Old 06-24-2008, 01:51 PM   #481
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Originally Posted by trailranger View Post
I'm not trying to downplay Tekin. I just want the RS series to be the Best and the software is holding back.
You won't think so after you run one yourself.
I do agree on one point, that it would be nice to be able to equate Timing% with degrees of timing. This is the only thing I would do differently.
Neutral width is the percentage of trigger travel that the speed control will read as 'neutral', it has nothing to do with time.
Push Control:
This is a far more noticeable feature with brushed motors, as they have far greater natural drag brake. This basically substitutes putting 'creep' into the radio. A setting larger than 0 for this will prevent the motor from coasting on it's own when the throttle is lifted to neutral from an elevated setting. It will continue to give gradually decreasing current to moment the throttle is lifted. The rate of this decrease is inversely proportional to the push control setting. The higher the push control setting, the more the motor will coast.
The available throttle curves are more than adequate, and it is one of the, if not the most adjustable brushless speed control on the market.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-24-2008, 02:16 PM   #482
I'm still waiting on my RSPro....
I have had the chance to play with someones elses RS with Hotwire.
Things that need to be addressed in Hotwire software.
Timing? 0~100 is that precentage, degrees or miliseconds? Ditch the precentage and go to degrees or miliseconds.
Neutral Width. Again, Ditch the 0~100% and go with degrees or miliseconds.
Push Control? Documentation on what this feature does would be great.
Throttle/break profiles, If you ever owned a Castle Product you would would expect more from the "Pro" Brands
Then add the same adjustiblity from throttle/break profiles to the Hybird timing. Users would be very happy to have be able to adjust the timing curve for the hybird function.
Timing would be nice in degrees since that is what most people are used to with brushed
Neutral width...I understand that to be the amount of trigger throw where it stays in neutral before throttle engages. Percent and degrees would work fine for that. Don't see how miliseconds would work.
Throttle profiles...These days this really isn't needed on the ESC as that is available on just about any radio you'll see at the track anyway.
Push control...I thought this documentation was pretty good. In the software it could be defined a bit better but in the instructions it was fine.
Old 06-24-2008, 02:23 PM   #483
Regional Moderator
CarbonJoe's Avatar
Not having an RS or Hotwire yet, does the Neutral width correlate to the width of the neutral signal from the radio? I know that some radio vendors specify the neutral width in ms.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 06-24-2008, 02:31 PM   #484
See the above two posts for the correct description of Neutral Width.
USVTA Member #211
Old 06-24-2008, 02:59 PM   #485
Hi,
Can sombody tell me were i can buy a Tekin RS pro?
They are every ware out of stock.
Or when are they comming again?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 06-24-2008, 04:02 PM   #486
Geezatec's Avatar
wait like the rest of us!!! They say end of June!!! I had waited 4 months when the R1Pro to be released and available. LHS I bought it from(RSPro) they only had two left.,Still they have no inventory, two month ago!!! Also with Redline Sensorless Modified motor, waiting on!!! LHS are not to blame!! Just wait!!!! We all be lucky if it available the end of July!!!
Geezatec is offline   Reply With Quote
Old 06-24-2008, 04:05 PM   #487
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by Brian McGreevy View Post
You
Push Control:
Is push/creep benificial with bl? Will that provide more corner speed?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 06-24-2008, 04:57 PM   #488
trailranger's Avatar
As long as I get my RSPro by July 18th....i'll be happy.
As for the Neutral width, miliseconds wouldn't work for most users unless they understood that the signal was in PWM. Precentage would work if it considered % the total trigger movement.
Getting the terminology and units of measure on the same page as other manufactures will make Tekin more appealing and more adaptible to everyone.
For the documentation, I was refering to the Hotwire software. There is very little "mouse over" dialog to explain what the adjustment values were changing.
trailranger is offline   Reply With Quote
Old 06-24-2008, 05:00 PM   #489
I think it still is with 13.5 and 17.5 motors. You will have to experiment with that.
USVTA Member #211
Old 06-24-2008, 05:10 PM   #490
davepull's Avatar
According to Jim the push control feature only works in brushed mode.
davepull is offline   Reply With Quote
Old 06-24-2008, 05:36 PM   #491
davepull,
That would make sense. The benefit of it would be very, very minimal at best for most BL motors.
USVTA Member #211
Old 06-24-2008, 06:12 PM   #492
yyhayyim's Avatar
Trader Rating: 26 (100%+)
the manual does say that the push feature is for brushed mode.
yyhayyim is offline   Reply With Quote
Old 06-24-2008, 07:03 PM   #493
miller tyme's Avatar
davepull,
I assume the brushless side of the scale would be drag brake, correct!
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 06-24-2008, 07:18 PM   #494
davepull's Avatar
NO push control is like putting forward roll into the car.
Old 06-24-2008, 09:05 PM   #495
What I meant was on a linear scale:
one end has brushed with natural drag brake where push control tries to reduce that effect and approach a neutral '0'
on the other end of the scale has brushless with natural push and needs drag brake control to approach that neutral '0' point
Ken Miller
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
