Old 08-21-2009, 12:40 PM   #6376
JCarr's Avatar
Originally Posted by padailey View Post
Can someone post a setup for 21.5 (VTA)? Or can I just assume that 21.5 setups are very similar to 17.5's with the exception of gearing?
Any suggestions on what works well with a 21.5 using V200?
You know you will probably catch a lot of flack for using turbo in VTA. I have 200 set up on mine but turned the turbo off. Myself and two other guys have already been accused of cheating before v200.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 08-21-2009, 12:48 PM   #6377
Trader Rating: 38 (100%+)
It had nothing to do with turbo. It was the 3.5 motor you had in your car! Those Tekin stickers sure are easy to move from motor to motor. Good thing they made them all the same color.
or8ital is offline   Reply With Quote
Old 08-21-2009, 12:48 PM   #6378
yokemad's Avatar
hi guys
first of all I'd like to thank to Randy and all Tekin Team for this great product...
I've received my rs pro and hotwire today Can anybody mail me the v200 please?
[email protected]
Also I'm using hacker 13.5 fixed timing motor on small tight carpet track with 6-6.5 overall ratio
can you please give me some setup/gearing ideas
thanx in advance
yokemad is offline   Reply With Quote
Old 08-21-2009, 12:49 PM   #6379
When you put the Turbo on, they will think that you drive a 13,5T
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-21-2009, 02:22 PM   #6380
I have developed an "issue" and need some help. Firstly, it's NOT cogging but sounds like it. I have sensorless systems too so know all about cogging!
Just upgraded to v200 and trying to get my setup right. When I hit the gas full power from a stop, it stutters and won't get going. If i'm even rolling a tiny bit, she's a runner. Thinking it may be sensors going in the motor, but all 3 lights on the esc go up when I rotate the spur.
Here are the vitals:
TA05 rubber touring
RS (non pro) ESC
Novak 13.5SS, zero motor timing
Batteries GP3700 Matched, Corally 4200 matched (tried 3 different packs)
Hotwire V200
Brakes = 85%
Neutral = 10
Motor type = 1
Timing Boost = 12
Turbo = Max
Delay = 0.5 secs
Its's not going sensorless only mode, as when I run it off the ground the turbo starts to kick in, which wouldn't happen if sensorless.
Any ideas?
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 08-21-2009, 02:26 PM   #6381
2wdrive's Avatar
probably it is mentioned somewhere but when (roughly) is the 12.3mm rotor comming out?
2wdrive is offline   Reply With Quote
Old 08-21-2009, 02:33 PM   #6382
http://teamtekin.com/blmotors.html
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 08-21-2009, 03:08 PM   #6383
2wdrive's Avatar
thanks mikkey but it doesn't mention when the 12.3mm comes out? It only mentioned the different rotors but only the 12.5 and 13mm (standard versions) are out
Old 08-21-2009, 03:29 PM   #6384
Company Representative
SweepRacingUSA's Avatar
hello tekiners
total nub questions
first of all how can I get in to advance menu?
mine dont show timing boost, turbo or delay at all (attached)
also what is Timing Boost, Turbo, Delay means and how does it work?
I tried to search this forum but no luck.
can some one explain or link to the page where that show?
thanks in advacne
SweepRacingUSA is offline   Reply With Quote
Old 08-21-2009, 03:39 PM   #6385
Con
Choose the SENSORED mode,not dual mode
Con is offline   Reply With Quote
Old 08-21-2009, 03:46 PM   #6386
ZOMG.....that make sense, have to be in sensered mode to use timing boost...of cos..
Thank you. waht does turbo, timing boost mean how does it work?
Old 08-21-2009, 03:58 PM   #6387
Turbo timing is extra timing. Tis will come in as you reach almost your top speed with the boost. So it ads some extra power for the straight.
You can set it on max.
First gear your car for the infield. set your boost around the 20 as your motor is timed around the 12.
Don't look at the top speed. This will come as you ad the Turbo.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 08-21-2009, 04:09 PM   #6388
slakr's Avatar
Trader Rating: 31 (100%+)
Was there ever really a definative resolution to the problem where people seemed to be loosing turbo after several laps?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is online now   Reply With Quote
Old 08-21-2009, 04:15 PM   #6389
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you're having a rough running issue there are a few things to check. Make sure you have your VC set to off since you're running round cells.
Make sure ALL of your wiring is good, a bad joint can cause this.
Make sure that all the sensors are checking in the speedo using the sensor checker feaure(in the manual).
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-21-2009, 04:20 PM   #6390
12deg? on my motor? what does Losi or Trinity comes with Zero? thats how I have
what is diffrent bet timing boost amd a turbo boost?
is it timing boost is like advancing timing on the motor and Turbo xtra add on RPM kicks in after set delay?
also what is push control does?
so many question yike!
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
