Old 08-03-2009, 02:34 AM   #5566
tc3team's Avatar
I have no doubt v200 is going to be good, but guys...
I've won an A main from 3rd on the grid using v189.
All i'm saying is, dont think 200 is the "be all and and end all" - we still have some good software that IS out there right now
No amount of hounding for it will make it come out any sooner. Maybe i'm just a little more chilled out when it comes to software releases, or more than likely just dread trying to update my software with my limited PC knowledge!
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 08-03-2009, 02:44 AM   #5567
Originally Posted by Randy_Pike View Post
The RX8 will not be affected by this new software. In offroad the turbo function is almost hillarious in spec classes. 17.5 for example is almost like having a 2 speed tranny!
It simply needs to be witnessed to believe.
Got to admit, run the v199 on the weekend, with a 10.5 in an SC10, and it was aweful, I had to turn the turbo off, as it was kicking the back out down the straight
Also tried it in a 6.5 buggy, and it was too much!! Can't wait to try it in the saloon...!!!
DA_cookie_monst is offline   Reply With Quote
Old 08-03-2009, 05:49 AM   #5568
Trader Rating: 38 (100%+)
Originally Posted by chris_dono View Post
Have a look for "windows xp mode" in windows 7. It runs a virtual machine for xp if you want it to.
Not really interested in running a virtual machine. Plus it requires an extra 1GB of memory which my laptop can't take.
or8ital is offline   Reply With Quote
Old 08-03-2009, 07:51 AM   #5569
cyanyde's Avatar
Can someone help me out. I'm struggling to get my RS Pro to work with my car. Here, we drive 11.5T Touring sedans, rubber tires and 7.4v lipo. Our tracks are mid sized with 80 feet or so straights.
My problem is I can't get the same motor to get more speed or punch than if it were hooked on my low cost Xerun 120A. Track time is pretty limited for me so any ideas will really help. I have hotwire, without 199 though... :-(
cyanyde is offline   Reply With Quote
Old 08-03-2009, 08:30 AM   #5570
Patriiick's Avatar
After a super quick initial contact to Tekin regarding returning my RS since last month, i have yet to hear back from them despite my sending them 4 emails since.
Can someome tell me if they have been on vacation or at travelling to major races recently ?
Thanks !
Patriiick is offline   Reply With Quote
Old 08-03-2009, 09:00 AM   #5571
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by B18C Turbo View Post
where can i get 1.99 firmware?
199 is a Team Driver, test only version. 200 will be released to the rest of us shortly, and you will be able to get it from the hotwire section on tekin's website.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-03-2009, 09:06 AM   #5572
Con
Thanks !
I would try calling.Their number is on the website
Con is offline   Reply With Quote
Old 08-03-2009, 10:09 AM   #5573
Krio's Avatar
Trader Rating: 150 (99%+)
For any spec class over 9.5 turns here is what most people are doing. First off, make sure you have the latest firmware from tekins website and upload version 198 into the speedy. Put the timing on the endbell of the motor to 10 degrees and then the rest is in the software. There is a checkbox on the right side in hotwire for "sensored only". Make sure that box is checked and NOT dual mode. Now there should be a slider labeled "boost". Bump that slider up until it reads 20. Make sure to send the settings to the esc and hit ok. Now hit the track and keep gearing up until the motor comes off the track around 150 degrees F or your lap times peak.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 08-03-2009, 10:11 AM   #5574
lochness42's Avatar
Firstly it will be distributed via emails so if you want it asap send mail to Randy to email that is on previous page or 2 pages back.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 08-03-2009, 10:31 AM   #5575
Super Moderator
ooops.. edit. Yes, 200 is coming soon and we might get it emialed to us pretty soon.
- RCSpecialties -
Old 08-03-2009, 10:54 AM   #5576
Jeff Crosson's Avatar
Capt: I'd bet you weren't told about the epa adjustment that is needed to make 199 work properly.
And what would that be?
Jeff Crosson is offline   Reply With Quote
Old 08-03-2009, 11:15 AM   #5577
You must change your EPA settings in your radio before you calibrate the Speedo with the radio.
After that you set it back.
The V200 will be without the problem.
Tekin want's to have the software 100% ok before they give it to everybody.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-03-2009, 11:51 AM   #5578
PaZ
PaZ's Avatar
Alright guys, im about to get a Tekin system for the touring car but im cut between the rs pro and the normal rs. I wont be doing any nationals etc just local clubs and our south west champs, am i really going to notice a difference in taking the pro over the normal one? Is it worth the extra 30 odd quid, oh and ill be running the 13.5 redline
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 08-03-2009, 11:56 AM   #5579
Super Moderator
0 difference. Get the RS, and a hotwire instead
- RCSpecialties -
Old 08-03-2009, 11:57 AM   #5580
Krio's Avatar
The only difference between them is how hot of a motor you can hook to them. If you won't be going hotter than the typical spec classes the regular rs is for you. Save yourself the dough and lower your CG because the rs is lower in profile over the pro.
www.kriostasis.com
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
