Old 11-05-2009, 10:27 PM   #8026
touringdriver's Avatar
Trader Rating: 15 (100%+)
Default GEARING IDEAS WELCOME
looking for some sort of beginning gearing ideas for a tekin 13.5 2wd offroad and a tekin 10.5 4wd offroad buggys. i use the redline motors along with the rs pro speedos. thanks for any help.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 11-05-2009, 10:53 PM   #8027
niznai's Avatar
Originally Posted by Krio View Post
Isopropyl alcohol isn't a problem. The problem is that all the motor sprays that I've ever owned usually contained one or more of the following:
Hexane, Propane, Isopropanol, n-butane, and Isobutane. While plastic friendly for the most part, they are not ideal for electronics.
Cool, thanks. Locally (in Australia) you can actually buy industrial grade (by that I mean high purity) isopropylic alcohol in cans from electronics places.
"Motor spray" is a generic mixture of various crap manufacturers think it's good for motors.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-05-2009, 11:01 PM   #8028
What about using denatured alcohol as a cleaner?
RoyU is offline   Reply With Quote
Old 11-05-2009, 11:27 PM   #8029
The RX8 is based off the RS and is very similar. However, because it was designed for multi-pole high voltage motors the sensor only function is locked out in the software. Sensors are not as accurate with multiple poles/slots so sensored only is actually detrimental in 8th scale electrics. Thus to protect the uneducated public sensored only is not available on the rx8. I'm sure you could "jailbrake" it though...
Your quote of me on this one is odd as I did not say what you quoted me on. I think something messed up on a multi quote or something.
Old 11-05-2009, 11:28 PM   #8030
mangoman's Avatar
Originally Posted by InspGadgt View Post
Yup try a new sensor wire...if that doesn't work then clean out the motor really good with motor spray. Sometimes dirt can get on the sensors and cause the same problem.
Yep or try turning the motor by hand and watching the last three LEDs on the esc (while it is on).
You should see a litle red light in the center of the LED switch between the last three LEDs which is for each phase of the motor. You need to look pretty carefully when doing it.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-05-2009, 11:30 PM   #8031
No...do NOT use motor spray on sensored motors. Compressed air is the best way to clean them out. Motor spray can damage the electronics in the motor.
I was just doing what Tekin told me to do...I've never had an issue with motor spray damaging electronics. Brake cleaner, which many people do use, has definately caused problems. But if you want to be on the safe side use electrical contact cleaner then. Compressed air often can not clean well enough, depending on what is in the motor.
Old 11-06-2009, 02:37 AM   #8032
Hi all. Is it normal if I can't find any RS Pro, nowhere? Asia, Europe, Usa, no speedo, any idea?
*LAF Painting*
february is offline   Reply With Quote
Old 11-06-2009, 03:02 AM   #8033
chrislow's Avatar
Trader Rating: 17 (100%+)
here,try australia http://www.feralbatteries.com.au/category.aspx?id=%2038
M03R mini cooper -- T2'008
XXX-CR -- D8 V4 conversion
chrislow is offline   Reply With Quote
Old 11-06-2009, 03:12 AM   #8034
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Find them at Walmart or Advanced Auto. Walmart is a bit cheaper, I think about $4.50/12 Oz.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 11-06-2009, 04:32 AM   #8035
amnesia's Avatar
http://demonpowerproducts.co.uk/prod...oducts_id=3245
Job done.
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
www.titaniumracing.com
amnesia is offline   Reply With Quote
Old 11-06-2009, 05:35 AM   #8036
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
any1 have a redline with an excessive amt of slop in the arm (rotor)? have 1 that has far more play from the day it started life then my other redlines. worried about it, and prolly want to send it in. not to mention that this 13.5 i speak of is alot faster than my others and in comparison to 2 others from friends that i compared too. almost as if to say its not a 13.5. thoughts?
R
UltegraSTI is offline   Reply With Quote
Old 11-06-2009, 07:06 AM   #8037
timmay70's Avatar
Some of those, I.E. Propane, are just the propellant. I have used motor spray (aka contact cleaner) on electronics for years without incident.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 11-06-2009, 08:33 AM   #8038
rcterp's Avatar
Trader Rating: 35 (100%+)
Ok, I give. How do I get version 200? I just picked up an RS and Hotwire. I've got up to 198, but no 200.
rcterp is offline   Reply With Quote
Old 11-06-2009, 08:53 AM   #8039
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
http://redirectingat.com/?id=42X1295...Hotwire200.zip
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-06-2009, 09:50 AM   #8040
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
R
Is the rear endbell cap warped? How much play are we talking here?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
