Old 10-02-2009, 09:46 AM   #7276
2wdrive's Avatar
so everyone is giving fdr's but a tamiya could be different then a xray with tehe same fdr? as you could have a different DTR? (so pretty useless when people only tell there fdr's)
2wdrive is offline   Reply With Quote
Old 10-02-2009, 09:51 AM   #7277
When every body is using the same tires the FDR is for all tc cars the same.
The internal ratio is different but with an other spur gear and Pinion you get the same.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 10-02-2009, 09:56 AM   #7278
2wdrive's Avatar
yeah but no one is giving there internal ratio's when they put there setup here?
edit:
apparantly the FDR that people put on here is not FDR but the PDR and as described before the DTR can be different from car to car? Making the FDR not correct from car to car when only looking at the spur and pinion
Old 10-02-2009, 10:01 AM   #7279
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I'm not trying to tease. I do want everyone to know that we're still working at improving that is already quite good.
We're working on making some things more simple with better performance.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-02-2009, 10:14 AM   #7280
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
no... FDR is FDR, it doesn't matter what chassis you are driving, as long as you are running the same tire.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-02-2009, 10:19 AM   #7281
2wdrive's Avatar
yeah but it seems that some are using the spur/pinion as FDR? which doesn't take the internal ration into account.
Or am i mistaken and everybody takes the internal ratio into account and not only spur/pinion.
Sorry don't want to make a fuss about nothing but i want to be sure the FDR is the FDR and not the PDR otherwise a comparisson is useless
Old 10-02-2009, 10:22 AM   #7282
Regional Moderator
CarbonJoe's Avatar
Spur/pinion is the PDR. FDR is the PDR multiplied by the DTR.
So, you take the published FDR, divide it by your car's DTR, and that tells you what your PDR should be.
You could use rollout like the foam tire guys use, but since the rubber tires are all assumed to be the same diameter, the rubber tire guys use FDR.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-02-2009, 10:23 AM   #7283
Moderator
Clegg's Avatar
Hey Randy,
Now I have done remappings in the past on real ECU's for cars, and some real tuning work. Looking at how that is handled, is there any chance we could get an editor for the ESC's that would let us build an arc or some sort of plot/graph where we could tune how timing advance is applied in what kind of curve at what load/RPM? I know that kind of thing is way over some peoples heads or what they want... but a simple interface, and the ability to change the timing curve would be pretty cool.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 10-02-2009, 10:30 AM   #7284
2wdrive's Avatar
Hey Joe,
Thanks for explaining. But i want to make sure the FDR is what people use when they put on there FDR here because sometimes i have the feeling that they just put on the spur/pinion as FDR (but would be PDR). That is only my concern lol. The rest i understand fully.
Anyway.... on topic
Old 10-02-2009, 10:32 AM   #7285
Regional Moderator
CarbonJoe's Avatar
Originally Posted by Clegg View Post
Hey Randy,
The Castle Creations Mamba ESCs have something like that already (at least for a throttle/brake curve).
What I'd like is a real installer so that you don't have to uninstall each time a new rev comes out. Something like Installshield isn't that expensive.
How about a way to save/load the current settings to/from a simple text file. You could then create several config files at home and load them quickly at the track. Then people could post their "setups" easily.
Old 10-02-2009, 10:33 AM   #7286
DriftDreamer06's Avatar
Hey Randy,
yea this would be HOT ---- always willing to test we have 7 rs running on a 2 week schedule and 3 to 4 testing weekly in 1/12 and VTA(3.7 volt and 17.5) check us out MMR direct in minnesota
DriftDreamer06 is offline   Reply With Quote
Old 10-02-2009, 10:43 AM   #7287
2wdrive's Avatar
how big are touring car tires in mm?
Old 10-02-2009, 10:45 AM   #7288
Regional Moderator
CarbonJoe's Avatar
Most rubber tires have a diameter of 63 mm (2.480 inches).
Old 10-02-2009, 10:45 AM   #7289
2wdrive's Avatar
thanks!
Old 10-02-2009, 10:51 AM   #7290
Lost Aggresiva's Avatar
Anybody?! Maybe I bought an expensive paperweight....?
Originally Posted by Lost Aggresiva View Post
Ok, maybe somebody here can help me out. I'm having a bit of problem with my RS. I downloaded and installed the 3.25 hotwire software from the tekin website. When I try running the program, I get a little red screen telling me it cannot connect with the database and I need the lastest version. I thought I did have it. What am I doing wrong here.
Bill.
Lost Aggresiva is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
