4james's Avatar
Trying to help one of our local guys out,
Has anyone run one of the new SP 3.0 17.5 motors with the Tekin RS ?
If so how did you find it compared to other 17.5 motors as far as gearing and timing settings in the speedy ?
A couple of the guys here have tried them and found them to be slow and needing huge amounts of teeth thrown at them to make them even close to other motors ??
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 11-10-2009, 05:54 AM   #8087
Originally Posted by mikky32 View Post
That is the service of Tekin. It's great.
Here on the forum and the mail. They will always try to help you.
Yup. So far my experience has been positive (apart from the dead ESC). I've been quite impressed with their level of support so far. Hopefully it will be a fast turn around to get my ESC fixed/replaced.
spongerX is offline   Reply With Quote
Old 11-10-2009, 06:07 AM   #8088
Yes the SP 3.0 is slower. The 10,5 13,5 and the 17,5 are slower than other motors. You need to gear it very heavy to get some speed out of it.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 11-10-2009, 06:34 AM   #8089
Moderator
Clegg's Avatar
Originally Posted by Owen RaCing View Post
How about something for the Mac users? I get sick everytime my dad boots vista to play with his RS.
Now if he was booting up windows 7 that'd put a smile on yer face Arent you mac folks used to not getting any software support by now? Isn't that why apple allows MS OS's to be loaded on the lappies?!
(dislcaimer... I am a windows guy, but I do have OSX loaded on a hackintosh netbook just to see it work)
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 11-10-2009, 09:24 AM   #8090
mangoman's Avatar
yep a niche OS requires niche software
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-10-2009, 09:55 AM   #8091
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
Don't update your hackintosh,,, apple blocked that hack. http://www.informationweek.com/news/...Sfeed_IWK_News
The Original SC10 4X4 Clutch Basket
Steve McGeorge
Mac The Knife is offline   Reply With Quote
Old 11-10-2009, 10:43 AM   #8092
tallyrc's Avatar
I want Bluetooth and an app for my Droid
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 11-10-2009, 10:51 AM   #8093
I only want more power. Alle that I get more is extra
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 11-10-2009, 12:09 PM   #8094
Trader Rating: 16 (94%+)
That would be totally bad ass. Change your speedo settings during the race and on the fly by your pit man if needed.
It would also be very cool to have something like the Spektrum Telemetry system, but better, in that would tell you everything thing going on with the motor and speedo, and record the data every few milli-seconds. You could use this data to see how long you stay in full throttle, when the turbo came on, what the rpms were before and after the Turbo kicked in, battery voltage, and temperature logging along the entire race. This data would probably create some of the most accurate and powerful tuning aids in extracting every last ounce of power from your motor and speedo.
kn7671 is offline   Reply With Quote
Old 11-10-2009, 01:23 PM   #8095
Bob~H's Avatar
The Novak Data Sentry Logger Pro does this, it doesn't feed the telemetry back to you, you connect the unit to your PC after the run and download the entire run with a .1 second refresh rate. It gives battery voltage, amp draw, rpm, g forces, and temp for the entire run or can be hooked up with the car on the bench and gives real time data. We used one on a Velodrome track this summer and even saw the rpm spikes when the tires lost contact with the track in a bumpy section.
Bob~H is offline   Reply With Quote
Old 11-10-2009, 02:05 PM   #8096
Right, but if we could see that data in relation to the Tekin timing and turbo, imagine the possibilities. you would need higher resolution than .1 seconds, or 10ms.
Old 11-10-2009, 04:53 PM   #8097
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Excedrin stock would probably go up 30% as well!
Old 11-12-2009, 08:17 AM   #8098
Default Should I gear up further or turn up the timing?
Hi guys. Have been running my RS Pro and an X-12 5 turn for quite awhile now. My FDR currently stands at 7.15 and my esc timing in dual mode is about 6 degrees. Motor timing is the factory recommended timing of -10 degs.
Somehow I just don't get enough top speed at my local track (~60 metre straight). I have geared up to 7.0 and also tried boosting the esc timing to 10 degrees but still can't keep up with another guy running a hobbywing 5.5T combo geared at 6.5 FDR on the straights.
Should I use an even larger pinion to gain my top speed? 'Cos my 5T gearing is getting really close to that of a 5.5T and I'm worried that I might have been doing something wrong.
Motor temps is good though at about 65 degs (with a high speed cooling fan). ESC temp is at 4 LEDS.
Some direction would be very m uch appreciated. Thanks.
radwerx is offline   Reply With Quote
Old 11-12-2009, 11:28 AM   #8099
the difference between a 5 and a 5,5T is not that big.
I would ad some extra timing.
Do you mean 6% or did you calculate the % back to degrees?
Because 6 is very low if it's in %. You can set it easy to 45% or higher when you keep enough power and the motor temp stays below the 80 degrees.
Also you can try to gear it heavier.
Combine the 2 so gear heavier and set your timing higher but watch the motor temp and watch also to the speedo temp.
Did you ad a extra cap? Use also a fan for the solder post.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 11-12-2009, 11:29 AM   #8100
Some direction would be very much appreciated. Thanks.
That is a pretty long straight, almost 200ft long.
Question - Are you and this other car running the same body at the same height, and are the cars at the same weight. If not, you may need to work out the aero and weight before getting further into motor and esc tuning, as these will be two big contributers into a cars top speed.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
