Old 09-08-2009, 11:00 AM   #6886
Company Representative
SweepRacingUSA's Avatar
Originally Posted by B4james View Post
Hi Guys,
I am happy to announce that the Tekin RS has won the 2009 South Australian Titles in 17.5 Stock.
This adds to the Victorian State stock title last month in 17.5 stock also.
I was able to T.Q 5 out of 6 Qualifiers, on the way to setting the fastest lap time, fastest race time as well as wrapping up the win in the first two finals.
Car had plenty of pace and motors ran extremely cool all weekend with temps averaging no higher than 120-130f, and this was at a crazy FDR of 3.6 whilst still using boost and turbo function.
Here is some footage of the event and track,
http://www.youtube.com/watch?v=BWOUolZvQ5E
Congrrats, awesome video, great ACDC sounds! nice track perfect!
SweepRacingUSA is offline   Reply With Quote
Old 09-08-2009, 01:43 PM   #6887
Can someone give me some pointers for gearing and settings for the track below (that is a 1/12 running on it, but it's still a BIG track!)
I am running:
Touring Super Stock Tamiya TA-05
Tekin RS esc
Tekin 13.5 redline, 8 deg timing
18 degrees Timing Boost
Max Turbo boost
0.5 sec delay
Had a few issues with set-up, and want to get the turbo right.
http://www.youtube.com/watch?v=26uBtxhZiDw
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 09-08-2009, 01:52 PM   #6888
cyanyde's Avatar
I am running:
Tekin RS esc
Max Turbo boost
0.5 sec delay
Thats one track where the RS will REALLY shine!..
Try timing boost 20-25, fdr 5-6. Watch the temps!!
cyanyde is offline   Reply With Quote
Old 09-08-2009, 02:43 PM   #6889
I am running:
Tekin RS esc
Max Turbo boost
0.5 sec delay
Just what cyanyde says.
Higher your Boost.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 09-08-2009, 03:19 PM   #6890
tc3team's Avatar
Originally Posted by amnesia View Post
Cheers Chris - that helps a lot.
(Nice tidy install by the way )
Daniel.
No problem, and thanks
After being in the hobby 15 years, you get very familiar with a soldering iron!
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 09-08-2009, 09:25 PM   #6891
vazzo's Avatar
Trader Rating: 100 (100%+)
Can anyone confirm these settings should be ok? Just dont have time to test unfortunately.
Tekin RS PRO with Redline 6.5 in XRAY T2009, running FDR of 7.52 in dual mode with 80 timing advance?
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 09-08-2009, 10:50 PM   #6892
cyanyde's Avatar
Adrian
First of all, get out of dual mode, and into sensored mode. Then timing boost at 10, turbo 10. Start with an FDR of 9.0 and progressively gear up/timing boost up/turbo up depending on the track layout, while watching the temps.
Most RS users are running stock classes and haven't much experience running modifieds. But that's what I'd do if I were to run a 6.5T.
Old 09-08-2009, 10:54 PM   #6893
cannon's Avatar
Trader Rating: 35 (100%+)
Not sure if that is correct. Before Tekin Prez said that turbo was useless and dangerous in Mod motors. Not recommended
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 09-08-2009, 11:04 PM   #6894
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I wouldn't start out in sensored only mode either in a 6.5. I'd start out in dual mode, 80 on the timing advance.
You can get into sensored only mode but there are things that must be adjusted prior to doing so.
If you go into sensored only mode make sure to turn your motor timing down to 0, then start bringing up timing boost slowly while watching motor temps closely.
It's easy to overtime a mod motor quickly.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-08-2009, 11:06 PM   #6895
cannon's Avatar
Randy, thanks for the back up on the answer
Old 09-09-2009, 12:19 AM   #6896
B4james's Avatar
Randy, you have an email
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 09-09-2009, 12:28 AM   #6897
we ran 6.5 on-road with the Tekin
dual mode
80 timing
installed a bigger power cap though to be safe. I've tried it in a 2wd buggy too, and that didn't seem to need the cap, but I've not raced that yet, just run it around for a few runs.
CPD Racing
chris_dono is offline   Reply With Quote
Old 09-09-2009, 03:01 AM   #6898
vazzo's Avatar
Thanks heaps guys. Do you think that FDR of 7.5 is about right as well?
Old 09-09-2009, 03:31 AM   #6899
Default RS pro shuts down, overheated?
Hi,
Have some question regarding my RS pro + redline 3.5T setup on my xray EU rubber spec.
After about 5 - 6 mins run time on my local asphalt track, the whole system will shut down with nil response; seems like its overheated.. (local temp that day was about 33-35deg C)
Am using a 17T pinon.
Can any body help pls? Anything wrong with my setup?
Many thanks!
benokw is offline   Reply With Quote
Old 09-09-2009, 03:46 AM   #6900
Originally Posted by benokw View Post
Hi,
Many thanks!
Did you use a bigger cap?
set a fan on your solder post. This will keep the speedo cooler.
lower your timing in the speedo.
what is your setup?
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
