Old 09-30-2009, 06:29 PM   #7231
MaxSp97's Avatar
Originally Posted by Swampracer View Post
Has anyone had problems loading the "Hotwire" into a net-book computer. Window XP, HP net-book.
Having a problem with the software not finding the database?
Thanks Greg G
Did you connect the Hotwire to the car?
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 09-30-2009, 06:34 PM   #7232
Suspended
Originally Posted by Skiddins View Post
A few people have mentiond in the UK that the GM seems to have the legs on the larger outdoor tracks while indoors there is little difference.
I know that most US racing is done indoors on fairly small tracks (by UK standards) or parking lot style tracks which again tend to be smaller.
The GM seems to have an advantage (according to some) on the bigger tracks that are used by nitro's etc.
On the flip side, I also know someone who has gone back to his Nosram as the tuning and gearing nightmare became all too much for him.
Skiddins
Right then!..
Back to these
Simplistic and even
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 09-30-2009, 06:35 PM   #7233
MaxSp97's Avatar
[QUOTE=
0,8sec turbo delay works great.
The car accelerates now in one line to it's top speed.
It's even a bit faster on some infield places.[/QUOTE]
Mikky,
Could you share your setup?
Track size?
This will help TC's friends.
Calvin. L
JOY IS IMPATIENT...
Old 09-30-2009, 07:32 PM   #7234
PrimeAKF11's Avatar
Guys,
I'm sorry to ask such a n00bish question but I can't seem to find the answer anywhere.
Which wire goes where when using a Trinity 13.5 Duo motor?
The other motor I have (Novak 21.5) has its soldering tabs marked A,B and C so all I needed to do was solder and I had no problems whatsoever with that one. But this particular Trinity motor doesn't have any markings and I don't have a clue. I've tried a few combinations but the motor runs either backwards or doesn't run at all.
I don't have a hotwire yet so for now I can only play with the basic settings.
Help!
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 09-30-2009, 07:46 PM   #7235
YmeBP's Avatar
Trader Rating: 32 (100%+)
hold your novak in the same orientation as the duo the wires they are all standard. so connect them the same as the novak.
Originally Posted by PrimeAKF11 View Post
Guys,
Help!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 09-30-2009, 07:55 PM   #7236
PrimeAKF11's Avatar
Ok, I just tried that and the motor runs backwards with forward throttle applied. If I try to run it in reverse it makes a weird noise and wouldn't run at all .
Old 09-30-2009, 08:03 PM   #7237
cheROK1212's Avatar
If you have a Futaba radio you have to reverse the throttle.
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
Old 09-30-2009, 08:14 PM   #7238
PrimeAKF11's Avatar
I already did that when I was setting up the ESC for the first time.
Old 09-30-2009, 08:36 PM   #7239
PrimeAKF11's Avatar
Never mind, guys. I figured it out.
It had nothing to do with the wiring order. Apparently I put the motor back together incorrectly when I had opened it yesterday. Runs fine now. Thanks!
Old 09-30-2009, 11:22 PM   #7240
Originally Posted by Nick Priest View Post
Right then!..
Back to these
Simplistic and even
im looking for these speedos so ican run mod
boybawang is offline   Reply With Quote
Old 10-01-2009, 12:02 AM   #7241
TrevCoult's Avatar
Thanks Greg G
Sounds like MDAC 2.8 isn't installed to me. It is on the HotWire install CD, as are the other things it needs to run.
Trev
Schumacher Atom GT12
Schumacher Eclipse 12th
www.carsrcracing.co.uk
CARSrcracing.co.uk Webmaster
Schumacher Racing
TrevCoult is offline   Reply With Quote
Old 10-01-2009, 02:20 AM   #7242
Hey people, i have a tekin RS esc also and have had nothing but problems with it. When it's working it's fantastic but every now and then in a heat or a final it'll just cut out with no response at all, normally ending up hitting something very hard.
Any ideas? Has anyone has this as well? I'm running the standard power cap that came with the ESC, also running a Nosram 10.5 and spektrum. Tried re binding the Spektrum a few times......but nothing.
Please Jim can you fix it for me!!??
dave_oline is offline   Reply With Quote
Old 10-01-2009, 02:31 AM   #7243
Skitee's Avatar
That doesn't sound like a problem with your RS, that sounds more like your receiver is loosing bind with your transmitter. Do you still have steering control when this happens?
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 10-01-2009, 03:02 AM   #7244
cyanyde's Avatar
Or a bad battery connection to the esc.
cyanyde is offline   Reply With Quote
Old 10-01-2009, 05:46 AM   #7245
vazzo's Avatar
Trader Rating: 100 (100%+)
Whats the ultimate 10.5 setup at the moment guys?
Gone riding, cya.........
vazzo is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
