Old 07-19-2009, 03:06 PM   #4981
Push control is mainly there for brushed motors which have a lot of natural drag in them which can cause too much drag brake. Brushless motors have very little drag in them to start with so using push control on a BL is going to have very little effect.
Old 07-19-2009, 03:23 PM   #4982
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
it is mostly for the heavy drag brakers to get the efect of a brushed feal,it is also something that if you like drag brake try it push control to help roll through the center some may like it and some may not
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-19-2009, 08:22 PM   #4983
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Push control is the EXACT opposite of drag brake. This is mostly used for brushed applications but we do allow it in brushless. This will actually power the motor partially for a brief amount of time based off of how long full throttle was held. I could see this being usefull on high speed flowing tracks.
If you have drag brake and push control both set, you're working against yourself.
The FDR's I used were for Speedworld Raceway where the Reedy Race of Champions is held. The inside corner to inside corner of the straight is 165'. This track has some technical sections so gearing/timing setups are key. All who ran Tekin ran 199/200 and all improved there positions by doing so.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 07-19-2009, 10:43 PM   #4984
STLNLST's Avatar
Trader Rating: 21 (100%+)
Thanks for making my weekend great. I had plenty of power and my motor never got hotter than 185 I believe. The fan on the motor also helped. The heat/torture test of the motors and speedo's went rather well IMO. Track temp of 160 and outside temps were 106-114. My RS never saw more than 4 lights after a 6min race with a warm up lap or two. I had quite a few straight away victims during the raceday See ya in a couple of weeks.
STLNLST is offline   Reply With Quote
Old 07-19-2009, 11:21 PM   #4985
scalippo's Avatar
Thumbs up
Thanks Randy.
I do not understand why my engine to go better with "PUSH CONTROL" high.
When to use new SW "199 200"?
Ciao
Filippo
www.miniautodromopadovauno.it
scalippo is offline   Reply With Quote
Old 07-20-2009, 08:59 AM   #4986
Senna Racing's Avatar
final got to test my new tekin toaday at my local club here down under air temp was 22c
i was running 17.5 lrp with my rs,with 48p 33p 65s and the inprovement in power was awsome compaired to my tc spec. which was struggling to keep up with my mate on sundays race whom is running a tekin rs and redline 17.5 with a 35p 66s
The back streight is about 35-40m and so is the front for that matter with a technical fieild
My motor was only running at 45c so ithought i would go up a tooth on the spur
but when i went up to 34p 65s i didnt have the same straight line speed do i ghange the timing boost from 20 -25 or how can i get the edge over my mate at least ( Hello =Flip=)
Hope that i have given you guys enough info
Thanks wayne
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 07-20-2009, 09:23 AM   #4987
As the LRP has a timing on the motor of 12 set the boost to 18.
Than find a good infield speed and the straight will be ok.
The Redline motor is faster than the LRP motor.
I have a 10,5 LRP and a Redline 10,5.
The Tekin is on the straight the fastest.
Infield I hath the same speed.
You must gear your LRP motor a bit heavier than the Tekin motor.
I gear my Tekin around the 6,87FDR
The LRP motor 6,0 to 6,3FDR on the same track.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 07-20-2009, 10:08 AM   #4988
ya was runing my lrp combo at 3.4 - 3.5
and rs lrp combo at 4.04-3.92
but will adjust the boost
can the timing be adjusted on the lap can waiting to get my redline next week
Old 07-20-2009, 10:23 AM   #4989
SammyZ's Avatar
Trader Rating: 138 (100%+)
any trade in program for R1 to RS?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 07-20-2009, 10:36 AM   #4990
razzor's Avatar
Thanks wayne
Before gearing up try going down a tooth.
It will allow the motor to get up to rpm sooner down the back straight.
Did the car feel like it reached top speed by halfway to three quater down the straight ?
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 07-20-2009, 10:43 AM   #4991
top speed around 3.4 down the straight
when you say down a tooth is the the spur
thanks
Old 07-20-2009, 11:18 AM   #4992
Team Tekin
Randy_Pike's Avatar
What rotor is in the LRP?
There is currently no trade in program on the R1.
Old 07-20-2009, 11:20 AM   #4993
JayL's Avatar
Thanks for the help with my F1 at the Speedworld Cup Randy!
My next speed step faster, with motor temps ~142, should be add boost or still smaller pinion?
when you guys see Randy at a race man he helps everyone, really makes you like Tekin
JayL is offline   Reply With Quote
Old 07-20-2009, 11:25 AM   #4994
The LRP has a Sintered rotor, 12.3
this is for the 10,5T but I think the 17,5 has the same.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 07-20-2009, 11:40 AM   #4995
randy its 12.3
here are the other spec. if it helps
Weight 168g
Power 153W
Type 17.5 TURNS
Efficiency 93%
Specific rpm/volt, kv 2.300
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
