Old 10-19-2009, 09:06 AM   #7696
cyanyde's Avatar
Hopefully some team drivers can help me with this. How would you setup SP 10.5 lipo tc for this track.
+ YouTube Video
cyanyde is offline   Reply With Quote
Old 10-19-2009, 09:31 AM   #7697
Try the following setup for that track.
Boost 15
Turbo max
Turbo delay 0,7
5,5FDR You must try several to find the best one.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 10-19-2009, 09:50 AM   #7698
Why are there people that don't ask to help them with the speedo and only complain about no power and slow. Wile when they would only just ask for some help or listen to what you tell them, they would go much faster.
I tried to help some drivers on the ETS but one of them didn't even try my setup and only complaint about it.
Boost 30
Turbo Max and turbo delay 0,2
just got his setup.
5,0FDR
motor Speedpassion 13,5 the new one.
And he found it strange that he had no power in the infield.
Others tried other setups but I was not there so I don't now what they did.
I heard only complaining about that they came power to short.
I have more power on the small tracks than the SPX and GM drivers so I don't now why they don't find any power.
My acceleration is the best and I have on the very short track even without the Turbo the same top speed.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 10-19-2009, 11:06 AM   #7699
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Yang, thanks for the help.
CarlosG. is offline   Reply With Quote
Old 10-19-2009, 02:00 PM   #7700
I like the setup from Mikki32, i suggest you some a lot different, for you have a totally different points of view. ¿Motor SP old one? timming is fixed at 12º.
Boost:22-24
Turbo:15
Delay: 0.3
FDR: 7.0 (same here, you need to test and find the sweep spot)
Please, check your temps, at least every 2 minutes at start.
And, of course, the timer is telling you that it is faster.
Good luck
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 10-19-2009, 02:11 PM   #7701
Trader Rating: 20 (100%+)
Default new guy questions
I should be receiving a TC4 in the mail this week. I have been running off-road 2wd up until now. I have a few new guy questions.
I will be running a Tekin RS with a 13.5
1. What pinion and spur would be a general starting point?
2. What would be a good start for the Tekin ESC v200 as far as the settings?
3. Where should my FDR be at as a starting point?
storytyme is offline   Reply With Quote
Old 10-19-2009, 02:55 PM   #7702
RC MARKET's Avatar
Hk Customer over gear motor temp had 100℃+ ,
used 2 DC fan direct cooling the motor to drop around 80 ℃
RC MARKET is offline   Reply With Quote
Old 10-19-2009, 03:01 PM   #7703
My motor stays below 60C and I don't use motor cooling.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 10-19-2009, 03:19 PM   #7704
@ mikky32
i drive at the ETS with the folowing setting
on the ESC:
timing boost 27
Turbo boost 15
Turbo delay 0.2
throttle program 5
on the motor:
+10 degrees timing
and a driveratio of 7,15 and iv'e got power in the infield.
Yokomo - Much-More - Tonisport
jjongelin is offline   Reply With Quote
Old 10-19-2009, 03:51 PM   #7705
Yes but you geared very light.
When you gear heavier you lose a lot of power.
Not with a 5.0FDR.
Try that and you lose all the power.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 10-19-2009, 09:16 PM   #7706
RMKinWI's Avatar
Trader Rating: 15 (100%+)
How do you get the turbo delay to go less than 0.5 second?
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 10-19-2009, 09:25 PM   #7707
Default turbo settings
RMKINWI,
You have a PM about the Turbo.
Robert
robert s is offline   Reply With Quote
Old 10-20-2009, 03:09 AM   #7708
mazmo's Avatar
Hi mikky32,
What setup with Tekin 10.5 lipo at the same track?
Alan
Boost 15
Turbo max
Turbo delay 0,7
mazmo is offline   Reply With Quote
Old 10-20-2009, 04:11 AM   #7709
Originally Posted by mazmo View Post
Hi mikky32,
Alan
Boost 20
Turbo Max
Turbo delay 0,8
6,3 FDR to start with. (watch temps) you can gear lighter when you have Turbo left on the end of the straight.
Motor timing 8 to 10
When you come power to short in the infield lower the boost a bit.
Try than
Boost 15
Turbo max
Turbo delay 0,6
Motor timing 8
6.3FDR
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 10-20-2009, 04:15 AM   #7710
mazmo's Avatar
Boost 20
Turbo Max
Turbo delay 0,8
Try than
Boost 15
Turbo max
Turbo delay 0,6
Motor timing 8
6.3FDR
OK ... Thanks Mikky
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
