Old 08-17-2009, 11:06 PM   #6226
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Captain,
How long is your straight away? Where is your motor timing set? What is your Timing boost set to?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-18-2009, 05:38 AM   #6227
Originally Posted by Cpt.America View Post
Nope... actually, even set at .5 seconds, when the turbo IS working, it doesn't actually kick in till 1/2 or more the way down our back straight. I would actually prefer .2 or .3 delay.
First time I used the Turbo, I wanted that to. But now I find 0,5 good.
On some tracks the Turbo comes in later but that is because of the gearing and Boost I use.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-18-2009, 07:03 AM   #6228
Last Saterday some one made a short film.
The black and pink car uses a Tekin RS PRO with a 10,5T Speedpassion and 5 cell. (V200)
The other pink car drives 6 cell with a brushed 19T motor. Both Xray FK05.
Last 2 cars both with a 5 cell 10,5 Speedpassion motor and Tekin RS Pro speedo. Also both with a TOP. I use a TOP Scythe and the other driver a TOP Photon.
I drive the dark gray car.
http://www.youtube.com/watch?v=RdtFV...layer_embedded
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 08-18-2009, 07:07 AM   #6229
vazzo's Avatar
Trader Rating: 100 (100%+)
Hey guys
Does anyone have any good v200 settings for 2wd buggy (B4) with Tekin RS and Redline 17.5. Track pics below, I dont know exact distances sorry. It only has two straights one is roughly 50ft the other about 30ft.
Tekin RS ESC sensored-track001.jpgTekin RS ESC sensored-track002.jpgTekin RS ESC sensored-track003.jpg
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-18-2009, 08:45 AM   #6230
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Default windows vista & v200
I am having problems with this either I am doing something wrong or my notebook won't let it download if anyone has some free time and does not mind I could use some help pleas call steve 630-935-0132
All I can get to work is v180
twelvegauge is offline   Reply With Quote
Old 08-18-2009, 08:45 AM   #6231
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Randy_Pike View Post
Captain,
Our straight is HUGE... 100 feet down the back, 80 feet back towards the driver stand, and you can take the corner between the two sides at full speed. The turbo doesn't visibly kick in till 1/2 to 2/3rds down the back 100 foot stretch.
Timing setup is pretty pasic... running a duo, 10 on the can, and 10 on the esc. Also tried 20 on the esc. I didn't notice it change the precieved spot where the turbo kicks in.
My real issue though... is why the turbo completely goes away after 5 or 6 laps. in a 22 lap race, its kind of "eehhh"....
Cpt.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-18-2009, 09:52 AM   #6232
Cpt.
now i using 200,run 12min with 5200mah 30c and motor 11.5r 0 timing,boost 27,turbo 20,delay 0.5,every lap turbo working great....no issue with 200,great product !!!!
on d way is offline   Reply With Quote
Old 08-18-2009, 10:04 AM   #6233
Team Tekin
Randy_Pike's Avatar
Cpt.
I understood that. What radio? Receiver? Where did you cal the radio/esc in regards to endpoints?
Old 08-18-2009, 10:14 AM   #6234
Hey there randy if you are choosing to ignor me thanks for nothing, but if not the file does not show up on my screen like it does on your youtube video not sure why can I rename the whole thing and if so what do I put it is a little hard to read.
Old 08-18-2009, 10:49 AM   #6235
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Try this, its a little long handed and old school, but it works.
Put the file on your c: drive.
hit start.
in the run box type cmd
in the prompt type cd.. and hit enter
repeat the last step until all you see is C:\> and a flashing cursor.
Now type dir and hit enter
You should see the file name you copied directly to the C drive.
Now type rename Tekin_Hotwire_Beta_3_30.txt Tekin_Hotwire.zip or whatever name you want .zip
Move the zip file using drag and drop from C drive to where ever you want it.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-18-2009, 10:49 AM   #6236
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I have a couple questions for you:
Do you have the file on your desktop?
If yes, then you should be able to select the file as in the video. When you do you should change the extension on the file to .zip. Meaning if the file is named "tekin.txt" change it to "tekin.zip". Then the file icon should look like Randy's.
Where you able to get that far?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 08-18-2009, 10:53 AM   #6237
Team Tekin
Randy_Pike's Avatar
I'm not ignoring you at all:
Click on "start"
Click on "computer"
Hit the "alt" button
Select "tools" at the top menu bar
Select "folder options"
Click on the "view" tab
Click on "show hidden files and folders"
Uncheck "show extension for known file types"
Click "apply"
You should now be able to "rename" the file that you were sent. Simply right click on it, choose rename, highlight the last 3 characters and change it from .txt to .zip .
Old 08-18-2009, 10:55 AM   #6238
hit start.
Did cd\ not go all the way back?
It's a long time ago that I worked with it so I don't now for sure.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 08-18-2009, 10:57 AM   #6239
JCarr's Avatar
Something I missed while trying to download the new version with vista. The video tells you how to get rid of teh hidden file but doesn't mention you need to go to the install/uninstall program and remove the old tekin file also. I forgot that step and fought with it for a couple hours before I realized my stupidity. Did you remove the old tekin file before trying to download the new one?
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 08-18-2009, 10:59 AM   #6240
Super Moderator
Using a 3PKs with fasst... completely "model reset" setup on the radio... 100%on all end points... totally vanilla. Receiver is 603fs (dual antenna). I have zero issues of any kind, other than the one in question.
- RCSpecialties -
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
