Old 08-17-2009, 03:43 PM   #6211
Hi, Just loaded up the V200 and was looking for some help with the setup and maybe gearing suggestion.
Running a Tekin 13.5 on Asphalt track 60x100
Thanks in advance.
RKP3.3 is offline   Reply With Quote
Old 08-17-2009, 03:48 PM   #6212
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by pakk View Post
well you said if 200 doesn't work for you, your going to try 200. Do you have two different versions of 200?
--pakk
Oh sorry. I meant if my 199 becomes a problem I have 200 to download and use. I must of not watched what I was typing.
ST Racing Concepts (STRC)
Old 08-17-2009, 03:52 PM   #6213
wyd
Tech Legend
wyd's Avatar
Originally Posted by jon Perkins View Post
I see on the setup thread for the tekins spedos, i see that some guy's look like they are running 40-50 deg totall timing correct me if im wrong, but i thought that 30-35 was really the max timing to run between the motor and speedo, anything else higher was bad for the motor
I'm sure others will reply but what i have gathered is as long as your motor is not getting too hot you ok. I try to keep all my motors under 175 and that has worked great for me. Most of my motors run in the 160's and I have been super happy with that and the performance I get at those temps.
Old 08-17-2009, 03:53 PM   #6214
I have used the V199. I run now the V200.
It runs better. lower motor temps and the speedo reacts very good on the throttle.
Also the Turbo feels better.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-17-2009, 03:58 PM   #6215
35 to 45 total timing
I use now 47 timing and max Turbo
best result for me on my home track for now with the speedpassion.
With the Tekin Redline I run 42 total timing and max Turbo.
On my home track I even use with the Tekin redline only 35 Total timing with max Turbo.
Motor temp are good. all below the 180F.
Only in some races as I want as much power I can get the motor will be some times 190F. But the temp lowers after the race fast.
This is also alone as the air temp is high.
Normally even than I stay below the 180F.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 08-17-2009, 04:07 PM   #6216
kenny myers's Avatar
i have read the past 2 pages and i have a major headache!some are saying to do the throttle calibration and some no? if that is the fix than sweet i will do it but it sounds like it has worked for some and others disagree. so far i like the v200 and i will fricken love it if i could get the turbo to be consistant.i'm a racer in denver colorado and belong to colorado on road rc club.we have a sick ass track in lakewood that is basically a fricken super speedway!our straightaway is like 200ft +.we race 3 times a week, 2 nights of carpet and sundays on asphalt.anyways everybody in our club runs there motors hot.not that that is good but i see guys saying there motors are at like 130 and 150?we push our cars to the limit i won't stop gearing my car till it is around 180 to 200!on a big track, now carpet a little different but still about 175 to 180.anyways i thought that the turbo feature may be being affected by voltage drop as the batterys start to discharge. so after my long novel here is the calibration trick the fix or no?
kenny myers is offline   Reply With Quote
Old 08-17-2009, 04:13 PM   #6217
wyd
Tech Legend
wyd's Avatar
Thats funny. I keep reading how nice the 200 is but a few teams guys that I know where going back and forth. A few other non team guys like 199 better than the new 200 version.
I guess I will just have to try it and see how I like it. I can always go back if I don't like the results.
I keep watching the thread on ideas on settings with the 200 so when I try it I have a very good idea on what I should be doing to make it work at its best.
Old 08-17-2009, 04:16 PM   #6218
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you have 200 installed in your esc and your hotwire. You should NOT need to do anything other than a standard radio calibration.
IF you find that the turbo is inconsistent try the epa trick to assure your esc is receiving full throttle from the radio.
There really shouldn't be any confusion.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-17-2009, 04:50 PM   #6219
Gilligan's Avatar
Hey, guys.
Ran v200 here this weekend in TC Stock. Absolutely loved it. Ran zero on the motor, 15 boost, 20 turbo with .6sec delay. FDR was 4.56 on a tight track. Came off each run between 145 and 150 degrees for three qualifiers and a main. The race announcer was joking a bit saying that my three-speed electronic transmission would be DQ'd. Hilarious.
The trick for me was to find the gearing and timing settings where there was no noticable kick into turbo - just a smooth and hard pull on the straight while maintaining reasonable temps. I found, though, that I have been running many different combos depending on the track layout and whether I was running a diff, spool or one-way. Without finding the right settings it was simply something cool to watch toward the end of the straight. Spending the time thinking about what the esc is doing, and under what conditions it does so, is time well spent in chasing faster laptimes. Next week we'll see what can be done with the beast in Pro10 235mm GTP 2 cell LiPo class (in the middle of a European Classic Car Show, no less!).
Props to Randy et al for the support.
Phil
www.onejobjar.com
Gilligan is offline   Reply With Quote
Old 08-17-2009, 05:10 PM   #6220
Trader Rating: 38 (100%+)
Originally Posted by Gilligan View Post
Hey, guys.
Phil
what motor?
or8ital is offline   Reply With Quote
Old 08-17-2009, 05:29 PM   #6221
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Here's a thought for those thinking the turbo is getting soft/turning off/whatever after a few minutes of racing (if you have time to practice with lap timing)
Go out with the settings you have been using that you felt would only allow the turbo to last 1-4 minutes. Get some lap times you feel represent as close to your best effort as possible. Go back recharge, resauce and come back out and change nothing. Run until you think the turbo has shut off. Stop the car in the groove, go out to the car, and dial your throttle hi-point down just until you can't get full throttle flashing on the esc. Continue running as quickly as possible and see if you notice a difference in lap times.
Another way to do it would be to go out and run like normal, and then come in recharge and resauce and turn the turbo to zero leaving all the other settings the same and see what difference it makes. I couldn't see a definite drop in lap times in the run that I thought the turbo was easing off so I am expecting it was just in my head.
HTH
Old 08-17-2009, 06:15 PM   #6222
thanks all for the advice and info.
Old 08-17-2009, 08:36 PM   #6223
RacinJ's Avatar
Default Fading Turbo?
The question that keeps coming to my mind is, do you have your turbo delay set to low?
As you run and your battery is going down, can the .5 second delay be too short to feel? It may be kicking in before you're wound out on the straight.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 08-17-2009, 08:43 PM   #6224
Gilligan's Avatar
Originally Posted by or8ital View Post
what motor?
TEKIN 17.5!
www.onejobjar.com
Old 08-17-2009, 10:16 PM   #6225
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Nope... actually, even set at .5 seconds, when the turbo IS working, it doesn't actually kick in till 1/2 or more the way down our back straight. I would actually prefer .2 or .3 delay.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
