Old 08-18-2009, 10:01 PM   #6286
SammyZ's Avatar
Trader Rating: 138 (100%+)
help!
i reverted to firmware 1.98 because i prefer this one, however
when i set my timing boost to any value, i will save it and then go
back to check what the value is through hotwire and it says "GO"?
What is wrong? why can't I add any timing boost?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 08-18-2009, 10:07 PM   #6287
pakk's Avatar
Trader Rating: 79 (100%+)
Originally Posted by Randy_Pike View Post
Pakk: We can't reveal everything we're doing. Your "theory" is logical for the most part.
Capt's Radio/ESC issue can be related to heat though. When things get warm resistance does change a bit, sometimes "just enough." I have seen some radio's be more sensitive than others. I give Clint a tough time about his "choice" of radio at often.
You are correct in stating that on Norcal's current layout that you may never reach full turbo. There is no harm setting it on full however as if you got a killer drive out of the 180 before it you might get to say 11 degrees versus your setting of 10. If the current layout was to say have a sweeper preceeding that straight you very well might get to full turbo.
Why can't you have it earlier? Great question. If we allowed you to get this much timing sooner you could potentially add so much timing you would literally melt the motor down. Under speed on the track too much timing is often not "felt" as cogging or miscomutation since the car is moving. However this is "seen" in super high motor temps that are out of the ordinary.
If you need more timing before this delay you should be able to get what you need using motor timing and or boost timing. It's often overlooked on motors that some use since you're stuck with "holes" or "positions." If you look at a few of our team drivers setups from tracks like Norcal or Speedworld you will see motor timing around 10 degrees or a bit more.
If someone were to say run .3 on the delay along with 10 on the motor and 20 on timing boost on a track that had only an 80ft straight away this would be most likely result in a motor failure. We didn't limit you to .5 because you're trustworthy, rather because if you need it sooner than this motor timing and timing boost should cover this timeframe.
I can't go into more detail as this will give away information that is valuable to R&D. We're constantly making changes that benefit the racer. Perhaps this is just a "taste" of what's to come....
I guess that means no chance of an open source software?
That response is wrong in so many ways. It's like a suprise "To Be Continued" of a REALLY good law and order episode. Like the one when the blonde DA got killed and it was fake to put her in protection. But, the response is well understood and I'll leave it at that. I can't wait to see what else you guys have in store.
If you need another tester, I'm only an email away.
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 08-18-2009, 10:12 PM   #6288
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Pakk, thanks for understanding. We've often times offered up too much information that we feel is being used by "others" to improve products. It's time for Tekin to keep quiet and simply provide constant support along with software upgrades that make our toy cars faster each time. I don't intentionally try to leave anyone hanging. Hell someone said I was an "r/c crack dealer" a few pages back!
Thanks for understanding.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-18-2009, 10:39 PM   #6289
randy that was me that said that and yes you totally are a rc crack dealer. but hey its what keeps them comin back. randy you better come up for april fools this year in utah. just to show us how its really done!!!!!
pakk yes 200 is out but i think randy needed to give the software guys time to let their bloody welt marks heal a little before he starts whippin them again
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 08-18-2009, 11:09 PM   #6290
Rdog's Avatar
Trader Rating: 83 (100%+)
I just tried out the 200 this past Sunday with both 17.5 and 13.5 and I never noticed a fade in the boost from start to finish. Dead even with the spx I think Im going to stick with tekin for a while now.
Rdog is offline   Reply With Quote
Old 08-18-2009, 11:15 PM   #6291
MarkBrown's Avatar
What's your motor timing on this setup? Thanks.
Originally Posted by brrrrm View Post
Tested the 10.5 Redline + RS (v200) on a technical track with relatively short straight (60 ft).
Car: Tamiya TA-05 IFS, front spool, rear ball diff.
Radio: Futaba 3PM 2.4G, receiver: Futaba R603FF
FDR: 6.85
Battery: 4200 Mah LIPO
DB: 15
RS: 100
BS: 100
NW: 45
MT: 3
TP: 5
VC: 2
PC: off
Timing boost: 15
Turbo: max
Turbo delay: 0.5
Track temp: 82F
Motor temp: 120F after 15 minute run.
My car was very fast, easily gaining on another car fitted with 4.5T BL, both on the straight and infield. The turbo kicks in almost immediately after I hit the straight, but it is too short to hit the max rpm. Accelleration coming onto the straight is awesome.
