Old 08-26-2009, 12:15 AM   #6496
niznai's Avatar
Well, calibration is done. No difference as far as I can tell, but anyway.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-26-2009, 04:48 AM   #6497
amnesia's Avatar
Originally Posted by Randy_Pike View Post
We're are looking into a few new items to add to our product line. I wish I could devulge what we're doing, but can't...
We have our own version of "skunkworks" if you will: Engineers that we feed every now and again, some water here and there. If they're lucky we let them watch some old reruns of wester movies!
This is why guys local to me always ask "why aren't you ever at the track? Or why aren't you at this event?" And of course the answer is " I was testing something I can't show you...I knew you'd be there so I was at this track...
There are products in the works...in time you will see them. There are some shows coming up for just this reason, perhaps something will "show up."
SR-71 version of firmware for RS Pro = Mach 3.5 ???
No-one else will be able to keep up
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
www.titaniumracing.com
amnesia is offline   Reply With Quote
Old 08-26-2009, 06:30 AM   #6498
StewartFan20's Avatar
Your not geared right. I'd actually gear this up with the current setup. The 17.5 class MUST be geared right for speed. Your temps are cool to cold to be honest. If you're missing acceleration you need to get your gearing right.
On this short of a track you should be running around 25-30 total timing between the motor and timing boost. IF you're DUO is on the lowest setting that should be 0 not 10 so make sure.
I'd reccomend the middle hole(10) and your exsisting RS setup. For now leave the gearing but make the motor adjustment. Run the car and see where you're at. If you're still pulling off that cool gear it up.
If your NW is narrow this should affect the nuetral sensitivity, not WOT.
Setting your epa's 10 over or 5 over calibration is something that was done back in the days of non digital radio since you didn't want to run the risk of bumping a trim pot,etc.
As always guys, you talk and we listen. We are dedicated to being the best.
I moved the timing to the middle hole and left the RS setup alone. The car did have more punch coming out of the corners. I did bump the timing up to 25 (thinking I should back it down to 20) and the motor was 160* in the first qualifier, 164* in the second and third qual and 168* (a little warm?) in the main. I think it needs to be tweaked just a little but it is much better than it was. I don't feel like I am getting beat out of the corners (at least as far as non-driver related issues). Next time, I am going to try the timing boost at 20 and see what the temps are.
Thanks to everyone that offered advice.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 08-26-2009, 11:02 AM   #6499
niznai's Avatar
I think I need some help.
Tested the car (Xray T007), REDLINE 21.5, RS pro.
Pinion 22, FDR 6.409, motor didn't get too hot, but only run two laps at a time. Car was very fast.
Changed to pinion 20, FDR 7.1400, motor got hot, I would guess about 65deg C (about 150F) (run about ten laps), car of course slower but better acceleration (which is what I was chasing).
Motor timing 12, ESC timing 15, profile 3, no drag brakes, brake max.
I had advice form someone else running a Kopropo speedo (not sure what motor) that FDR should be in the low 3s. I think that's way too low, but he told me his motor is cold, and he was pretty fast (my car with the 22 pinion was faster though).
If anyone from Tekin reads this, I would appreciate your input. I attached a picture of the track. It's quite crappy but you get the idea.
Team Greasy Weasel
Old 08-26-2009, 11:07 AM   #6500
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Changed to pinion 20, FDR 7.1400, motor got hot (run about ten laps), car of course slower but better acceleration (which is what I was chasing).
