Old 08-23-2009, 06:45 PM   #6436
cyanyde's Avatar
google is your best friend
http://www.mediacollege.com/microsof...on-change.html
cyanyde is offline   Reply With Quote
Old 08-23-2009, 06:45 PM   #6437
Originally Posted by Josh Keller View Post
How are you changing it to a .zip file?
Thanks,
Josh
change txt at the end of the file to zip
Lugnutz1 is offline   Reply With Quote
Old 08-23-2009, 07:34 PM   #6438
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Thanks,
Josh
Originally Posted by Fred_B View Post
Step 1)Click "Start" and select "Control Panel." Next, double-click "Folder Options." From there, choose the "View" tab.
Step 2) Un-check "Hide Extensions for Known File Types" and click "OK."
Step 3) Navigate to the file whose extension you would like to change. Right-click the filename and select "Rename."
Step 4) Type a new filename. The extension is the portion of the filename that follows the period. In the accompanying image, the extension was changed from "txt" to "zip" Press "Enter"; you will be asked if you are sure you want to change the filename. Select "Yes."
Googled it...
one more thing is to remove old version before you install the new,you can do this after you change it to a zip
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-23-2009, 08:04 PM   #6439
SammyZ's Avatar
Trader Rating: 138 (100%+)
what temp does your speedo come off at?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 08-23-2009, 08:14 PM   #6440
STLNLST's Avatar
Trader Rating: 21 (100%+)
In 13.5 running in hell I have only seen 4 lights on the RS.
STLNLST is offline   Reply With Quote
Old 08-23-2009, 08:20 PM   #6441
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Thats no joke. Its been freakin hot this summer!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-23-2009, 08:50 PM   #6442
Uziman's Avatar
How hot is hot for you guys?
Down here in Aus we can have a week or so around 43 C (109F) during Summer
Corally RDXΦ'09 ★ Airtronics/Spektrum ★ Tekin ★ Fantom
★ www.aerccc.org.au ★
Uziman is offline   Reply With Quote
Old 08-23-2009, 09:30 PM   #6443
SammyZ's Avatar
trying to get an idea of exact temp's of the esc, thanks
Hotbodies USA
SweepRacing USA
Old 08-23-2009, 10:44 PM   #6444
Drifting101's Avatar
Mine is coming off at 45* C
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 08-23-2009, 10:58 PM   #6445
Every one I gave v200 to (about 6 of you) I gave you the older team version that has the ability to go below .5 turbo, if you set it lower than .5 you risk frying your motor, so keep that in mind or get the newer version and it also has v199 within.
Schumacher
Old 08-23-2009, 11:11 PM   #6446
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Matt,
Please don't give out bad info. There was NEVER a v200 that had turbo go below .5 delay.
There was v199 that had a turbo timing slider bar that was NOT released to more than a dozen people. That version didn't have half the turbo we're using now.
If you think you're getting below .5 delay you need to double check your software.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-23-2009, 11:18 PM   #6447
Originally Posted by Randy_Pike View Post
Matt,
It is 200 with a slider (on the most right), I wasn't given it by you, so that's why I didn't address it to you but rather to the people who contacted me (I don't have their emails any more) This was pointed out to me by a local Tekin distributor (reliable source as he tells me you know him personally). I will take a screen shot later tonight. I can GUARANTEE you it says 200
Schumacher
Old 08-23-2009, 11:28 PM   #6448
Version info
Schumacher
Old 08-24-2009, 12:05 AM   #6449
Rdog's Avatar
Trader Rating: 83 (100%+)
K guys Ive been testing the v200 the last couple of weeks and it pretty good. Im still having some issues with getting her just right though. Can anybody give me a great setup or starting point for 13.5 and 17.5. This rubber tire on carpet tc. Im heading out to vegas and I want the put a good showing.
Rdog is offline   Reply With Quote
Old 08-24-2009, 12:11 AM   #6450
pakk's Avatar
Trader Rating: 79 (100%+)
I keep gearing lighter and lighter. I ended up gearing my 17.5 at 5.88 last night. I would have went even lighter, but any smaller, and my pinion wouldn't touch the spur anymore. So I'm going to grab a bigger spur.
I don't have dimensions of the track, but it does have a fairly short strait compared to other tracks I have been to. Pre-200, I was geared roughly 5.0.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
