Old 09-03-2009, 10:28 AM   #6781
Originally Posted by 2wdrive View Post
oh by the way. During saterday's club meeting the black wire broke from the esc plug that goes in the receiver . Are there any plugs that have a broader end so i don't have to yank the wires constantly? just curious
I am not sure but would it work if i would solder a second plug onto the esc wire and use that one to plug into the hotwire while leaving the standard esc plug alone? ( when unplugged from the batteries and everything is turned off) Or would there be a short circuit or something else? That way the plug can stay in the receiver and i can use the other one to put in the hotwire to setup the speedo.
edit:
Mikky i don't think i can fit a motor cooler like that in my pod. the axle is near the motor but i would have to see it to be sure. Will look into that.
Forgotten that you have a pan car.
Mine doesn't become to hot any more now I gear it lighter.
The motor has so much rpm that you can gear it very light.
I used a small piece of tape no make a kind of pulling help on it.
Now I pull on the tape and the tape is on the black plastic part of the wire.
This works great.
You can try a Y wire. Don't now if it works but you can try.
I was thinking of the same.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 09-03-2009, 01:18 PM   #6782
cyanyde's Avatar
Originally Posted by amnesia View Post
Hi all.
I run a Photon on rubber indoors on a small high grip carpet track.
This is a small school hall - maybe only 15x10 metres.
I have just purchased a RS Pro (and Hotwire) to replace my Speed Passion LPF2.0 and would like some advice on setup please.
I use a SP13.5 motor (no timing adjustment on the motor), with an FDR of around 5.5. Lap times are around 7.5 seconds for the 13.5 guys - those people running 10.5 motors are approx 0.5s faster.
Should I run a higher FDR with the RS Pro, or start off with the same FDR and see how I go ?
(SP suggests ratios between 4.8 and 6 for this motor)
Assuming I have v200, what would you aim for as a base setp, to tweak from ?
Cheers,
Daniel.
Wow thats a very tight track!!... I'd start with 6.5/20tb/max turbo and work up from there.
cyanyde is offline   Reply With Quote
Old 09-03-2009, 01:20 PM   #6783
cyanyde's Avatar
This works great.
A Y harnes can be risky as you'll be sending power to the receiver and communications thats unfamiliar to the receiver. This could short it along with the hotwire. I wouldn't try until randy says its ok.
Old 09-03-2009, 01:36 PM   #6784
amnesia's Avatar
Cheers...
By working up, I presume you mean lower the FDR (keeping an eye on temps) until I hit optimum lap times ?
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
www.titaniumracing.com
amnesia is offline   Reply With Quote
Old 09-03-2009, 01:36 PM   #6785
2wdrive's Avatar
uhmmm. lets see, the wires are going from the esc to the receiver. red and black are used to power the receiver. the other one is for the communication i gues. When i would use the hotwire the receiver would indeed get voltage and a signal as well i presume as it is still connected to the esc..... not sure if that would be harmfull to the receiver but indeed it could be. Indeed, randy can you shine youre light on this subject?
2wdrive is offline   Reply With Quote
Old 09-03-2009, 02:20 PM   #6786
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Randy,
What can we do for strain relief on the ESC wires? It would be nice to have a small piece of 3 lead cable with the standard end that goes to the esc and a female end with some sort of eject lever on it kind of like internal PC cables.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is online now   Reply With Quote
Old 09-03-2009, 02:27 PM   #6787
2wdrive's Avatar
yeah that would be a very good idea indeed!!!
After some snooping around, from Futaba there is a "servo extention wire" which has a female plug on one side and a normal plug on the other. Don't know if it is something with a eject system though.....number BC0024... but it is a start. should be easier to get the plug in and out i think.
edit:
Ko Propo and some other brands also have a extention wire with male and femal ends. Great stuff ....it will get a lot easier with those extention wires to get the plug in and out without pulling the wires. Probably very similar to the hotwire female plug.
Old 09-03-2009, 03:36 PM   #6788
LOSI123's Avatar
Trader Rating: 63 (100%+)
Originally Posted by Randy_Pike View Post
OK, that setup might be too much timing. I would like to see you try dual mode with 90 on the timing advance and see if you like that.
Dual mode uses the sensors only for rotor position, not for timing calculations.
Thanks randy ill give it another go, although i have tried dual mode already i did not run 90 on the timing.
Is it ok to do the Y lead thing?
LOSI123 is offline   Reply With Quote
Old 09-03-2009, 05:02 PM   #6789
JayL's Avatar
Here's Clints setup, don't tell him! LOL
I was hoping for something faster
BOR:spx is fine just trying all the stuff I have, I did see clint in my rear view but the car didn't look that fast
JayL is offline   Reply With Quote
Old 09-03-2009, 05:48 PM   #6790
Trader Rating: 21 (100%+)
Originally Posted by liljohn1064 View Post
Randy,
John,
Try this: http://www.rcslot.com/pc-radio-contr...enions%2Bwires
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 09-03-2009, 05:49 PM   #6791
John Tag's Avatar
Trader Rating: 42 (100%+)
Randy.....U Got PM
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 09-03-2009, 06:48 PM   #6792
cyanyde's Avatar
Cheers...
Old 09-03-2009, 08:37 PM   #6793
Originally Posted by lidebt2 View Post
I wonder if a piece of narrowed fillament tape looped around the face of the plug with the plug pointing down would work and not be too thick...
Old 09-03-2009, 08:47 PM   #6794
STLNLST's Avatar
Didn't I out qualify you last week???? I have an idea as to what the problem is and will address it before the regionals.
STLNLST is offline   Reply With Quote
Old 09-03-2009, 09:02 PM   #6795
Bob~H's Avatar
I've tried this before and have to say that it does help take the stress off of the plug and wires.
Bob~H is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
