Old 08-08-2009, 12:55 AM   #5746
barts71m's Avatar
Trader Rating: 34 (100%+)
So went to my local shop where I buy my goodies, the esc is flashing 1,2,6,7 so im guessing its in brushed mode. Planning on throwing another motor on there 2morrow to c if it runs.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 08-08-2009, 05:04 AM   #5747
cannon's Avatar
Trader Rating: 35 (100%+)
Scott
That is the same problem that Steve had. It was the motor
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 08-08-2009, 07:21 AM   #5748
barts71m's Avatar
cheers greg thanks man..got ya email..and replyed...need a new 17.5 before tuesday nite lol
Old 08-08-2009, 02:54 PM   #5749
Default mod
After reading every post, asking questions and even some winging. Ive come up with this conclusion.
The RS Pro is not fast mod esc. Firstly, you cant use sensored mode so no boost or the new turbo feature. Dual mode is luckly to get one or two bars in temp. But it just doesnt cut it racing against sxx's.
So after getting and installing my own sxx. My cars has been completly transformed in mod. I dont know if ill even bother using the sxx for 17.5/10.5 because i know the rs pro so well and still very keen to try out turbo.
Ive asked if the 200 software will improve mod, but no answer. My feeling is no it wont.
zharn is offline   Reply With Quote
Old 08-08-2009, 03:15 PM   #5750
wont.
Looks like there is still some whinging going on here
I haven't heard of people saying the RS is no good for mod, and i've been following this thread since it started. There is the brake drama, but that's it.
Thanks for the post though, almost as helpful as mine!
JR007 is offline   Reply With Quote
Old 08-08-2009, 03:42 PM   #5751
Krio's Avatar
Trader Rating: 150 (99%+)
No one has ever said you have to use dual mode for mod motors. People just recommend it for smooth power and accurate timing. I personally don't like dual mode much...too soft for most of my conditions. I run all of my cars in sensored only and use the boost to my advantage no matter what the motor e.g. in my B44 I run a 6.5 on 12 degrees of timing and 8 boost. People think I have a 5.5 or hotter in that thing.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 08-08-2009, 04:26 PM   #5752
STLNLST's Avatar
Trader Rating: 21 (100%+)
You might want to take the time and look at the team set up's posted on the Tekin website because JMO was never short of power against the sxx at the reedy race. The turbo feature is more spec based. The raw horse power of a mod motor is more than enough (IMO) and turbo isn't needed. What were you running that you had trouble with? Help is on this board....can you post your settings?
STLNLST is offline   Reply With Quote
Old 08-08-2009, 09:48 PM   #5753
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You can use sensored only mode in mod all you want. Some of our team guys do prefer this setup. However you MUST make sure you don't overtime these motors as it can be very unforgiving if you make a wrong decission on a setting.
Matter of fact, at the Reedy Race JMo did in fact motor down since his Tekin Redline 4.5 was too much motor. He chose a Redline 5.5 and still had the ponies to chase down anyone on the track, even those running 4.0 and 4.5 turns.
If you do choose sensored only mode in mod you can use the turbo function. We have team guys testing this right now. I'd like to see a motor timed at 0-5 degrees, 0 timing boost and some turbo. The turbo delay will be critical to proper setup so each track will be different. Even layout changes can create a need to make an adjustment for OPTIMAL performance.
If you have a track you need setup help please don't hesitate to ask. The more info you give me the better setup I can provide you with.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-08-2009, 11:18 PM   #5754
skypilot's Avatar
Trader Rating: 14 (100%+)
i'm just thinking out loud here, but why in the world would you need boost or turbo with a mod motor, my god man, its mod, it has its on boost built in to the motor.
semi retired..
skypilot is offline   Reply With Quote
Old 08-09-2009, 02:49 AM   #5755
Trader Rating: 16 (94%+)
I would think mostly as a fine tuning option. Most running mod used to have one option to increase runtime, reduce heat, or get more speed, and that was to swap to a different mod motor. Not uncommon to see guys switch between a 3.5 up through to a 7.5 to tune the car for the track, BUT NOW with the software punch and timing options in the speedo, you can get that extra speed down the straight w/o having to change the gearing or changing motors.
kn7671 is offline   Reply With Quote
Old 08-09-2009, 07:26 AM   #5756
B4james's Avatar
I know its been asked to death, but is there any further news as to when V200 is going to be released other than soon and to be patient ???
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 08-09-2009, 08:42 AM   #5757
cyanyde's Avatar
Other than soon and be patient?... How about.. absolutely no idea when??..
By the way, heard that Speed Passion will be releasing a new speedo soon. Looks like this Turbo thingy will be in almost every esc... Hopefully we get to try it before those escs are out. I'm currently running my cheapo Hobbywing Xerun and keeping my 2 week old RS Pro in the pit box cos its simply slower. If I tune for speed, I lose punch and vice versa. The Xerun gives a better compromise.
cyanyde is offline   Reply With Quote
Old 08-09-2009, 09:25 AM   #5758
STLNLST's Avatar
Look at it this way.....If Tekin released the 199 with the bug everyone would be on here complaining that they are having problems and a flame war would be brewing. On the other hand keeping everyone posted on the progress has resulted in some flames and people not wanting to wait for it to be done correctly so where does that leave us????? At the club level we have to wait but at some of the bigger races Randy already stated that he will be there and he won't let any Tekin users go without the latest and greatest. So for now rather then being told to be patient how about....it's around the corner Not trying to be a smart a$$ or anything like that. Just trying to ease some minds and built up tension cause I know how it feels to be under powered.
Old 08-09-2009, 09:27 AM   #5759
STLNLST's Avatar
Even with the 198 software????
Old 08-09-2009, 09:34 AM   #5760
Hi Kenny,
What is your speedo settup for lipo 12 scale 13.5?
What motor are you running? Any timing? 189,194,198 What do you prefer? Rollout in inches. Do you run any throttle punch?
boost
drag break
thottle profile
break strength
neutral
I know I missed some stuff...
Thanks,
Travis
march to my own is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
