Old 08-18-2009, 01:19 PM   #6256
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Randy_Pike View Post
Capt. : That's all I can ask for! Thanks. Please do let me know. If we have a calibration issue with a certain radio we need to track it down and correct it.
Will do Randy, and thanks.
And just in case I didn't mention it before, when the car is on the track and I lose the turbo, it doesn't "slowly get weaker". For example, lap 5 might feel awesome with a nice bust of turbo speed going down the back straight.. then lap 6, no turbo at all... zero. (at least preceived) Flat acceleration from front to back with the trigger all the way back.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-18-2009, 01:30 PM   #6257
This is my setup as it was in 198 and now in 200.
With the 198 setup, it was competitive with the SPX, but with the high boost, it lacked the punch in the infield and after 5 min it came off the track at around 170 - or closer to 180 when running 5.1 FDR instead of 5.29! The same temperature was recorded if I run longer, say 10 to 12 min... Our straight is around 160ft and long 'chicane' also taken at full speed is approx 160ft.
Then switched to 200 software and things improved A LOT. I stayed with the same 5.29 FDR and reduced boost to 15 from 30 and put turbo to MAX. Infield performance was MUCH improved and i could very easily keep up with the SPXs, both in the infield and the straight... but I'm still rookie so I make a lot of mistakes and lose pace shortly afterwards. Temperature after 5min or more...140ish
I think I could benefit if the turbo came in sooner. In essence you can control the turbo by staying slightly off 100% throttle in the field - granted it might not be the easiest thing to do... Anyway... now i'll test with i higher FDR (5.49) and see how this helps turbo to 'spool' quicker
i also noticed that the turbo kick softens, but only when the battery voltage starts to deplete... For a 5 min race, I do not think it's an issue...
Overall thumbs up
gortan is offline   Reply With Quote
Old 08-18-2009, 01:41 PM   #6258
Overall thumbs up
With a higher FDR the Turbo comes in earlier.
Set your boost to 10 and it will also come in sooner.
You don't have to use a higher FDR when you lower your Boost.
You also get some more power in the infield with the Speedpassion motor.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-18-2009, 01:49 PM   #6259
skypilot's Avatar
Trader Rating: 14 (100%+)
capt, going fast see local thread
semi retired..
skypilot is offline   Reply With Quote
Old 08-18-2009, 01:57 PM   #6260
thanks mikky... this it the kind of feedback i was looking for!
With a lower boost, I'd expect a bigger kick from the turbo! It's quite nice to see it, the effect is exactly like a 2nd gear shift
anyway i'll try both lower boost and higher fdr.... not sure if I'd prefer a less aggressive change when the turbo kicks in...
thanks once again...
g
Old 08-18-2009, 02:04 PM   #6261
Trader Rating: 16 (94%+)
Wouldn't a properly configured setup with Motor Timing, Boost, and Turbo be imperceptible?
Seems to me that if you can visually see the Turbo kick in, than you will have already lost some acceleration, or kinetic energy from the motor already being at max rpm's under the given motor timing and boost? If that happens, the motor and ESC will have to work harder and draw more current to re-accelerate, compared to one continuous imperceptible acceleration?
kn7671 is offline   Reply With Quote
Old 08-18-2009, 02:13 PM   #6262
double post
Old 08-18-2009, 02:14 PM   #6263
Super Moderator
The turbo actually starts to ramp up pretty quickly (only .5 seconds). and gradually gets faster and faster. But watching the car down the straight... it doesn't APPEAR to ramp up, it looks like it shifts gears.
- RCSpecialties -
Old 08-18-2009, 02:17 PM   #6264
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
You don't see a "kick" if you will, the acceleration feels continuous. It's more like once you hit full throttle your car keeps accelerating as opposed to being topped out. So there's no re-accelerating. You actually hear the motor start to wind up...I think that is the kick people refer to.
If I think of it...I'll try to take a video of the turbo "kicking" in.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 08-18-2009, 02:17 PM   #6265
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I want the tires to chirp!
Just kidding. I agree with you 100%. It hits top end, then ramps up a little more until you let it fall away. I can hear it more than I see it on the track so far.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-18-2009, 02:25 PM   #6266
this is what i had in mind... with the my current setup, when the turbo comes on, you can very easily see it visually...
i'll test with lower boost and then higher fdr and will recompare... i tend to agree that a smoother transition will result in less loss.... much like a close ratio gearbox, i believe
g
Old 08-18-2009, 02:26 PM   #6267
Right - this is what my cars do, you just keep hearing it accelerate towards the end of the straight, but on the infield I am on and off the throttle partially enough to keep it from coming on.
So I don't know guys, if you can suddenly see a change in the car, I think it is geared or timed wrong. I will try 2-3 less teeth on the pinion this weekend and up my Turbo to see how it works. I want the Turbo already on before the first 1/4 of the back straight, not half way or more down it.
Old 08-18-2009, 02:27 PM   #6268
Super Moderator
Originally Posted by PitNamedGordie View Post
You don't see a "kick" .
I certainly do. Off the ground, the tires spin and ramp up in what seems like a linear fashion to the point it seems like they are going to spin off. ON the ground, the car seems to "snap" to a second speed.
- RCSpecialties -
Old 08-18-2009, 02:48 PM   #6269
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Kn7671 is on to it!
That is exactly what you should be looking for. Not so much a "shift" in speed rather a long hard continuous pull...
That is when the will be "deceptively" fast as you can't see the shift rather it just keeps on going....like the little pink bunny!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-18-2009, 03:09 PM   #6270
mkdut's Avatar
Trader Rating: 19 (100%+)
Just so I got this right cuz I'm a little dense sometimes:
Gear down to maximize the infield rip and infield top speed. The turbo is then used to compensate for the what would be a normal loss of top end due to gearing down. The bonus is that it just keeps going like the bunny.
mkdut is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
