Old 08-31-2009, 12:35 PM   #6706
over gear's Avatar
Trader Rating: 15 (100%+)
if i don't use the lap time as gearing reference, than i don't know what to do. for the Tamiya race, everyone had to run Novak 17.5 and Orion3400 lipo. timing is fixed. i was running 15timing boost + max turbo. i guess the only thing i could have changed was the gearing. i tried 4.0, 4.3, 4.6, 5.0. and 4.0 FDR gave me the quickest average lap times.
over gear is offline   Reply With Quote
Old 08-31-2009, 12:38 PM   #6707
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Did they leave the Novak at 0*?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-31-2009, 12:40 PM   #6708
over gear's Avatar
yes, the staffs tech every motor.
Old 08-31-2009, 12:45 PM   #6709
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
If the novak was at 0 degrees, then you might of been slighly overgeared, and undertimed. Might of tried 25 on timing boost instead of 15, and geared down 1 maybe 2 64pitch pinion teeth from where you were. It would give you slightly better punch in both take off, and midfield. The turbo takes care of the straight.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-31-2009, 12:46 PM   #6710
What was your top speed with 4,0 FDR compared to the 5,0FDR?
What was the top speed compared to the others?
I use by far the lowest gearing with the Tekin on my track.
Still my top speed is the same as the other drivers.
The acceleration is faster than the other drivers.
That you are faster with a heavier gearing is not always because the car is faster. Some times the car is even slower than when you gear lighter.
A Tekin driver ad my club did also gear heavier than I did. He tried also a lighter gearing but he had problems handling the car when it was accelerating faster.
First I thought it was faster because he was faster with it, but after using my FDR he was making his corners much bigger. He misted his drive line each corner.
The car accelerated faster and he hath to get used to it.
After some practice runs he became faster.
I don't say that you have the same thing but I have faster lap times when the acceleration is higher.
You can also try a lighter FDR and set your throttle from 5 to 4. this makes it easier to drive in the infield.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-31-2009, 01:28 PM   #6711
Bob~H's Avatar
NovakTwo
Member
iTrader Rating: (0)
My Photos Join Date: Feb 2006
Steve Weiss explained that both the earlier Novak motors--the Velocitis and SS Pros--and the new Ballistic motors were factory set to 30 degrees timing.
The above is a HobbyTalk quote from NovakTwo, a Novak employee. This explains why some of our local racers have been frying Novaks with Tekin RSs since we thought that they came from the factory at 12-15 degrees of timing.
Bob~H is offline   Reply With Quote
Old 08-31-2009, 01:40 PM   #6712
razzor's Avatar
Originally Posted by Bob~H View Post
NovakTwo
Member
iTrader Rating: (0)
There you go !!
Taking that into consideration you should run around 10 - 15 timing boost max.
lower timing 0 - 5 will have more punch and accelleration.
Would think that on the turbo you would have to be conservative as well and not run max .
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-31-2009, 01:41 PM   #6713
over gear's Avatar
to those who has doubt about the brakes... i had almost 100laps this weekend and i have strong brakes lap after lap.
Old 08-31-2009, 02:53 PM   #6714
Hi Mikky, do you have a link to a vid off your track. just want to see how it compares to track im going to the weekend coming.. with your ratio of 6.3 then from there I can see how I should start with gearing...
thanks
Ricky
prodriver is offline   Reply With Quote
Old 08-31-2009, 04:15 PM   #6715
thanks
Ricky
No problem.
The last 2 cars are both with a Tekin RS Pro.
also the first driver with the pink and black car body.
All 3 with a Speedpassion 10,5 motor for the nationals.
I'm driving the gunmetal car.
http://www.youtube.com/watch?v=RdtFV_zGSzk
this is all with 5 cell.
With 6 cell and a 10,5 you can better choose 7,0FDR to start with.
If you use a 10,5 Tekin Redline 10,5T
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 08-31-2009, 04:29 PM   #6716
this is the track i will be goin to this weekend. any ideas on gearing and motor and speedo setup.
thanks
ricky
tekin 10.5 with lipo.
http://www.youtube.com/watch?v=IYGWcjnQ294
Originally Posted by mikky32 View Post
No problem.
Old 08-31-2009, 04:44 PM   #6717
http://www.youtube.com/watch?v=NRflU8kVbro&NR=1
or that link to track
randy and anyone else any suggestions would be great setups to try.
Old 08-31-2009, 04:57 PM   #6718
Skiddins's Avatar
NovakTwo
Member
iTrader Rating: (0)
Every 'Y' wound motor I have come across comes with 30deg of timing as standard, this is what the manufactures call '0' deg.
Apparently true 0deg would cause the motors to run like dogs (delta wound motors come with true 0deg)
On the Tekin motors 0deg starts at 30deg, the timing mark saying 12deg would in actual fact be 42deg. But due to the timing always starting at 30, we only adjust from 30deg upwards.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-31-2009, 06:28 PM   #6719
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I think I agree with Skiddins. I had a SP, Trinity, and an LRP 13.5 apart on my pit table earlier this year trying to determine if their "standard" timing were the same. It appeared to me as if the sensors were in the same location relative to the coils/can etc from motor to motor. I'd be interested in seeing a Tekin and a Novak apart with the three I mentioned earlier and look for similarities/differences in std. timing. I don't care if we call it 0, 30 or 3.14159 degrees of base timing; the numbers seem arbitrary to me.
Old 08-31-2009, 07:12 PM   #6720
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
On the track I seen in the vid I'd be running 10 on the motor, 20 on timing boost, full turbo with say .6 delay. It's hard to say though since one car is carrying far more corner speed than the other.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