You can overheat your motor by undergearing it as well. 7.14 is geared WAY too short in my opinion. I would try something closer to 5.5. Run the car how you would in a race, for 3 minutes, and temp it. Heck... grab a buddy and put him track side, and have him temp your car every minute up to the 6th minute. You just pull up, he temps the motor, and drops you right back on the track.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-26-2009, 11:16 AM   #6501
cyanyde's Avatar
With a 21.5 you're geared very light. Even for a track that small. The motor got hot because of excessive revving, which will kill the motor in a short time. I would start with 4.5, boost 20 and gear/time up/down depending on temps or lap times. Forget about turbo. You wont see it working on a straight that short. I'm not with tekin though, so take that with a grain of salt yeah
cyanyde is offline   Reply With Quote
Old 08-26-2009, 11:46 AM   #6502
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
on a track that small granted with a 13.5 @ 5.76 gearing i do get boost out of it on the straightaway. it is all in gearing and timing. motor temp was at 154 deg after a 6 min. race. i might drop to a 5.6 ish next time out the try out. with 17.5 or 21.5 gering is much lower 4.0-4.5 range. on that track 4.7-5.0 tould be good. jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 08-26-2009, 11:49 AM   #6503
niznai's Avatar
Thank you cyanide, capt'n. I don't have turbo (by the way I use v198, not v200). But if the turbo kicks in at .5 sec, I could use it. The three sides of the track you see in the picture (one is missing towards you, I just couldn't get away from the track enough with my crappy camera to catch that) can be done flat out. I do it in stock (brushed 27 turn) and have absolutely no problem and people do it in mod (brushless), again with no problem.
Back to my problem, it is rather strange to me (first brushless) to have a motor heating from overrevving. But I take your point. Brushed motors spin to their max rpm and can stay there all day long if you undergear them (not that you're going anywhere fast).
Say i would gear it up to something like 4-5. how would I get the punch back then?
Anyone from Tekin want to add something, please?
Team Greasy Weasel
Old 08-26-2009, 11:56 AM   #6504
razzor's Avatar
On my SP 17.5 and LPF esc i run a 3.8 gear ratio
So i definately think you should be at least geared around 4.5 - 4.0 for a 21.5
From there you can gear up a tooth at a time while watching the lap times.
At the moment it looks like you are overheating the motor by undergearing it.
Undergearing is just as harmfull as over gearing !!!
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-26-2009, 12:03 PM   #6505
Krio's Avatar
Trader Rating: 150 (99%+)
Going to the lower fdr everyone is recommending will produce more punch as you keep the motor in the lower rpms where electric motors make the most torque. Also, free revving a motor builds up heat at a considerable rate compared to a properly loaded motor. There was a reason you were supposed to put a on brushed motors when breaking them in such as a fan. If you are looking for the most punch possible email me at [email protected] so you can take advantage of turbo to maintain your top end but lower your boost timing for more infield punch.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 08-26-2009, 12:06 PM   #6506
Super Moderator
The turbo STARTS to ramp up the timing in .5 seconds, but you dont' actually see it till around 1.5 seconds, maybe 2.
- RCSpecialties -
Old 08-26-2009, 12:08 PM   #6507
Company Representative
SweepRacingUSA's Avatar
Originally Posted by MarkBrown View Post
If you are new to the RS and HotWire, read this post:
http://www.rctech.net/forum/5940355-post4315.html
It should save you some time sifting through old posts on the thread.
I finally found what I been looking for, I'll called that " Tekin Rs for Dummies"
thankyou so much.
SweepRacingUSA is offline   Reply With Quote
Old 08-26-2009, 12:19 PM   #6508
niznai's Avatar
I emailed you from my hotmail address. Hopefully it will not block the attachment when you send me v200.
Team Greasy Weasel
Old 08-26-2009, 12:36 PM   #6509
Krio's Avatar
hotmail shouldn't be a problem as gmail is the one notorious for blocking attachments. I am sending the email so let me know if it doesn't make it within 15 minutes or so.
www.kriostasis.com
Old 08-26-2009, 03:05 PM   #6510
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The guys are right, you can over rev ANY motor and cause too much heat.
With spec motors you really need to gear for all the available torque and then use timing to make up for other sections on the track.
Capt'n is right about the buddy and temping every minute or so. THat is truly ideal if you have support at the track.
Your esc setup is good but I agree, bring your gearing up into the 5.0ish fdr range and work up/down from there. I'd expect gearing up rather than gearing down. Temp is key here. I feel as the others do that you're on the undergeared side of the range.
GEAR IT UP!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