I have to adjust the setup a bit to make sure that I don't lose traction at the end of the straight where it goes into a wide 90 degree turn. Probably increase DB to 20 to slow down a bit more before entering the turn.
I only use drag brake despite the track being very technical with multiple hair pin turns. I found dragbrake sufficient.
MarkBrown is online now   Reply With Quote
Old 08-18-2009, 11:58 PM   #6292
vazzo's Avatar
Trader Rating: 100 (100%+)
Originally Posted by vazzo View Post
Hey guys
Does anyone have any good v200 settings for 2wd buggy (B4) with Tekin RS and Redline 17.5. Track pics below, I dont know exact distances sorry. It only has two straights one is roughly 50ft the other about 30ft.
Attachment 489741Attachment 489742Attachment 489743
Cheers
Adrian
Damn no-one must run the 17.5 in the AE B4 2wd buggy. How would these settings go? If anyone can let me know if I'm on the right track that would be great.
DB: 0
RS: 100
BS: 100
NW: min
MT: 1
TP: 3
VC: 2
PC: off
Timing boost: 20
Turbo: max
Turbo delay: 0.5
FDR of 6.93 and endbell timing 10 degree's
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-19-2009, 12:00 AM   #6293
pakk's Avatar
From what I remember reading on this thread, turbo and dirt don't mix. That guys that tried using it just ended up turning it off. All the cars would do is spin out. Ill see if I can find the post.
--pakk
post #5547
The RX8 will not be affected by this new software. In offroad the turbo function is almost hillarious in spec classes. 17.5 for example is almost like having a 2 speed tranny!
It simply needs to be witnessed to believe.
He says RX8, but the RX8 is a pro with better cooling.
*Photon* *SC10 4x4*
RCRD
Old 08-19-2009, 12:07 AM   #6294
DB: 0
RS: 100
BS: 100
NW: min
MT: 1
TP: 3
VC: 2
PC: off
Timing boost: 20
Turbo: max
Turbo delay: 0.5
Adrian
for off road fdr is not really used. there is a tekin rs setup page here in onroad. but its just onroad. definatly go down on the turbo. but we need to see or know what kind of track size you got. Vazzo you got pm.
Old 08-19-2009, 12:20 AM   #6295
sorry cpt but there can only be one superhero on this thread and its already taken by randy.
hey randy when is the superhero doll of you sportin a red tekin cape gonna be out??? I definatly want one of those!!!!!
Old 08-19-2009, 04:32 AM   #6296
2wdrive's Avatar
Originally Posted by mikky32 View Post
I have my setup now like on smooth acceleration.
It's testing and trying to find a good balance.
Here is my setup with a Speedpassion motor on my home track.
It's not as smooth as the setup I use with my Tekin motor but this is the fastest setup I got with it for so far.
I try tomorrow a lower boost and a heavier lower FDR.
I use quit a high Boost because of the straight.
Just curious, in your setup sheet you state that you use a 12,3mm rotor. Where did you get the 12.3mm rotor? Cause i can't find it anywhere ( is it even out yet?)
2wdrive is offline   Reply With Quote
Old 08-19-2009, 05:05 AM   #6297
razzor's Avatar
The SP comes std with a 12.3mm rotor.
Same for the 13.5 but not sure on the 17.5.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-19-2009, 05:11 AM   #6298
Grim Blackmore's Avatar
Default Tekin rs pro update
Hi i am looking for the update for the tekin update for the software (esc) and have heard there is a 200 version out? where can i find it?
P.S I love my Tekin.
Grim Blackmore is offline   Reply With Quote
Old 08-19-2009, 05:38 AM   #6299
u got mail GB.
RC
prodriver is offline   Reply With Quote
Old 08-19-2009, 05:57 AM   #6300
tc3team's Avatar
--pakk
Some guys in off road still actually use 180 for this very reason.
Off road demands a very different driving style to off road, simply put with off road you cannot use full throttle as much becuase the grip level can vary much more and can be overkill in the bottom end - top speed may take longer to achieve, since you're negotiating jumps etc.
You need a comfortable amount of power at your disposal on the bottom end. So you either control it with your thumbs, or through your electronics/settings...
Turbo might be worth using on a high bite track, where the power can be put down easily and there is a good amount of space to get to speed.
Might be better to try turning it off first, and going up slowly and seeing if it helps.
I don't currently race off road though, so using my past thoughts as a possible explanation...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
