Old 08-31-2009, 07:19 PM   #6721
Bandit17's Avatar
Does anyone here have any information from Tekin on 64 bit vista software for the Hotwire? Release date? etc...
Trackside Hobbies ~ CRC Hobbies
HPI Blitz ~ Custom Works Rocket & Outlaw ~ Tamiya 414M ~ TA05-IFSR
Bandit17 is offline   Reply With Quote
Old 08-31-2009, 07:22 PM   #6722
don't hold your breath for it.
all you can get out of tekin is they are working on it.
patience man.
i break out the old 6 year old xp sp1 computer to tune.
Dondor is offline   Reply With Quote
Old 08-31-2009, 07:26 PM   #6723
Bandit17's Avatar
patience man.
Looks like I might be installing a different OS on my laptop for those away races. Oh well, not much we can do about it I guess.
Old 08-31-2009, 08:10 PM   #6724
tallyrc's Avatar
just resurected my 8 y/o gateway for the same reason.. it's surfs and runs hotwire, what more do i need?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 08-31-2009, 08:15 PM   #6725
niznai's Avatar
Originally Posted by niznai View Post
Another question for team Tekin.
I have changed my gearing as instructed, so am now running a 3.5 FDR (21.5 turn redline/RSpro). I have noticed a significant drop in brake power (compared to the previous gearing). Nothing else was changed on my setup from before (just to remind you, 12 timing on motor, 10 boost, no turbo, no drag brakes, profile 3, sensored mode, no reverse, everything else zero or not used).
Thank you for your help.
Please, Tekin Team, any ideas?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-31-2009, 09:18 PM   #6726
WeatherB's Avatar
Hi Guys, I got the Tekin RS w/ 13.5 brushless motor installed in my CRC Gen-X and I noticed that the motor does have some cogging to it (not sure if this is normal since it's a sensored motor). Also, not knowing that the car was stuck on the edge of a carpet, I gave it some throttle and noticed that the motor made a weird sort of slipping noise as if it was slipping internally instead of putting the power to the wheels. I've only done this once or twice not knowing that it was stuck.
Is this cogging and slipping normal? I read that the old version of the Tekin RX8 has issues with the rotor separating and slipping but not sure if that's the case with the RS as well. Did a search for the usual terms "slip, slipping, etc..." and didn't get any pertinent results.
Hope my motor isn't defective. Been used for maybe 10 minutes at home for testing purposes.
WeatherB is offline   Reply With Quote
Old 08-31-2009, 09:30 PM   #6727
cyanyde's Avatar
Are your brakes set at 100%? EPA brakes maxed out as well? If still weak brakes, try doing a factory reset on the esc and recalibrate and reconfigure everything again. A few here have added some drag brakes to help with braking a little. The thing is, a 21.5T motor runs on very low fdr's which have a negative effect on braking power.
cyanyde is offline   Reply With Quote
Old 08-31-2009, 10:47 PM   #6728
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
That gearing isn't helping your cause. Brakes are created from the motor reversing the power for the most part. That isn't very many rpm's for braking. That is why they feel weaker than before(last setup).
Your motor should not be cogging. That noise you hears is mis commutation.
Make sure your sensor wire is plugged in properly.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-31-2009, 11:06 PM   #6729
niznai's Avatar
Thank you very much Randy/Tekin Team.
I suspected as much. This being the case, should I expect turning up the drag brakes to help the cause? I mean would drag brake help the emergency brake, or the effect is not compounding?
I appreciate you taking the time for me (and everybody else).
Team Greasy Weasel
Old 09-01-2009, 01:00 AM   #6730
razzor's Avatar
I have experienced this even with my SP esc and 17.5.
The taller/longer gearing used the weaker the brakes feel.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-01-2009, 01:03 AM   #6731
LOSI123's Avatar
Trader Rating: 63 (100%+)
Wheres the best place to get the latest RS Pro Software?
Also will it not work on any Windows Vista, or is it just not working on the 64bit version.
LOSI123 is offline   Reply With Quote
Old 09-01-2009, 02:24 AM   #6732
chrislow's Avatar
Trader Rating: 17 (100%+)
Email randy, or guys at your track, me included have it. Normally see a few laptops with it running.
M03R mini cooper -- T2'008
XXX-CR -- D8 V4 conversion
chrislow is offline   Reply With Quote
Old 09-01-2009, 05:00 AM   #6733
Give Randy an email or Pm on the boards. He is very fast at turnaround on things like that )
Great support too.
Old 09-01-2009, 07:35 AM   #6734
WeatherB's Avatar
Hi Randy,
It coggs slightly ever since the motor started "slipping".
All wires are connected correctly, including the sensor wire.
I noticed that it does the "slipping" thing when I hit the brakes hard as well.
Is there a way for me to check the motor internals to make sure it's not broken?
Old 09-01-2009, 08:16 AM   #6735
SammyZ's Avatar
Trader Rating: 138 (100%+)
vista 64x hotwire support?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
