Tekin RS ESC sensored >
Old 08-20-2009, 09:19 AM
  #6346
scoyle's Avatar
Guys, posted this query before but guess it didn't make sense without the motor or track size... I am moving from an SPX to the RS in 10.5 turn and I am planning to go with the following settings;
Drag - 20
Reverse - 100
Brake - 100
Neutral - 5
Motor - BL-FW
Throttle - 5
Volt Cut - 2
Push - Off
Timing - 0 (and default timing on my LRP motor)
Current - Off
Sensored - Yes
Boost - 20
Turbo - Max delay - 0.5
With my SPX set on profile 8 (max punch) I am running 5.3 FDR - should I keep this the same with the settings above as I have the Throttle Profile at 5 and the Boost and Turbo on?
The track can be seen here
scoyle is offline
Old 08-20-2009, 09:38 AM
  #6347
Drag - 20
Reverse - 100
Brake - 100
Neutral - 5
Motor - BL-FW
Throttle - 5
Volt Cut - 2
Push - Off
Current - Off
Sensored - Yes
Boost - 20
Nice track.
Motor timing of the LRP 10,5T is 12.
Try 5,7FDR
Check motor temp.
as the Turbo comes in to late or when you have still a lot of power on the straight, lower your boost to 15 or even lower.
Good luck.
mikky32 is offline
Old 08-20-2009, 09:56 AM
  #6348
scoyle's Avatar
Thanks for that - will give those settings a go this weekend. Can't wait!
Stephen
scoyle is offline
Old 08-20-2009, 10:23 AM
  #6349
Stephen
Let me now how it went and what you changed to get the right setup on that track.
Good luck
mikky32 is offline
Old 08-20-2009, 10:55 AM
  #6350
big al's Avatar
Drag - 20
Reverse - 100
Brake - 100
Neutral - 5
Motor - BL-FW
Throttle - 5
Volt Cut - 2
Push - Off
Current - Off
Sensored - Yes
Boost - 20
Scoyle,
Try to keep your neutral above 9. the esc will be very ttouchy at 5. I keep mine at 15, just to be safe. Good Luck--Al
big al is offline
Old 08-20-2009, 02:35 PM
  #6351
cannon's Avatar
Trader Rating: 35 (100%+)
199 is supposed to be the prototype of 200. According to Tekin the same
cannon is offline
Old 08-20-2009, 02:50 PM
  #6352
pakk's Avatar
Trader Rating: 80 (100%+)
according to people who have used both, there is a difference.
--pakk
pakk is offline
  #6353
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
No... NOT the same according to Tekin.
Cpt.America is offline
Old 08-20-2009, 03:00 PM
  #6354
There is a difference but not in power.
The Turbo comes in much smoother. This is a big plus.
Also the motor temps stay lower. I used the same setup as with the V199 and the motor temp was lower. lap times the same but the car runs much smoother so my lap times are more constant.
I prefer the V200 above the V199. I like it when it accelerates in one smooth line to it's top speed.
mikky32 is offline
Old 08-20-2009, 03:01 PM
  #6355
Showtime Racing's Avatar
Location: Naperville, Illinois- on to Wisconsin, Michigan, Indiana Racetracks!
Trader Rating: 35 (97%+)
Any word as to when the 200 firmware will be released to us mortals?
Showtime Racing is offline
Old 08-20-2009, 03:06 PM
  #6356
mail Randy and you have it
mikky32 is offline
Old 08-20-2009, 03:09 PM
  #6357
Bigedmond's Avatar
Trader Rating: 18 (100%+)
well my hotwire will be here tomorrow. Not sure where to start, but i do want to get some testing done before IIC
Bigedmond is offline
Old 08-20-2009, 04:09 PM
  #6358
Team Tekin
Randy_Pike's Avatar
199 is NOT the same as 200.
200 requests here: [email protected]
Randy_Pike is offline
Old 08-20-2009, 04:43 PM
  #6359
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Default thanks
Randy-Thanks for the help today. The v.200 is loaded up. All I had to do was recalibrate the Tx. Are their any setup sheets yet for a baseline? I ran the 180 version out of the box with a few tweaks. Are the 198 setups close to the 200 to start?
If anybody else has some ideas, fire away! I'm running a 17.5 TC5, the track should be a mix of wide open and technical sections with the straight roughly 125' long. tia, Nick A.
TeamCarnage is offline
Old 08-20-2009, 05:10 PM
  #6360
Trader Rating: 17 (100%+)
Default vid to explain how to open updated
the new updates are sent in different format on my coputer and need to be converted. any one know where to find this info ? it was emailed to me but i lost y verizon email account thanks
markny is offline
