Old 08-12-2009, 12:19 PM   #5971
Skiddins's Avatar
Originally Posted by cyanyde View Post
With so many brushless motors out there and almost zero info on their endbell timing, can someone tell me how to measure the endbell timing from the sensor position? After looking at the sensors of 2 different motors of the same winds I have, One seems to be so much different than the other. Like 15 degrees off or so. Its so weird...
I was told by LRP that the following picture shows 30deg actual timing, which most manufactures consider to be 0deg with regard to delta wound motors, I have Speed Passion (pictured), Nosram and Hacker. They are all the same;
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-12-2009, 12:35 PM   #5972
Giorgio's Avatar
V 200 test with 4.5 ...
Ok, just back from the track (same short track as my previous report), same gear used, same Tekin 4.5 motor, timing as per default.
Car: Losi Jrx-Type R, Tekin RS (V200)
Motor: Tekin 4.5, 94/18 (can't go any lower than that...) using the tire diameter to change the overall gear.
Tires: Matrix foam tyres (we use them also outdoor)
Battery: LRP lipo 5300 25C.
Fan on the motor, fan on the esc and an extra capacitor 16V 2200
First run, tyres at 60/59ish, turbo timing 8, turbo boost 19, delay 0.7sec.
Motor temp:65 C
Esc temp:50C
temp bar: 3 led
The first run didn't impress me that much, doesnt "see" any shifting, but... the car was more pleasant than usual to drive.
Second run: new tyres (63mm) turbo timing 6, turbo boost 19, delay 0.7sec.
Motor temp:73 C
Esc temp:60C
tiem on the track: 7 minutes... still full...
temp bar: 7 led, then drop down to 5 and 3, in about 30 seconds...
Bigger tyres means longer gearing, this time the difference is more "clear", shame the short straightline, a longer one will show a better effect..
Might be an impression, but the "softy" behaviour in the second half seems less present
The only thing, the delay should be carefully set... you might get some kick, when you have to brake...
Giorgio is offline   Reply With Quote
Old 08-12-2009, 12:41 PM   #5973
Trader Rating: 16 (94%+)
Questions?? Neutral Width
Neutral Width - Can someone please explain why it is at 56 from Tekin by default, and why you would adjust it higher or lower...
kn7671 is offline   Reply With Quote
Old 08-12-2009, 01:10 PM   #5974
HarryN's Avatar
Send a message via AIM to HarryN
I never understood this feature having such a high setting as well.
Randy?
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 08-12-2009, 01:12 PM   #5975
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
a lower number will give a more sensitive feel,less travel of the trigger
higher number has more travel before power is delivered
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-12-2009, 01:13 PM   #5976
HarryN's Avatar
Originally Posted by 20 SMOKE View Post
a lower number will give a more sensitive feal,less travel of the triger
I think we know that...
The question is why is it set so high, let alone have such a very high setting capability in the first place.
Old 08-12-2009, 01:18 PM   #5977
20 SMOKE's Avatar
probable for the different types of radios used today,if one setting is used it may or may not have the same feel on a different brand,just giving you a wider band to adjust to
Jamie W
Old 08-12-2009, 01:20 PM   #5978
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
It's that high by default to allow cheaper radios to find nuetral. Some RTR radios dont' have have a solid nuetral set point. If we make it lower it might not calibrate.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-12-2009, 01:23 PM   #5979
AOD
AOD's Avatar
Randy do you know when the v200 will be up on the tekin site?
AOD is offline   Reply With Quote
Old 08-12-2009, 02:18 PM   #5980
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yep.. as previously discussed in this thread, for the sake of keeping things simple, we are ignoring the "built in" timing, in the internals of the motor when discussing adding 30 degress of total timing betwen endbell and ESC.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-12-2009, 02:41 PM   #5981
bkspeedo's Avatar
I went and practiced with 200 last night in my 17.5 car and had some questions.
My home tack is rather small 40x60 and there's just not enough time for Turbo to really kick in.
I race at a second track that is 60x70 and will have a chance the see the response from turbo tomorrow.
1. I noticed that when turbo is applied it ramps rather slowly, how much testing was done to determine how fast this ramp should be? Where different ramp times tested for optimal performance?
2. When I set the delay to .5, which I'm assuming is half a second, it sure seems like it takes longer than .5 sec to start applying turbo. Is this because of my first question? The ramp is starting slowly so it appears to take longer than expected.
3. Was there much testing done on small carpet tracks? It seems like the delay feature should be allowed to start at zero being the turbo function is being ramped up so slowly. Or the turbo on ramp should also have a time setting.
I realize this feature was mainly added for large to very large tracks to compete against other ESC's but I think turbo could be applied effectively for short tracks also which would give the RS an advantage over the non-programmable ESCs.
I by no means am complaining about this release I just had a few questions and maybe these questions can be applied in a future release.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 08-12-2009, 02:42 PM   #5982
Krio's Avatar
Trader Rating: 150 (99%+)
With each motor being different in endbell construction your best bet is to look in the end like the picture posted by Skiddins. When we are referring to zero timing (at least I do...lol) we mean when the Hall Sensors are right in the middle of each lamination holding the windings. I would agree that the picture shows about 30 degrees of timing. When you are trying to set the timing from scratch here's your best bet :
Center the Hall sensors on the laminations.
Paint/Grind marks on the endbell and can that line up so you always know where zero is.
If you want more timing than zero, every millimeter around the outside of the can is pretty close to 3 degrees (36mm diameter X 3.14159 = 113mm circumference. 360 degrees divided by 113mm = 3.18 degrees per mm)
Rotating the endbell counter clockwise will advance the timing.
www.kriostasis.com
Krio is online now   Reply With Quote
Old 08-12-2009, 03:00 PM   #5983
Randy, I want sensored mode and Turbo Boost in my RX8
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 08-12-2009, 03:05 PM   #5984
Hello all,
I am ordering the Hotwire now and want to buy a range of gearing options for the car as gearing for V200 may take some trial and error. Also at the track that I race at in Camarillo, Ca. we change the track layout every race weekend and gearing may be an issue. What range of FDR do you think I should be looking at with a 17.5 motor. Track is medium size I guess with a pretty good straight. Thanks for any info.
Rob,
FzCruzer is offline   Reply With Quote
Old 08-12-2009, 03:16 PM   #5985
stitchy's Avatar
Originally Posted by FzCruzer View Post
Hello all,
Rob,
Pete should know this one...Calling reenmachine, calling reenmachine...
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
