Old 07-28-2009, 08:31 AM   #5371
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Jonnydb View Post
im starting with Tekin RS, updating my esc with hotwire, show me the green box, reading some posts here on thread, i tried to change the values, and download to esc but persists the green box, im using the 198 firmware and using with brushed motors, maybe this is a problem?
Ps.: sorry for my bad english
The upgrades to the software and firmware don't apply when this speedo is used with brushed motors. To see the true potential of this ESC, try a brushless motor (you'll never use a brushed motor again!!!)
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 07-28-2009, 08:37 AM   #5372
Jonnydb's Avatar
Send a message via MSN to Jonnydb Send a message via Skype™ to Jonnydb
ok i see
i was running with spx after some issues i decided to take a Tekin, im trying with brushed motors because a silver can class but i usually run stock class
so forget use this esc with brushed motors right?
Jonnydb is offline   Reply With Quote
Old 07-28-2009, 08:38 AM   #5373
cyanyde's Avatar
Sometimes you may have to shove the usb connection in on the hotwire a little harder. You can use it with brushed motors, as stated in the manual. Don't waste money buying another esc for brushed motors. Thats the whole idea of it being designed for both.
cyanyde is offline   Reply With Quote
Old 07-28-2009, 08:43 AM   #5374
oeoeo327's Avatar
ok i see
You can use this ESC with a brushed motor with great results, and you'll have the ability to "tune" the ESC using the MODE and INCR buttons on the case. The only thing you'll miss are the boost (variable timing) and dual-mode features.
Old 07-28-2009, 09:38 AM   #5375
Jonnydb's Avatar
this is the first idea because was designed for both but its ok i keep the esc
Old 07-28-2009, 09:39 AM   #5376
Jonnydb's Avatar
i changed the firmware to 189 and stopped the green box
Old 07-28-2009, 10:09 AM   #5377
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yes, the yellowish/greenish error box is a bug with 198.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-28-2009, 10:50 AM   #5378
How does the RS Pro hold up to modified abuse? Is there trouble with overheating in warmer weather around the 40C mark (+100F)?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-28-2009, 11:35 AM   #5379
jkirkwood's Avatar
Originally Posted by hound_dogs_01 View Post
are the tekin 21.5's as fast as the novak 21.5's?
Alex
Originally Posted by mikky32 View Post
The Tekin is a great motor.
It is as fast as the Novak but it drives much smoother.
Yes the Tekin 21.5s are every bit as fast as the Novak's, perhaps even faster. I run on a small track and the lap times was identical within just a few hundredths. We also tested the Trinity Duo and found it also to be equal on our track as well.
The reason I picked the Tekin was it drives much smoother than the Novak and Duo. The throttle is very linear compared to the other motors which makes the car much easier to drive.
jkirkwood is offline   Reply With Quote
Old 07-28-2009, 11:35 AM   #5380
Damn that's hot.
Do you come outside with that wetter?
I stay inside with an airconditioner
A cool fan on the solder post and a bigger cap.
That must do it.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 07-28-2009, 11:44 AM   #5381
Skitee's Avatar
The RS holds up just fine to low turn mod racing, I ran my RS Pro in touring modified on foam with a 4.5 DUO and outdoors with a 34C ambient high and track temp 57C and the highest the temp went was 5 LED's. I ran an upgraded cap and a high RPM 25mm x 25mm fan mounted about 15mm from the posts blowing directly at the posts.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-28-2009, 11:45 AM   #5382
DriftDreamer06's Avatar
i have read on here a couple times that adding caps help the rs run cooler. i can do this, but i am one of the "why" people. can somebody explain how this helps?
thanks
DriftDreamer06 is offline   Reply With Quote
Old 07-28-2009, 11:52 AM   #5383
Super Moderator
thanks
The cap does some of the work that the ESC would have to do without it, by first storing energy, then releasing it when needed. It keeps the load lower on the ESC istself. If you want, go wiki how a capacitor works.
- RCSpecialties -
Old 07-28-2009, 11:59 AM   #5384
Senna Racing's Avatar
It only gets that temp out west
But you should definitely get one off fisher i dropped over a second on my times last night and so did andrew and he was keeping up and betting your brother
when he coundnt touch him 2 weeks ago
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 07-28-2009, 12:14 PM   #5385
Trader Rating: 26 (100%+)
Due to the tight fit on the F104 I finally had to remove the posts on my RS and solder the wires into the holes in the board. I made sure there is no solder spillover from tab to tab, does anyone see me having a problem with this?
svines1972 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
