Old 08-03-2009, 12:05 PM   #5581
PaZ
PaZ's Avatar
thanks for the quick replys guys yea im only running 13.5 stock no higher
cheers
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 08-03-2009, 12:41 PM   #5582
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Originally Posted by Patriiick View Post
After a super quick initial contact to Tekin regarding returning my RS since last month, i have yet to hear back from them despite my sending them 4 emails since.
Can someome tell me if they have been on vacation or at travelling to major races recently ?
Thanks !
No racing/vacations right now. If people are gone it will say "gone racing along with where,etc."
Try calling support.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-03-2009, 12:56 PM   #5583
Randy I see on the site that there are new rotors.
TT2273 13.0mm BL ROTOR
TT2277 13.0mm BL TORQUE ROTOR
TT2277 14.0mm BL HI-TORQUE ROTOR recommended for use with worm drive axles and other high torque applications
Is the 13mm and the 14mm better for short tracks?
And must you gear it heavier?
I have looked at the setup that you posted yesterday and the rotor on it is also 13mm.
The Timing on the motor + the Boost and the gearing is quit heavy when I compare it with what I'm used to drive.
Is this because of the rotor?
Can it handle more timing?
Will it give more acceleration for the infield?
Witch of the rotors is best for a big track? The 12,3 or the 12,5?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-03-2009, 01:03 PM   #5584
razzor's Avatar
Basically the thinner rotors are for higher rpm and the thicker ones for more torque.
For short tight tracks you can benefit from from torque and vice versa depending on what you prefer.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-03-2009, 02:51 PM   #5585
Thanks Razzor.
I think that I want a 13mm and an 12,3mm
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 08-03-2009, 04:11 PM   #5586
Team Tekin
Randy_Pike's Avatar
The larger and torque rotors offer more torque, less rpm's. They are meant for a situation where snap is desireable.
Note: the torque line isn't ROAR legal nor is the 13mm size.
Old 08-03-2009, 04:19 PM   #5587
Trader Rating: 16 (94%+)
What is your opinion on replacing rotors in old Tekin motors? Would a new rotor be enough to restore any performance loss in a well used, but never overheated Tekin Redline motor?
Opinions: If you were headed to a big race, would you always use a new motor, or take a known good motor and just freshen it up with a new rotor and cleaned/oiled bearings?
I plan to be running Tekin RS ESC's and Tekin Redline motors for the IIC is why I ask.
kn7671 is offline   Reply With Quote
Old 08-03-2009, 05:50 PM   #5588
Does anyone knows if I could program RS Pro with my Windows Mobile PDA?
billythekid is offline   Reply With Quote
Old 08-03-2009, 05:52 PM   #5589
Nope. Your best bet would be to get a small netbook for a few hundred bucks.
Old 08-03-2009, 05:57 PM   #5590
STLNLST's Avatar
Trader Rating: 21 (100%+)
The larger rotor was also run because it took the heat allot better. The gearing was exactly the same when using the 12.5 rotor or 12.3 If you're use to running on the smaller tracks then the gearing will look somewhat heavy. It was run on a 160ft straight. The 12.5 rotor is back in the motor and will be run at the Topgun race here in a couple of weeks.
STLNLST is offline   Reply With Quote
Old 08-03-2009, 08:05 PM   #5591
Team Tekin
Randy_Pike's Avatar
I don't get a new motor for each race, that's excessive. I've ran a 17.5 into the ground melting the front wye plate out of it(I had witness's, and NO it's not reccomended) and simply soldered it back up and proceeded to drop 10 seconds off my best qualifier and make the A! LOL Not bad for an offroad guy.
Seriously though, yes if you feel that your motor has given up some performance a new rotor should get you back in the game.
TT2271 12.3mm Stock Roar Legal
TT2272 12.5mm Stock Roar Legal
TT2276 12.5mm Torque Rotor
TT2277 13mm Torque Rotor
Old 08-03-2009, 08:08 PM   #5592
jkirkwood's Avatar
Do all those rotors fit all of the 1/10th scale line of Redline Sensored motors?
jkirkwood is offline   Reply With Quote
Old 08-03-2009, 08:18 PM   #5593
Default IIC at Vegas
randy,
are you or someone else for Tekin going to be at the IIC race in Vegas to help with the setup and programming of speed controls? Also will we need to have our hotwire with us or will u have a hotwire for everyone to use? Thanks for the great product.
robert s is offline   Reply With Quote
Old 08-04-2009, 12:20 AM   #5594
bukil's Avatar
Trader Rating: 39 (100%+)
I have a problem. My motor cogs everytime I hit the brakes then I gas it right away. And when that happens, it would make some weird squealing noises. Not like when you hear the motor peak when you pull the trigger. Mine would go but I would hear a somewhat "resistance" sound and it would not hit the peak rpm "sound".
Here are the things I tried to fix it:
1. Replaced the sensor wire (brand new) - still getting the "cogging sound" and not hear the peak rpm tone.
2. Tear the motor down and cleaned it. I checked the rotor if it was cracked or if it snapped - no cracks ; rotor is looking fine.
3. Upload an old firmware; calibrated the esc & radio; tried the motor - there is still "cogging"
4. Reuploaded my setup firmware (v189); calibrated the esc together with the radio - problem is still there.
5. Tried a different motor (Not Tekin) - same thing but a LOT less if anything.. there's none.
Prior to this happening. I hit the wall and ever since I can't get the system to work - well it works but I would witness the "cogging". More so when I hit the brakes then gas it right away.
Setup:
v189
FDR 4.8 (best setting compared to my old 4.2 - motor come off cool; infield and top end is insane; weird thing is I tried 4.8 FDR using v198 and it was SLOW)
NW 10
Motor timing 10
Boost 20
Drag 0
Brake 100
Linear
Cut off 6.0 (2S lipo)
Brushless Fwd only
Tekin 13.5 with RS
Sensored
Never thermalled my motor.
Is it safe to say my motor is done? Or is it the esc? If it's the esc, how long does it normally take for Tekin to fix it if I send it in for repairs?
Thanks in advance
~Mark
bukil is offline   Reply With Quote
Old 08-04-2009, 07:17 AM   #5595
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Setup:
v189
NW 10
Motor timing 10
Boost 20
Drag 0
Brake 100
Linear
Brushless Fwd only
Tekin 13.5 with RS
Sensored
Thanks in advance
~Mark
That squealing noise is the sound you get when you do not have the sensor harness in. You said you replaced the sensor wire and the motor so that leaves your ESC. I'd call Tekin support to get that fixed.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
