Old 08-27-2009, 01:01 AM   #6526
pakk's Avatar
Trader Rating: 79 (100%+)
Originally Posted by Scooter79rs View Post
Hi, I just got a RS (which should arrive tomorrow) I've been doing some reading, for the most part I seem to understand it. But I really just want to know what some of the features do because I've 'boost' 'turbo' and 'timing advance' being mentioned as being different terms.
All I want to do is use a 'turbo' to how the LRP SPX is like, I don't want to change the timing on my motor (currently a LRP 17.5) I already know to change my gearing (going from 3.5 to 4.5) so its not that big of problem. I'll be using the v200 software.
And for some stupid reason I can't join the tekin forum because of spam not being welcome there.
did you get a hotwire?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 08-27-2009, 01:15 AM   #6527
Yes, I got both the RS ESC and the hotwire. Just waiting on Australia Post now.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 08-27-2009, 01:24 AM   #6528
pakk's Avatar
Ok.
Boost is timing that comes in at a set RPM
Turbo is timing that comes in at a set delay
Those two + your motor timing will get you your total timing. So you have a somewhat timing curve.
As far as setting your RS like a SPX, I'm not sure if that will happen. You will be able to set it up to be as fast, if not faster, but they are two different esc's. As far ask I know, people use two profiles on the SPX, 7 and 8. What the difference? I don't know. One is aggressive on timing and the other is more aggressive. As to how they are aggressive, I don't know. It could be more timing, less delay, and/or more aggressive timing curve.
If there is no one at your track who runs the same motor and RS, here is what I can suggest.
Set your FDR for optimal infield speed, then add some boost, and then add some turbo and set your delay properly. Don't forget to check your temps.
Not knowing what your track looks like, I'd say go ahead and set your FDR to 4.5. Unless your track is really long and open, I'd say you might even have to go lighter.
*Photon* *SC10 4x4*
RCRD
Old 08-27-2009, 01:27 AM   #6529
niznai's Avatar
OK.
Here's my setup after reading (just to have it here for future reference).
100 Brake
profile 3
15 timing boost
cutoff 3V
BL-FW
everything else zero (including turbo)
See how that goes.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-27-2009, 01:32 AM   #6530
niznai's Avatar
Ok.
What is the "set RPM" value? Or is it "set" depending on other variables too (such as amp draw)?
The second statement in the quote.
Do you mean FDR should be decided only with the timing on the motor (i.e. no timing boost)?
Team Greasy Weasel
Old 08-27-2009, 01:43 AM   #6531
pakk's Avatar
As far as when boost comes in, we don't know. I couldn't find the post, but tekin(randy) won't tell us. I just remember it being a set RPM.
Yeah, set your FDR for infield speed with what ever timing you have on the motor you find best. Then add a little boost, check your temps. If your getting faster, add a little more boost and check your temps.
This may not be the best way to set your car up, but it worked for me and got me in the ballpark. Don't be afraid to go really light on the gearing. I went from 5.0 to 5.7 with v200 one of the tracks I race at. I would have went lighter, but I needed a bigger spur because my gears wouldn't touch anymore.
*Photon* *SC10 4x4*
RCRD
Old 08-27-2009, 01:52 AM   #6532
razzor's Avatar
Final gearing is dependant on infield punch or feel required.
Adjusting boost will help here, depending on the track you would add more boost for more midrange speed and reduce for more punch/accelleration.
This combined with small gearing changes will get you close and then add turbo to make up for lack of speed on the main straight.
To get the sweet spot it will take some practice and numerous tries but is very rewarding
Look at improving your laps times to confirm changes you make and use motor temps as a confirmation that all is good.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-27-2009, 01:56 AM   #6533
Ok.
Cool thanks for that, that makes sense. I drive on a large track so I might end up going from 4.5 to 4.3/4.2 fdr. With my TC Spec geared at 3.5 I spend most of the time at full throttle. I realise that the RS and SPX are not the same, but I do know someone that is using a SPX on p7 geared to 4.3, so I'm using that fdr as a starting point but slightly shorter to be on the safe side.
Old 08-27-2009, 01:57 AM   #6534
madmiki's Avatar
Trader Rating: 14 (100%+)
the way i set mine up is i run 0 timing on the motor with 20 on the the esc.this is with a 17.5. i then gear it so i have good infield speed with next to no acceleration on the straight.then i add turbo starting with 10 and increasing as needed.i found on our local carpet track the times were the best when the motor was coming off at about 135-145f.now our straight is about 30m and i was using about a 31mm rollout where as with a sp esc i was running about 42mm so a huge difference and the tekin rs improved my times by about a second.below is my set up
motor timing-0
esc timing-20
turbo-15
brake 100
push-0
drag bake-0
31.75mm rollout
MIL ROGIC
http://www.topracing.net.au
HOBBYWING
FUTABA
madmiki is offline   Reply With Quote
Old 08-27-2009, 05:39 AM   #6535
Trader Rating: 21 (100%+)
Originally Posted by da_John_wee View Post
I finally found what I been looking for, I'll called that " Tekin Rs for Dummies"
thankyou so much.
John,
I could say something as you left yourself wide open, but I'll be nice.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 08-27-2009, 07:53 AM   #6536
dawgmeat's Avatar
Originally Posted by cyanyde View Post
thanks but you need a log-in for this page
dawgmeat is offline   Reply With Quote
Old 08-27-2009, 08:10 AM   #6537
bkspeedo's Avatar
motor timing-0
esc timing-20
turbo-15
brake 100
push-0
drag bake-0
31.75mm rollout
Madmiki,
A 31mm rollout equates to ~6.3 FDR which is really really lite gearing. Most people I know and what Randy has stated for 17.5, gearing should be around 4.3-4.7. I think you would really see your car come alive if you geared heavier.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 08-27-2009, 08:29 AM   #6538
pakk's Avatar
It is going to depend on the track. On one track I race at, I am at 5.7 along with a lot of other 17.5s. Just about everyone at this track has a RS or spx.
*Photon* *SC10 4x4*
RCRD
Old 08-27-2009, 08:32 AM   #6539
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Randy,
Can you get dyno results for the Redline 10.5, 13.5 and 17.5 motors? I'm looking for peak torque and max RPMs. Its called a Redline, we should know where the red line is. A nice graph would be great. Some of the FDR numbers we collectively are coming up with are a little off the wall. It seems these motors like a little more rev and still have a boat load of torque and top end even geared lightly.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-27-2009, 08:41 AM   #6540
niznai's Avatar
Originally Posted by liljohn1064 View Post
Randy,
I concur.
If I am to find the best gearing I would rather have the torque and power curves than take advice (numbers) for granted. Efficiency and current curves would be nice too. The downside I think would be that not every motor is going to be exactly like the next, so it all depends on how close they would be to the one dynoed.
Team Greasy Weasel
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
