Old 08-11-2008, 06:48 AM   #706
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by reenmachine View Post
What would you guys think of the combo of the RS speedo and the Speed Passion 13.5 in the meantime?
what Speedpassion motor? 13.5?? My saettings with the SP13.5 was 85% timing and geared at a 3.84FDR and it was FAST!
Old 08-11-2008, 11:15 AM   #707
syndr0me's Avatar
Trader Rating: 32 (100%+)
Is it okay to remove those posts and solder your wires directly to the board? It sure seems like it would be easy to get a wire yanked off a post in a collision or something. The +/- battery terminals being right next to each other kinda makes me uncomfortable.
syndr0me is offline   Reply With Quote
Old 08-11-2008, 11:27 AM   #708
Regional Moderator
CarbonJoe's Avatar
After soldering, why not slip some shrink tubing over the wires down to the B+ / B- posts to act as an insulator?
If you try to get the posts out, you might overheat the board(s), since the top and bottom layer would have to be unsoldered at the same time in order to pull the posts out of the hole. You might need to cut the posts off and desolder the remains one piece at a time. Or use two irons and 4 hands.
Probably not recommended...
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 08-11-2008, 11:32 AM   #709
TRF415boy's Avatar
Both are bad ideas as the posts serve as heatsinks, you will be at more risk to go into thermal shutdown if you remove them or put heatshrink around them. Besides you will definately lose the warranty. Last thing if you're using a RS pro there are 2 fet boards for the solder posts to get connected to.
I've been using tekin speedos for 4 years now, even the G11 had solder posts with two being quite close to each other, and I never had an issue.
TRF415boy is offline   Reply With Quote
Old 08-11-2008, 11:33 AM   #710
Team Tekin
TY@TEAMTEKIN's Avatar
You could but I bet there would be a huge increase in operating temperatures, those posts act as a heat sink coming off the FET boards....Plus it is almost impossible to get those posts out without re-organizing some of the components on the boards, lol. I wouldn't do it, it would probably kill some performance. I have never heard of, or had, a problem with shorting the posts together ever. It could happen if a wire was cold soldered on and broke off during impact, but that would be the ESC's solder tech's fault.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 08-11-2008, 11:35 AM   #711
syndr0me's Avatar
Thanks for the reply. I have deep concerns about this particular solder tech's ability!
Out of curiosity, why did you guys opt to put the battery posts together? This is the only brushless ESC I've seen where there's not some physical separation between them.
Old 08-11-2008, 11:41 AM   #712
Team Tekin
LOL, I'm sure you can solder just fine, I didn't mean anything by it. I've just seen some crazy soldering come in on repairs, couple for the record books!
It really just worked out that way with the PCB layout and we figured it would be no less dangerous than having the three phase posts close to each other, or batt posts on the outside of the phase trio..Any of them touching any others is a bad deal, so we just laid it out simple to keep it the same from ESC to ESC. Only one we messed up on was the B1 because it was the first one done.
Ty Campbell
Old 08-11-2008, 11:55 AM   #713
mangoman's Avatar
I actually put shrink wrap on one of the battery posts. Mainly because ive been told that shorting a LiPo can damage it pretty bad.
I know its not good for cooling but i prefer not to take the risk.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-11-2008, 04:01 PM   #714
Default insulator
Another idea for insulating the posts from each other is a piece of fiberglass between the posts (broken 12th scale t-plates are ideal sources of material) shoe gooed to the case, not the posts. It doesn't cut down on the cooling as much as heatshrink will and allows you to extend it to the top, which is where the short would happen.
You know you love the tape, Sturley...
snowyelan is offline   Reply With Quote
Old 08-11-2008, 04:34 PM   #715
Does the sensored redline motors come with sensor wires? If so are they more flexible then the LRP ones?
Old 08-11-2008, 04:57 PM   #716
johnny boy's Avatar
Trader Rating: 267 (100%+)
tekin rs pros back in stock $209.99 shipped!! along with hotwires and rs's
www.highvelocityracing.com
JOHNNY CHASE
Team associated, Reedy, schelle racing, Lunsford, Lead finger racing
johnny boy is offline   Reply With Quote
Old 08-11-2008, 06:50 PM   #717
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The RS series is defaulted in dual mode. The Hotwire will be required to put the unit into Sensored only. You're truly missing out on the features of any of the our new esc's if you don't have a Hotwire. There are software updates as well as custom profiles(soon) that can be shared between users.
The idea is to be able to download Jeff Cuff's profile, Jason Moberly's, Mike Dumas's or any other team drivers profile.
You want to be fast like these guys? Grab their profile!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-11-2008, 07:29 PM   #718
James35's Avatar
Hehe, if only it were that easy
But the file sharing is certainly nice.
James35 is offline   Reply With Quote
Old 08-11-2008, 07:40 PM   #719
13.5 and 10.5 touring
Back down timing on 10.5 if motor temp gets to high
Sensored only mode
90% timing
throttle profile 5
drag brake 50
break strength 60
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 08-11-2008, 07:47 PM   #720
syndr0me's Avatar
Sensored only mode
90% timing
throttle profile 5
drag brake 50
break strength 60
Thank you!
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
