Old 08-21-2009, 04:46 PM   #6391
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
Push control would be used if you were running a brushed motor,
Mac The Knife is offline   Reply With Quote
Old 08-21-2009, 04:52 PM   #6392
Originally Posted by da_John_wee View Post
12deg? on my motor? what does Losi or Trinity comes with Zero? thats how I have
what is diffrent bet timing boost amd a turbo boost?
is it timing boost is like advancing timing on the motor and Turbo xtra add on RPM kicks in after set delay?
also what is push control does?
so many question yike!
Yes the Turbo ads extra timing after a delay.
The push control ads some extra roll as you go of the throttle. It does the opposite of drag brake. You can use it also with Brushless but i have never used it.
If the motor is on 0 set your boost on 25 to 30.
I don't now if the motor you use is standard on 0.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-21-2009, 09:54 PM   #6393
Randy when is you look alike doll coming. i bet the molders told you that they cant make it cuz your heads to big for your body.
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 08-22-2009, 03:15 AM   #6394
High guys going to a track this size can anyone advise settings for v200 ,The outer dimensions of the tarmac surface are 41m x 29m or about 135ft x 95ft
Ricky
prodriver is offline   Reply With Quote
Old 08-22-2009, 10:56 AM   #6395
TimNJ's Avatar
Trader Rating: 50 (100%+)
Hi guys,
I've noticed that there hasn't been much, if any talk about RS setups for 1/12 scale with a 1S/13.5 setup, so I figured I'd post some of my findings in case it might be of use to anyone.
This is on a medium grip, very small/tight/technical carpet track and I run a 12R5 with the Tekin RS (V200), Tekin Redline 13.5 and SMC 4900 40C 1S lipo pack, Novak Smart Boost & 9650 servo.
Initially, I started out pretty conservative with gearing and settings in the RS:
10 boost
12 physical timing
0 drag brake
100 brake
78/46 gearing on 45mm tires (then worked my way up to 75/47 and 30 degrees of total timing by going to "18" on the boost)
0 Turbo
TP: 4
The car was good like this, but lacked a bit on both the top and bottom ends. I played with a bunch of different gearing combos and found 75/47 to be better, but never quite got the feel I wanted.
So last night I made some big changes and got the car pretty darn near perfect on this track. It was almost as if I had put a different speedo and motor in the car:
Full boost
0 physical timing
0 drag brake
100 brake
75/47 gearing on 44mm tires
0 turbo
TP: 4
The car has plenty of bottom end rip now, is great in the midrange, and only lacks a tiny bit on the top end, which I will cure with the turbo feature and/or making a slight change in rollout.
You just can't beat the RS for tunability and performance. In just 2 races back on the rug this year, with the same car and nearly the same setup as I used with 17.5/4 cell, I'm already .2 - .3 per lap better than I was at the end of last season running a competitor's ESC and motor package.
Just thought I'd post all of that in case it might help someone who is new to running the RS 1S/13.5 in 1/12 scale.
Trinity - Caster Racing USA - Panther Racing
Race Videos: http://www.youtube.com/TrackMasterTim
TimNJ is offline   Reply With Quote
Old 08-22-2009, 11:35 AM   #6396
Danny-b23's Avatar
Hey Randy,
Could you send v200 to [email protected]?
Thanks,
Danny
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 08-22-2009, 12:54 PM   #6397
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
TimNJ- Thanks for posting that info. I'll put it to use when the weather makes us go inside for the winter. I plan on running that same el. setup in my crc car. I'm looking forward to going lipo. I have to do a little more reseach on getting voltage to the speedo. Either a small rx pack or a booster. what did you do? GoodRacing, NickA
TeamCarnage is offline   Reply With Quote
Old 08-22-2009, 01:14 PM   #6398
jkirkwood's Avatar
Full boost
0 physical timing
0 drag brake
100 brake
0 turbo
TP: 4
TimNJ, That's the setup I have nearly but with 25 on boost on a Duo 2 13.5/1s Thunder Power 40c, no turbo. My roll out is shorter at 81mm but I run on a 55'x30' track. I think maybe I could go up to a 82-83mm rollout.
TeamCarnage, I use a novak booster because it was easily available.
jkirkwood is offline   Reply With Quote
Old 08-22-2009, 03:09 PM   #6399
TimNJ's Avatar
You're welcome. I opted for the Novak Smart Boost. No complaints so far. The servo seems plenty fast enough for my liking and there is no additional pack to charge. To me, it's a win-win.
Old 08-22-2009, 03:19 PM   #6400
TimNJ's Avatar
That makes pretty good sense because the track I listed is 60' x 36'. It sounds like we're both very VERY close to where we need to be for our particular tracks.
I'm just thinking out loud, but rRight now, I see 3 options for getting just that tiny bit more on the top end;
1. Turbo
2. Increase rollout just a hair
3 Increase physical timing by a degree or two
I think, for me, the turbo will be the best option since my low end is exactly how I want it right now.
So now a question for the turbo experts: The runline of the longest straight on this small track is approximately 50' - 52' long and begins after a low-speed "S" turn section. It seems that I'm hitting full speed by the 1/3 - 1/2 way mark down the straight. There are 2 other shorter straight sections where I hit full throttle but only for maybe a second at most. My question is, approximately how much turbo should I try and how long/short of a delay should I try? Bear in mind that I'm only looking for a little more top end, not a whole lot.
Old 08-22-2009, 04:46 PM   #6401
cyanyde's Avatar
0.5 delay, max turbo.
cyanyde is offline   Reply With Quote
Old 08-22-2009, 05:05 PM   #6402
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Old 08-22-2009, 05:55 PM   #6403
Danny-b23's Avatar
Never mind.
Danny Buck
Last edited by Danny-b23; 08-22-2009 at 05:58 PM. Reason: Some days I wonder how I remember to breathe.
Old 08-22-2009, 06:44 PM   #6404
Just thought that I would post a little bragging rights for all of us RS/RS Pro users.
I put my Cyclone S up against a TC3 and completely drove off from him doing a little parking lot drag racing. My car has a RS Pro (v200 with Randy's recommended starting point)/Redline 13.5 powered with a SMC 5200 24c 2s lipo and geared at 6.58 fdr, his is equipt with a mamba max ESC and 4600kv motor powered by a 3300 ni-mh 6 cell (he doesn't know the gearing).
We both lined up the nose of our cars with a seam in the lot. Then when he said go, my car just took off. By the time the back of his cars body passed the seam mine already had a cars length between them. By the third seam, there was about a 20 foot gap between the cars.
Needless to say, I was very impressed with the RS Pro/Redline performance.
Fllyer is offline   Reply With Quote
Old 08-22-2009, 10:52 PM   #6405
SammyZ's Avatar
Trader Rating: 138 (100%+)
my tekin comes off the track @ 140 F after 6 minute qual, the ambient
air is 87 F. What's wrong? or is that normal?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
