Tekin RS ESC sensored >
Old 09-25-2009, 10:32 AM
  #7141
JayL's Avatar
Originally Posted by STLNLST View Post
Everything is ready for this weekend. Derek and i will hold it down. Should be fun and Ruben posted that it will be on live rc so I won't have to call you every 5 min giving you updates Any other last second info?????
Best of luck!
JayL is offline
Old 09-25-2009, 10:47 AM
  #7142
niznai's Avatar
Originally Posted by hacker View Post
I know I may get flamed for printing this but.....
the way I see it, there is no difference between
a) 0 motor timing & 0 esc timing with normal fdr
and
b) full motor timing & 0 esc timing with higher fdr
and
c) 0 motor timing & max esc timing with higher fdr
im finding this after a whole year of testing, and comparing my cars to others with no esc timing. Just when I think one option is better then the other, I go try the other 2, and can lap comparable times.
The real benefit is with the small footprint of the tekin speed control.
I've found, and am keeping to my set up of full motor timing, plus esc 10 boost just to give it abit more then what the physical motor can, and play with my gearing til I get 150F at the end of my runs.
thats my honest opinion!
have fun finding out for yourself!
That is interesting, but needs a bit of explanation. What do you mean by "normal" and "higher" gearing? How do you qualify the two?
niznai is offline
Old 09-25-2009, 12:58 PM
  #7143
Krio's Avatar
Trader Rating: 152 (99%+)
and
and
For a track that puts the motor all over the rpm spectrum there is not going to be much difference between the two setups. On a more flowing track I have found better results with a higher timing since the motor itself is spinning a higher rpm most of the time. The opposite for a tight track. The real benefit is using the "proper" timing for the rpm of the motor and is the whole reason v200 was released.
Krio is offline
Old 09-25-2009, 01:10 PM
  #7144
STLNLST's Avatar
Trader Rating: 26 (100%+)
Originally Posted by JayL View Post
Best of luck!
Thanks!
STLNLST is offline
Old 09-25-2009, 01:38 PM
  #7145
dawgmeat's Avatar
can a brotha get a bootleg copy of that vegas profile .3 turbo delay big race this weekend "heads up qualifying"
dawgmeat is offline
Old 09-25-2009, 01:45 PM
  #7146
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
As far as I know, nobody was given an installer.
Cpt.America is offline
Old 09-25-2009, 01:49 PM
  #7147
Krio's Avatar
Its a cheat code like on SNES
up, up, left, down, up, right, right, left, right, down, down, up
While holding start and select of course.
Krio is offline
Old 09-25-2009, 02:00 PM
  #7148
timmay70's Avatar
You don't know about the other one? It will drive your car for you and has access to the gyro and traction control...
timmay70 is offline
Old 09-25-2009, 02:58 PM
  #7149
Man, the fast team guys get all the cool stuff! Betcha they don't have the flux capacitor upgrade though, now that's bootleg!
adam lancia is offline
Old 09-25-2009, 02:59 PM
  #7150
if i ever find a Paul L bobblehead... they say those will drive your car if installed properly and given a power lead, and connected to the 3rd channel of your receiver...
Dondor is offline
Old 09-25-2009, 03:22 PM
  #7151
pakk's Avatar
Trader Rating: 80 (100%+)
Didn't work
pakk is offline
Old 09-25-2009, 03:38 PM
  #7152
I am surprised there is a .5 sec delay. . . I would think they would goto .1.
I have used the Paul L bobblehead, it works fine but V1.0 has a bigger footprint vs the talked about V1.2 that is coming out. . .
A-Ko is offline
Old 09-25-2009, 04:38 PM
  #7153
Default v200
Randy could you give a good starting point for 17.5 duo for this track at hobby stop.com timing boost, turbo boost thanks Marvin I forgot to mention this is for touring and starting fdr
mshap33 is offline
Old 09-25-2009, 04:39 PM
  #7154
turd ferguson's Avatar
Its at Trackside in the case
turd ferguson is offline
Old 09-25-2009, 05:20 PM
  #7155
Khador12's Avatar
To help with delay try to set your EXP at 100% when you calibrate and then turn it up to 120%. This made a big difference.
Khador12 is offline
