Old 10-29-2009, 11:48 PM   #7861
bkspeedo's Avatar
Originally Posted by Syber Serulean View Post
sorry for asking again but I didnt get not even a wisp of an answer...
has anyone compared the turbo function on this ESC to the MMPro's variable timing "c.h.e.a.t mode?"
sounds like it would work the same...
It's actually like Boost and Turbo combined. The advantage is you can adjust at what RPM the timing advanced starts and when it should be at 100% of the timing advanced you select (1 to 50deg).
So lets say your on a big track with a long straight, you can set the RPM range from say 10000 to 15000. When the controller see's 10K rpm it will start advancing timing and when it reaches 15K rpm the timing advance value you set will reach 100% and continue at that value until the rpm drops below 15K.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 10-30-2009, 12:07 AM   #7862
mjc168's Avatar
Trader Rating: 25 (100%+)
If tekin able to come out a dynamic timing firmware like what novak kinetic and orca speedo does...I think most of the beginner will very happy with that....
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Old 10-30-2009, 12:18 AM   #7863
Originally Posted by Cammer View Post
Kane-O
You have to use this software.
http://www.tqcells.com/Hotwire200.zip
So I need a little more help folks. I downloaded this version and after installing still no option for turbo delay after checking sensored. It indicates it is version 180 when I click on versions and upon opening the Hotwire it indicates an application error has occurred. Any help would be appreciated.
-Kane
Kane-o is offline   Reply With Quote
Old 10-30-2009, 01:13 AM   #7864
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
So in your opinion, and im bound to get a biased opinion asking in this forum, what would you say is the superior approach? Timing advance via RPM like the MMpro or "turbo" and boost seperate like the RS? Im already leaning towards the Tekin's but im trying to weight all my options before i sink my money in
Syber Serulean is offline   Reply With Quote
Old 10-30-2009, 03:01 AM   #7865
mangoman's Avatar
-Kane
Did you have vista and the old version installed? There are some things you need to do when reinstalling the newer software if that is the case.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-30-2009, 04:13 AM   #7866
tc3team's Avatar
We have as much tuning as you need on the motor, the 0.2 delay on the vegas software is the icing on the cake.
And yes, my answer is biased, 100% (But at least i'm honest)
Turbo and boost seperate imho allows for more tuning, and there's always going to be new software being developed, future proofing your purchase...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 10-30-2009, 04:40 AM   #7867
tallyrc's Avatar
-Kane
on the interface you have to select the v200 from the list on the right.. the interface is terrible, and the menu is hard to actually see..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 10-30-2009, 06:15 AM   #7868
Company Representative
Kane, I had the same problem. On teh bottom row of button there is a update button. I couldn't see it because of the red on black writing. Once I hit that, everything was fine.
Guess who's decided to play again???
HB Racing/Team Orion
Gary Fliegel is offline   Reply With Quote
Old 10-30-2009, 06:16 AM   #7869
theisgroup's Avatar
Originally Posted by cyanyde View Post
that is now and there is 5 days left. lets see what it sells for. I bet over 2 bills
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-30-2009, 12:12 PM   #7870
I believe this may be my problem. What ere the steps I have to take?
Old 10-30-2009, 12:20 PM   #7871
Thanks Gary, I tried that with no result. I think it is more related to the install of the software itself.
-Kane
Old 10-30-2009, 12:30 PM   #7872
here you go
http://lmgtfy.com/?q=youtube+tekin+vista&l=1
g
gortan is offline   Reply With Quote
Old 10-30-2009, 12:33 PM   #7873
is the simple ugly and easy to use interface still on the shortlist of to-do(s) @ tekin?
g
Old 10-30-2009, 12:42 PM   #7874
bkspeedo's Avatar
The MMPro is almost twice the size of an RS so if space is an issue Tekin is the way to go. The MMPro is also a new controller and is not fully proven yet where as the Tekin has one numerous titles in both on-road and off-road.
I personally think the RPM method is the way to go. Tekin may be headed this way in the near future but its hard to say. Tekin's goal is to make dealing with timing easy, which is fine for some people. I'm not one of those people, I would prefer more control.
I'm not bad mouthing Tekin here, it's a great ESC and I own 2 with a third on the way. I bought the MMPro due to its low cost and I've always been intrigued by Castles customization capabilities.
I started an MMpro thread in the on-road section where you can try asking more questions and we'll see who replys.
Brent Klingforth
5280 Raceway
Old 10-30-2009, 03:42 PM   #7875
Originally Posted by gortan View Post
Thank you so much for the help.....I would have been screwed without it!!! Now I have no stress for tonight's club race lol.
-Kane
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
