Old 08-11-2009, 09:30 AM   #5911
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by Randy_Pike View Post
Set your epa's as you normally would. On my Dx3r I run 150 and 150. On my M8 I ran 140 and 140 to keep 'em even.
Question the the epa's? Why do you set them at 150%? Is that so you guarantee that you are getting full range? I also have a DX3r...this is something I have to look at.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 08-11-2009, 09:39 AM   #5912
HarryN's Avatar
Send a message via AIM to HarryN
Probably to get better braking and more power on throttle. I do the same thing when I adjust my ESC via Hotwire. Any new adjustments made, I recalibrate my radio with the ESC and I use the higher settings on the EPA. Then I scale them down to 100% and then adjust accordingly to my driving style and the track setup.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 08-11-2009, 10:10 AM   #5913
Keep it the same.
When you have the brake lower, you can have problems with braking and calibrating the radio with the speedo.
Also keep the EXP on 0
When you set exp, you can get power problems with calibrating and the power.
One driver changed his exp.
I changed it back to 0.
When he drove again he hath more power.
EXP for throttle is not necessary. You can change the curve on the speedo with the Throttle.
hlpressley
that's the service of Tekin. It's the best service there is.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-11-2009, 10:21 AM   #5914
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If you use the entire range of your epa's you will get better resolution on the trigger travel.
NO, once set to 150 I leave the throttle, I will adjust the Low/Brake down to my preffered brake setting.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-11-2009, 10:31 AM   #5915
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Wicksy1 View Post
Could i please get 200 off someone done
ThanksGuys
Same here
[email protected]
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 08-11-2009, 10:49 AM   #5916
HarryN's Avatar
Interesting, does setting the EPA at 150 allow more current to the motor?? I do not see how 150 and 100 differ in terms of current going to the motor, when setting your ESC.
Unless I am missing something here. I completely understand the brake portion.
Old 08-11-2009, 10:52 AM   #5917
Trader Rating: 1 (60%+)
download link;
uploaded(dot)to/file/wffwy8
v200 uploaded
cico is offline   Reply With Quote
Old 08-11-2009, 10:54 AM   #5918
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
It doesn't allow more current to the motor, It gives a higher resolution to the trigger. If you're a "grip it and rip it" type of driver, you won't notice a difference, but, other drivers evidently can "feel" the difference. I ain't one of those drivers, but I also don't treat the throttle as an on off switch either.
Mac The Knife is offline   Reply With Quote
Old 08-11-2009, 11:15 AM   #5919
RC-ProSpeed's Avatar
Jost got a RS Pro, and I have no clue on how to set it up for my TC
Does anyone can share a good starting point for the RS Pro, I'll be runing a TC in asphalt/rubber tires, small-medium/fast track (if it matters average is 12.7 sec/lap) 8.5 BL motor.
Any advice will be appreciated, since I have no clue on terms like timing boost, motor timing etc...
Thanks in advance
Guillermo
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 08-11-2009, 11:17 AM   #5920
This is true but there are very few drivers who would benefit from that. I believe the problem is tuning the speedy to the radio. Sometimes even when following the manual a speedy dosen't always get 100% throttle or brake correct. Once you tune your speedy you should use your radio to verify that you are getting full throttle and brake. If you are not then you need to adjust your epa to correct the problem.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-11-2009, 11:27 AM   #5921
In that case you describe, You would, for example, calibrate the esc at 100%, and after calibration, turn your endpoints up, say, 125%. Others are maxxing out their EPA's for finer throttle control. Besides, with the RS, when you pull full throttle, you get all of the leds flashing at you, indicating full throttle. Interesting when racing at night, I might add.
Old 08-11-2009, 11:28 AM   #5922
Trader Rating: 20 (100%+)
Talking
deleted!
"Slow is fast." I drove slow but why am I still slow?
javacrazy is offline   Reply With Quote
Old 08-11-2009, 12:11 PM   #5923
delete, please.
Old 08-11-2009, 12:33 PM   #5924
mangoman's Avatar
Cico
You really should remove that uploaded file.
We like to get one on one with customers that get this software so we can go over it's use and proper setup.
Tekin are doing the right thing by us in getting out the latest and greatest software. If they wanted it publicly available they would do it through their own website. I believe one of the other reasons why they have held off making it public is the ability of people who do not understand the software to destroy their motors/speedies.
It's not that hard for people who want the software to contact Randy as he has requested....
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-11-2009, 12:51 PM   #5925
HarryN's Avatar
Here, here! Randy and Team Tekin deserve major Kudos for going above and beyond with their customer service. That is why I will remain a loyal customer to Tekin products.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
