Old 11-06-2009, 09:53 AM   #8041
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by touringdriver View Post
looking for some sort of beginning gearing ideas for a tekin 13.5 2wd offroad and a tekin 10.5 4wd offroad buggys. i use the redline motors along with the rs pro speedos. thanks for any help.
How big is the track? There are a ton of setups in the offroad threads.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-06-2009, 10:33 AM   #8042
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Randy_Pike View Post
Is the rear endbell cap warped? How much play are we talking here?
well none of them seem 'flat', is that wrong? this unit, the play is almost 1/8in. surely 3/32nds.
R
UltegraSTI is offline   Reply With Quote
Old 11-06-2009, 12:24 PM   #8043
Default Hotwire software setup
Randy,
I race 1/12th on-road and just received my Tekin RS-17.5 combo and a Hotwire. I've been keeping up on this thread, trying to get up to speed on the Hotwire software. I downloaded a copy of TekinHotWire_Beta3_30_RS_V200 that was posted on this thread a couple of weeks back.
My question is: Should I install the beta3 V200 software file directly (does it include the necessary operating system for the hotwire interface)? Or, should I install the software disk in the Hotwire box first (the label on the disk is Version 2.7), then the downloaded version of V200?
I am running an older system with windows XP. I've seen some of the recommendations to uninstall the software, then reinstall the update. I should be able to skip directly to installation of the V200 update?
Thanks,
Aaron
VRacing is offline   Reply With Quote
Old 11-06-2009, 12:27 PM   #8044
Originally Posted by VRacing View Post
Randy,
Thanks,
Aaron
No install the V200 version and update your speedo.
Don't disconnect the speedo till all 5 staphs are don.
After updating reset the speedo and calibrate it with your radio.
After that connect it to the pc again and set it on sensord mode.
Than set the settings you want.
good luck.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 11-06-2009, 02:03 PM   #8045
tallyrc's Avatar
question... when i first hit the track with my car is is very fast.. then seems to go "flat".. when temped it is never over 160 or so.. any suggestions? it was suggested that the rotor may be shot from previous use but any other ideas? thanks..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 11-06-2009, 02:10 PM   #8046
John Tag's Avatar
Trader Rating: 42 (100%+)
Yes check your rotor. Turn motor by hand 360* you should feel 6 thumps where motor cogs. If you get less than 4 rotor is shot. Also be sure your battery is not the issue.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 11-06-2009, 02:30 PM   #8047
tallyrc's Avatar
brand new thunderpuffer 5000 pack.. hopefully it's not the prob.. thanks john..
Old 11-06-2009, 02:34 PM   #8048
tallyrc's Avatar
haha.. as i turn it by hand it lumps around halfway then back again.. is that two lumps? can i still use it to hold kid art to the fridge?
Old 11-06-2009, 04:10 PM   #8049
John Tag's Avatar
It may not hold art I would be carefull...... Now take a good motor from your box and compare..
Old 11-06-2009, 06:35 PM   #8050
tallyrc's Avatar
yea, compare it to the spare in my box.. that's rich.. lol guess i'll buy a new rotor and compare it to that... maybe i need an Express...
Old 11-06-2009, 06:50 PM   #8051
good luck.
Mikky32,
Thanks, I'm looking forward to tuning things in with my new RS! Switched over from the GTB 4-cell.
Old 11-06-2009, 07:27 PM   #8052
chrislow's Avatar
Trader Rating: 17 (100%+)
what does it mean when there are 3 good cogs then a feint one? Do new motors have 6?
M03R mini cooper -- T2'008
XXX-CR -- D8 V4 conversion
chrislow is offline   Reply With Quote
Old 11-06-2009, 08:00 PM   #8053
P2
P2's Avatar
Trader Rating: 15 (100%+)
Had the same problem for 2 weekends and finally resolved it.....I tried everything from lower timing on motor, lower timing boost, lower turbo, lower gearing. Nothing worked, car would be ballistic for 3-5 laps then get "soft". The other RS's at the track didn't have this problem. What I did to fix the problem was just recalibrate the RS to my radio and all problems went away.
Current settings are 0* timing on motor, 13.5 Duo 2, 25 timing boost, full turbo, delay .3, FDR 6.9
Car is now a missile the whole run!
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 11-06-2009, 08:20 PM   #8054
Your full throttle setting on your radio is probably drifting a little during the run, and the RS is no longer hitting 100% full throttle. Your turbo won't kick in anymore when this happens. Drop the EPA 5-10, recalibrate your radio, then turn the EPA back up.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 11-06-2009, 09:05 PM   #8055
P2
P2's Avatar
I tried that too and it still didn't fix the problem in my case. After recalibrating the RS to my radio, all is well
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
