Old 07-30-2009, 05:32 AM   #5446
tc3team's Avatar
Originally Posted by razzor View Post
you would probably find you going to a smaller pinion ranging anywhere from 4 to 7 teeth smaller.
Just for all who need to reference, is this for 48dp, or 64dp? im guessing 64?
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-30-2009, 05:36 AM   #5447
razzor's Avatar
Sorry, should have mentioned that.
Yes on 64 pitch.
For 48 pitch you would probably look at 2 to 4 teeth smaller.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-30-2009, 05:38 AM   #5448
tc3team's Avatar
Yes on 64 pitch.
Old 07-30-2009, 07:31 AM   #5449
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
yes I run 64pitch gears....
The class I run is trans-am and our gearing has to stay between 4.2 - 4.6 FDR...
on the small track i gear it down to 4.6FDR and afer 6 minutes it was in the LOW 130F range...
last night on the big track at 4.4FDR it came off after 6 to 8 minutes at 140F...
I'm geared at 4.4 now but for the big track 1/4 down the back stretch it falls on its face and has no more acceleration... Taller gears would help this but I like the infield speed...
Alex
hound_dogs_01 is offline   Reply With Quote
Old 07-30-2009, 07:53 AM   #5450
Alex
Use that setup with the Turbo.
It will kick in on the straight and you will have enough power on the straight.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 07-30-2009, 09:09 AM   #5451
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Randy_Pike View Post
The tuesday joke is funny, I'm gonna use that next time! LOL
I'm shooting for this week soon. We do thouroughly test public loads though so have some patience with us, it WILL be worth the wait.
BOOYa... if you can get it up for the weekend, that would be stellar!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-30-2009, 09:11 AM   #5452
xevias's Avatar
Unless its a local track rule, VTA allows you to go beyond the 4.6 recommendation - just not higher than 4.2. I run in the 4.7 to 4.8 range for a 100' straight track and will try a 5.0 to 5.2 when the turbo gets released.
On larger parking lot tracks (130') I try to get as much top gear on it without going over 170*. That usually means about a 4.5 ratio with 0* timing on the motor and 28 boost on the ESC.
xevias is offline   Reply With Quote
Old 07-30-2009, 12:19 PM   #5453
so you can run lower but not higher????
our track gives some le way... hell last week in the vintage race i didnt have a body yet but had everything else and i took the wing of my mazda 6 boday and ran it....
i may try the 4.8 set up friday night and see how that works... on the little track i can already pull people 5 6 lengths on a 60' straight lol
Alex
Old 07-30-2009, 12:32 PM   #5454
Alex
When you gear it lighter, you will get faster lap times.
You win more speed in the infield.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 07-30-2009, 01:24 PM   #5455
stitchy's Avatar
Probably a stupid queestion, but what are those tiny little tubes that come in the "accessory pack" for?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 07-30-2009, 01:28 PM   #5456
JCarr's Avatar
I have an RS in my DB10R and it will not work with my 1c lipo. I have 198 and have the 1c box checked and fully charged lipo. When I hook uo the batt and turn the car on i get lights 1,2 and 6,7, but when I wiggle the steering a little teh esc arms without the beeps. Then it lights like it is working when I pull the throttle, but the motor is not running. I tried it with a 2c lipo and it works fine. Anybody have any ideas what's up with this?
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 07-30-2009, 01:37 PM   #5457
oldrcr's Avatar
Trader Rating: 44 (100%+)
Are you using a voltage booster or external battery pack to power the electronics? (Separate power supply for the receiver, servo, RS and Transponder)
Most ESC's need something to boost the voltage closer to 5 or 6 volts for the control circuitry to operate properly, a 3.7 volt single LiPo has not quite enough voltage to operate that part of the circuitry.
oldrcr is offline   Reply With Quote
Old 07-30-2009, 01:48 PM   #5458
mangoman's Avatar
I'm just about to start playing with 1s but the problem is probably with the receiver not getting enuff power. There is an rs thread i think for 12th scale which goes on about those problems somewhere on rc tech.
You will need to run a receiver pack or a booster. Running a booster is easiest because you dont have to recharge the the receiver pack (from what i can tell the novak smart boost is the most reliable option). If you get a lipo receiver pack make sure you get a voltage regulator to step down the voltage of the 2s receiver pack to 6 volts.
Oh also if you run the receiver pack you are meant to remove one of the pins from the plug before you plug the rs into the receiver. Yes one of those pins on the end of the black/red/white cable (such a pain) im not sure if you have to do that for the booster i need to do more research.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 07-30-2009, 01:52 PM   #5459
JCarr's Avatar
No, I'm not running a booster or anything. The really odd thing is I put the exact same settings into the RS in my touring car and plugged teh 1c into it and it worked. It did not do the beeping when it armed, but it did arm and run the motor.
Gorilla Size Racing
Old 07-30-2009, 01:53 PM   #5460
Krio's Avatar
Trader Rating: 150 (99%+)
Slide them on the capacitors leads for some protection.
www.kriostasis.com
Krio is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
