Old 08-10-2009, 02:31 AM   #5776
Skitee's Avatar
Originally Posted by hanulec View Post
What is the maximum temp as shown on the LEDs an RS should be run to? I've been seeing 4 or 5 bars on the temp meter in 13.5t/2s rubber tire touring car.
I'm trying to determine what is the optimal location and positioning for ESC cooling. On my XRay T2 08/09 I had been running the RS right next to the motor, laying flat with the gold posts facing towards the inside of the car. I've been running 13.5t motors mostly -- and haven't had any known overheating problems yet. I'm just trying to get this placed as ideal as possible.
This weekend I swapped the location of my ESC and receiver (futaba) but didn't notice any temp change really. Would spinning the RS 180 degrees so the posts are towards the outside of the chassis help?
thanks.
This weekend I ran my RS in 13.5 at our local national, it never went over 2 LED's even after some 8-9 minute practice runs. I've mounted the RS with the posts facing away from the center of the car.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-10-2009, 03:07 AM   #5777
vazzo's Avatar
Trader Rating: 100 (100%+)
Originally Posted by Uziman View Post
Does anyone see anything wrong with placing some heatshrink over the soldered part of the wire which attaches to the posts?
I'm not talking about all the way down, i know they are used as a heatsink. Just over the solder and the bare copper wire part.
Cheers
I have heatshrink on the exposed wire only above the solder posts and havent had any heat issues.
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 08-10-2009, 05:18 AM   #5778
jkirkwood's Avatar
Originally Posted by Mugen10 View Post
Jared get the software and share it with your fellow Losi driver.
As soon as Tekin releases it; I'll have it at the shop and will help everyone get their controller setup. Meanwhile the v198 is still showing strong results and I can help you get your new controller setup on that version. Plan on putting some track time in because every brushless motor has it's own little sweet spot but once we find it it's worth the homework.
jkirkwood is offline   Reply With Quote
Old 08-10-2009, 05:57 AM   #5779
Trader Rating: 21 (100%+)
Default PM
thanks.
You have a PM.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 08-10-2009, 08:00 AM   #5780
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Default Turbo question
This past weekend i saw someone running the v199 version and it was super fast for a minute or two and then the turbo would stop working? After a 6 minute run the car was pulled off and no turbo. After about 30 seconds or so it started working again? Is this one of the bugs?
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 08-10-2009, 08:19 AM   #5781
Trader Rating: 19 (100%+)
I'm done with the 198 software! No matter how I gear it on my DOU 17.5 it's always gets hotter that 180 degrees. So I tried the previous software (194?) geared it around 4.5, 0 on the motor and 20 boost and to my suprise it ran faster in the in field and faster in the straight. Also temps were around 150-160.
Has anyone else tried this and had success like I did?
zake540 is offline   Reply With Quote
Old 08-10-2009, 08:21 AM   #5782
Trader Rating: 38 (100%+)
Originally Posted by nitrobeast View Post
This past weekend i saw someone running the v199 version and it was super fast for a minute or two and then the turbo would stop working? After a 6 minute run the car was pulled of and no turbo. After about 30 seconds or so it started working again? Is this one of the bugs?
I've seen that as well.
or8ital is offline   Reply With Quote
Old 08-10-2009, 08:28 AM   #5783
John Tag's Avatar
Trader Rating: 42 (100%+)
Radio wasnt set correctly for 199 probally,Some radios needed some ajustments..199 needed to be set with radio high point at 90-100 and then set radio and speedo together. Then when complete turn radio +10 % to 100-110....That should solve that...
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 08-10-2009, 09:16 AM   #5784
Grenade10's Avatar
Trader Rating: 37 (100%+)
I have not tried this, but I am still running 189 in my 10.5 235 pan car. Had some conversations with Randy and decided to leave it there until 200 is up and working. Key is "What ever it takes to make it faster"
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 08-10-2009, 09:29 AM   #5785
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
This is the exact reason why 199 was NEVER released to the public. All the poeple that wound up with it can't manage to get it work properly because the "buddy" that hooked them up did them a disservice not telling them how to use it properly.
This is why I said NO to everyone that asked for it, sorry.
200 is on the horizon. It does not have this issue at all...
If your Duo is overheating double check your settings, there isn't a strong enough difference from 194 to 198 to cause the overheat. I'm betting that you're just off a tooth or two in your setup and simply just on the verge of the "sweet" spot of that motor.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-10-2009, 09:35 AM   #5786
HarryN's Avatar
Send a message via AIM to HarryN
Hey Randy,
Is 199 specifically tied to the DUO motors? My Redline 17.5 is loving it a lot. My most hottest run I got was 114*F. However, I am geared for bottom end instead of top end, because of how tight our track setup is.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 08-10-2009, 10:35 AM   #5787
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by B4james View Post
I face the posts towards the servo and put a small ESC type fan onto the chassis between the servo and ESC blowing over the posts.
If you have a search using the search function on this thread Randy and others have mentioned this tip and have also put photos of it.
thx - I tried rctech search but it sucks - it has huge data holes. next time I'll use google.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-10-2009, 11:05 AM   #5788
Hi randy
http://rcevilempire.com/2009/08/rcee...of-team-tekin/
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 08-10-2009, 11:39 AM   #5789
John Tag's Avatar
Originally Posted by HarryN View Post
Hey Randy,
Harry..
Im not Randy, But 199/200 is for any motor brand. All software is usefull for all winds/brands.
I actuall ran your local tracl last week. Had a great time in Maryland. My motors were coming off at 160-170* temps with 194 software and about same with new software after 6 minutes. I was geared low to mid 4 range for ratio for both softwares. Ill be back up there in a few weeks again, If you have any questions feel free to stop over.....
Old 08-10-2009, 12:03 PM   #5790
HarryN's Avatar
Originally Posted by John Tag View Post
Harry..
Oh man, when did you come on by?? I was there all week at night getting my ABC car setup and dialed.
One person is waiting for version 200 to come out. Would you happen to have the latest software? From what he told me, the turbo adjustment on the new version is amazing.
I have version 199 right now and I think it is doing very well. My motor is blazing fast and stays cool. There were a few guys at the track yesterday that can attest to my car's performance. However, one issue I am having is every time I load hotwire, it says that some of my settings are beyond my current ESC settings and that my ESC may not be compatible. Is this a false positive? Because my motor and ESC are not overheating at all.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
