Old 08-04-2009, 07:51 AM   #5596
niznai's Avatar
If the wire is suspect i would actually check it with a meter. Just in case. You wouldn't want to waste two weeks to find you still have a problem when Tekin sends back all your hardware (motor/esc or both). Wires are annoying and lose continuity easily. Besides being a low cost item I don't think they would have any serious QC.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-04-2009, 08:51 AM   #5597
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I will be in attendance at the IIC. No, you don't need your hotwire. I've got you covered.
The rotors do fit any of our sensored Redline motors.
If you're having ANY cogging you've got one of two problems: You have a sensor issue, or you have poor wiring to your motor, or both.
The RS has a sensor checker function, simply install a motor to the sensor harness, rotate the motor slowly by hand and watch the last 3 led's on the RS for cycling on/off dimmly. If you don't see this THIS is the problem. Try a different motor, sensor harness,etc.
If you have your motor wired wrong ie; A to A , B to B, C to C it will cause sensor issues.
Make sure your soldering on the speedo and motor is good and clean.
The squealing noise is the speedo driving your motor in sensorless mode.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-04-2009, 08:58 AM   #5598
bukil's Avatar
Trader Rating: 39 (100%+)
When you say install a motor to the sensor harness... Do you mean just plug the sensor wire to the motor and leave the ABC wires unsoldered?
bukil is offline   Reply With Quote
Old 08-04-2009, 09:06 AM   #5599
Senna Racing's Avatar
No i think he means make sure your wires are correctly soldered with good joins
Then take a new sensor wire and connect it
then manual turn the wheels of your car with the drive train connected
When you turn the wheels you should see some movement of lights on the speedi
This is covered in the manual
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 08-04-2009, 09:26 AM   #5600
razzor's Avatar
you need to remove teh motor and install the new or spare motor and connect the sensor lead.
The when you switch on the esc you can just turn the motor by hand and you will see the 3 led's on the rhs light up dimly and in sequence.
If any of these led's dont light up then the motor sensor is faulty or damaged.
Not sure if just the sensors are available loose.
Not sure if the surface mount hall sensors can be sourced from electronic supplies and replaced.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-04-2009, 02:14 PM   #5601
Trader Rating: 37 (100%+)
Can any of you guys explain brushless esc AND motor timing...and how they both relate to gearing?
...or does anyone have a link handy that explains all this?
Feel like I'm sort of stumbling around, making changes to gearing/timing without a thorough understanding of it all...
Thanks for any help.
"Fermentation may have been a greater discovery than fire."
-David Rains Wallace
jubilee is offline   Reply With Quote
Old 08-04-2009, 02:20 PM   #5602
skypilot's Avatar
Trader Rating: 14 (100%+)
look at your own home thread under setup tips
but basically, more timing equals more rpm and heat, so lots of timing smaller pinion,
low timing equals more pull, less heat, so run a bigger gear, now go forth and fine that magic combo
semi retired..
skypilot is offline   Reply With Quote
Old 08-04-2009, 02:29 PM   #5603
I'll check it out...
Old 08-04-2009, 03:09 PM   #5604
Team Tekin
Randy_Pike's Avatar
The motor does NOT need to be soldered to the speedo. You can check them with JUST the sensor harness, quick and easy.
In general more timing is more rpm, less torque.
Less timing is more torque, less rpm.
Old 08-04-2009, 03:09 PM   #5605
Trader Rating: 38 (100%+)
Orbital: I'll have a better answer for you monday.
Randy, were you able to get any news on 64-bit support?
or8ital is offline   Reply With Quote
Old 08-04-2009, 03:13 PM   #5606
razzor's Avatar
Mine wouldnt work with the motor wires disconnected.
Casterracing ZX1.5R
Old 08-04-2009, 03:27 PM   #5607
Team Tekin
Randy_Pike's Avatar
If you're doing it with the motor wires unhooked, you must cycle the on/off switch and not hit the throttle.
Old 08-04-2009, 03:42 PM   #5608
Default hotwire
Randy where can I download 189 194 198 from the Tekin website
mshap33 is offline   Reply With Quote
Old 08-04-2009, 03:47 PM   #5609
razzor's Avatar
download the Hotwire software and the esc firmware is in there.
There is a dropdown tab on the rhs of the interface that will list the different versions.
Casterracing ZX1.5R
Old 08-04-2009, 03:52 PM   #5610
Default hotwire
thanks
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
