Old 10-18-2009, 01:49 PM   #7681
yokemad's Avatar
I don't know you guys but I feel very lucky to be a Tekin user because Randy here with us everyday listens what we want and they work on it ...
that's really priceless ...
I do hope one day Tekin guys will bring us ORCA type of small programmer to set all those timing-turbo-delay etc.
I'm sure 99% of the tekin users will buy that device
yokemad is offline   Reply With Quote
Old 10-18-2009, 02:23 PM   #7682
John Tag's Avatar
Trader Rating: 42 (100%+)
My common 17.5 starting set up is(Rubber touring smaller asphalt tracks/Indoor Carpet):
10 Motor
10 Turbo(Vary 7-10 all smaller tracks)
30 Timming Boost(Vary 25-30)
gearing 4.5 start
Delay Min.
I Usally adjust timming Boost for infeild as needed and adjust Turbo till car peaks at braking point on main shoot.
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 10-18-2009, 02:43 PM   #7683
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
thats with a duo 2 17.5
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-18-2009, 02:50 PM   #7684
John Tag's Avatar
Yes, I run either Center 5th Slash or 6th slash. With Duo-1 I was running Low hole.
Larger tracks I have run 28 timing Boost and 18 Turbo, Middle hole DUO-1 and 4.76..That was a fairly large US style asphalt track.
Old 10-18-2009, 02:51 PM   #7685
Thats cool another cheap esc.
iLikeTraxxas is offline   Reply With Quote
Old 10-18-2009, 04:08 PM   #7686
vazzo's Avatar
Trader Rating: 100 (100%+)
Is there anyone out there that actually runs the Tekin with modified motors or is it all spec racing? If there is anyone running 4.5, 5.5 or 6.5 can you please throw up your settings just as a comparison?
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 10-18-2009, 06:08 PM   #7687
10 Motor
gearing 4.5 start
Delay Min.
Are you still running 100% drag brake?
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 10-18-2009, 06:21 PM   #7688
John Tag's Avatar
65 Drag-100-100.....
Old 10-18-2009, 06:53 PM   #7689
cyanyde's Avatar
Originally Posted by CarbonJoe View Post
The 20 degrees of timing increase is the same, the difference is *when* the timing is applied. Timing boost is *always* added, whereas the turbo boost is only added *after* you have been at full throttle for the specified delay time. Thus, timing boost is active for 100% of your lap, while turbo boost is active for probably 10% of your lap (by time).
By "max speed" are you referring to speed down the straight, or lower lap times?
Neither. Max speed was in a huge car park where turbo delay was not a factor. I can full throttle for more than 10 sec. You can also try doing it with less timing like 5 degrees then listen to the revs with the car off the ground.
cyanyde is offline   Reply With Quote
Old 10-18-2009, 07:29 PM   #7690
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Yes, I've posted a few mod setups before. Here's Jason Mo Moberly's 4.5 TC setup. This one is THE starting point for most Mod TC. Also Mike Dumas's mod 1/12 setup from IIC.
Tekin RS ESC sensored-jasonmoberlysmodtcsetup.jpg   Tekin RS ESC sensored-mikedumas1-12modiic.jpg
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-18-2009, 08:21 PM   #7691
Team Pink's Avatar
Trader Rating: 20 (100%+)
Moberly's mod setup is great starting setup. Used it to give me a starting point for mod and ended up not changing much or possibly anything.
Planning on trying the Vegas Special this weekend in WGT and my dad will be giving it a try in 13.tc as I'll be running mod tc. Will try to post setups Sunday or Monday.
Team Losi Racing/ Spektrum/ Horizon Hobby/ JConcepts/ Hobby Star/ Schelle Racing
Team Pink is offline   Reply With Quote
Old 10-18-2009, 08:22 PM   #7692
racer-oZ's Avatar
R/C Tech Charter Subscriber
ran my rs pro for the first time this weekend... ran real good, but wanting some additional ideas....
looking for a good baseline setup for my rs pro in a 2wd mod buggy with a 7.5 tekin motor. i usually gear 22/78 in my rb5 for a track that is 100 x 55.
can someone help me out? thanks!
racer-oZ is offline   Reply With Quote
Old 10-18-2009, 08:53 PM   #7693
I experienced a bit of a odd problem yesterday, I ran in 10.5 for the first time. During practice and first couple of qualifiers I had good brakes but then after that I started loosing brakes, I run with no drag brake. But I ended up changing brakes on my transmitter from 70% to 100% just in some hope of getting brakes back.
Yesterday was also the hottest day I've ran a RS (with v200) in, the motor (Losi 10.5 w/ fan) got up 65c. Up until yesterday I've been experiencing lock up in the brakes. If it wasn't for the brake loss the speedy ran completely fine.
Do the Tekin RS's just not like heat?
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 10-18-2009, 09:03 PM   #7694
joeymdz's Avatar
Send a message via MSN to joeymdz
personally changing from an LRP to a Tekin my brakes are the same... nothing! lol
but from our "local guru" says.. the faster you come into a corner and utilize corner speed.. you will see the best results.. so now i use 60 drag brake and use it to the best of my ability (anything more or less was not my driving style with trial an error)
back in the subject is there a problem with my brake or keep on doing what works for me>?
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 10-19-2009, 03:27 AM   #7695
TrevCoult's Avatar
Here's my setup from the 12th scale national last weekend at Crewe, UK. Maybe not quite optimal, but up with or better than anyone else in my heats and mains, and probably better than my ability can handle!
(Tekin RS, Nosram/LRP 10.5)
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
